Frank C
Frank C last won the day on November 18 2023
Frank C had the most liked content!
1 Follower
Frank C's Achievements
Mentor
Mentor (12/14)
  • Posting Machine Rare
2.1k
  1. Here's the shower curtain retrofit that I did using 3M adhesive command hooks. If you scroll down through the posts you'll see the pics of my install. No drilling required, just command hooks attached around the bathroom walls and ceiling, and it worked very well. And easy to remove the shower curtain completely when not in use, and also to remove it to let it dry outside the camper after using the shower. We sold our Oliver Elite II about 2 years ago to do more overseas travel, but I still lurk here now and then to see what's new in Ollie world. We do miss traveling with our Ollie though, and we are actually looking at getting back into camping again now, so I want to keep up with the latest changes that Oliver has made to the trailer.
  2. here’s a more detailed post of the full modification I did, with links to all the hardware used.
  3. As an example, this was an image generated by a few simple text prompts of our dog living the good life on a motor scooter in Italy (which I can assure you she has never been. She may be a spoiled pup but not that spoiled 🙂), using a very basic AI image generator software program. There are far more powerful AI tools available for photo and video. Unfortunately we have reached the point where any photo or video on the internet is suspect, with basically anything being potentially faked.
  4. Sadly it’s an AI generated image hoax, just like the Caterpillar CAT truck hoax that circulated on the internet previously. The folks that create these do it to get clicks on their webpages. The power of the AI image tools now lets anyone create photo realistic images and video. https://tfltruck.com/2024/09/video-is-a-caterpillar-pickup-truck-really-coming-the-answer-is/
  5. You have the Truma AquaGo hot water system and in the normal COMFORT operating mode it has an internal circulating pump and will turn on fairly frequently, along with the burner, to maintain some ready hot water, and when it does turn on, it makes a noticeable sound, especially if you are on the bed right above it. Used to drive me crazy at night. The solution is to put the Truma on ECO mode. The initial water temp will be lower in ECO mode (see below) but it wont turn on the recirculating pump and burner as often. It also will save propane. Just have to wait a little longer for hot water when you need it. And we don’t have our Oliver trailer anymore, but we do miss it, and I still check in here now and then to see what’s new.
  6. I always had that concern about getting locked out of the trailer and truck if I lost my keys while on the road, so I mounted a small mechanical (no battery) combination lockbox from Lowe’s inside the rear bumper storage area on one frame rail and kept an Ollie door key in there, and then kept a spare truck key hidden inside the Ollie so I could always get access to everything if I ever lost my primary keys while out away from the trailer.
  7. We didn’t get the Oliver shower curtain track with our Elite II. The curtain track is an odd design, seems a bit expensive, and some owners have had issues with the track detaching from the inner hull ceiling because of a poor riveting job. But we wanted a shower curtain though, so I attached the small Command hooks all around on the bathroom ceiling directly above the perimeter of the shower pan in the floor, and then hung a standard shower curtain on those hooks to take our showers, and easy to quickly remove the curtain to let it dry outside the trailer when done. It was a cheap and effective solution to keeping the toilet area dry. And easy to remove it all completely if ever needed. Command strips/hooks are a great accessory for attaching lot of things on the Ollie interior.
  8. The chains are necessary for the anti-sway function also. The chains connect to the “whale tail” at the bottom of the hitch ball tapered spindle, and any sway or turning of the trailer causes that ball spindle to rotate against the friction material of the hitch, damping the sway. If the chains aren’t connected to the whale tail then the trailer bulldog coupler just freely moves on the ball and there’s no anti-sway function. Here’s a pic from the Andersen website.
  9. There are zerk fitting repair/extractor tools available at most auto stores & Tractor Supply. It’s a combination wrench/tap/extractor. I’ve used one in the past. If the fitting is broken off but the threaded part remains in the wet bolt, the extractor (the pointy tool) should allow you to unscrew the threaded portion. https://www.tractorsupply.com/tsc/product/workforce-all-in-one-grease-fitting-repair-tool-for-1-4-in-28-fittings
  10. Make sure the red lever on the Optifuse resettable breaker is pushed inwards (see arrow on picture). The Optifuse breaker on the left shown in the photo is in the open state when the lever is popped out like that. The Optifuse on the right is closed. The red rubber covers on the outer two items are just contact covers on the other self resetting breakers. The Optifuse breakers can manually opened by pressing the little red button on them (which will make the red lever pop out), and then pushing the red lever back in to reset. And this is my first post in a long while since we sold our Ollie. A sad day when it was towed away, but it went to a good new owner. We’ve moved on to other travel plans now. But I still lurk here on the forums occasionally 🙂
  11. It’s because of the greater distance from the rear axle of the RV or trailer to the rear bumper, compared to that same measurement on a car or pickup truck. That greater distance means the loaded bike rack experiences much larger movement up & down and side to side from bumps & potholes in the road, from going around corners, etc. That larger movement means much higher accelerations/forces acting on the hitch and rack. Some motorhomes have ridiculously long rear overhang distance.
  12. Do you only have the plug in 12volt anti-freeze heater kit option installed instead of the standard filter? If so, then yes you will need a standard filter to do the de-calcification process. They are available on Amazon from Truma, but pricey! And check in the Truma compartment thoroughly by opening the outside Truma access door. Some owners (and Oliver service folks) tuck the standard filter into the Truma unit in the area of the wiring harnesses. It just fits in there for storage but can be well hidden. Truma AquaGo Replacement Filter | Compatible with Truma AquaGo Hot Water Heater https://a.co/d/3KBZRdb
  13. I built a similar 2 stage filter system but mounted it in a standard 6 gallon milk crate. All hoses, regulator and fittings store in the crate and the whole thing slides easily into the basement storage area for travel. The filters are mounted using Camco filter mounts attached to aluminum “Z” hanger picture hanging brackets (one bracket on the filters and one bracket screwed to the milk crate) so the filter assembly lifts out to do filter changes. Quick connect fittings on everything so setup at the campground is quick.
  14. It actually happened a couple years ago, back in 2021. https://www.marinebusinessworld.com/news/237945/Dometic-acquires-Zamp-Solar
  15. I listed it on RV Trader and also the Oliver Trailers for Sale Facebook page. All of the legitimate potential buyer leads, and the eventual buyer, were from RV Trader inquires about the trailer. The Facebook page generated a lot of comments and likes but no actual buyer leads.
