katanapilot
katanapilot last won the day on August 25 2022
katanapilot had the most liked content!
1 Follower
    628
    2020
5,050 profile views
katanapilot's Achievements
Rising Star
Rising Star (9/14)
695
  1. I'm sure all the Victron users know this, but there is a temperature input on the Smart Shunt, on the Multiplus II and four on the Cerbo GX. I assume that information can also be fed to the phone app.
  2. Dragonfly Energy (stock ticker DFLI) down 37% today due to 10-1 reverse stock split being announced. They appear to be trying to hold onto their NASDAQ listing as the stock is trading at about $0.45 today.
  3. Going to ask again in a slightly different manner. Has anyone had a catastrophic or near catastrophic outcome as a result of this feature/defect with the BB batteries? On the surface, it does appear that there could be an issue that warrants close monitoring. On the other hand, if users are unlikely to stress the batteries and/or the connections which can lead to the overheating and subsequent arcing condition - I'm not sure there is an immediate need for removal or a large scale recall. As has been discussed, a recall of 400,000 batteries would probably end up bankrupting the company - although the bad press from this issue may do that anyway. Not saying this is the case, but the headlines that get you to click on a story lead to more $$$ for the person writing the article.
  4. Not minimizing the potential issue here with the BB batteries (and I have three in the Oliver) - but keep in mind the recent Truma AquaGo issue. Oliver said there was an issue (and to their credit have been dealing with it) despite the fact that Truma says there is no issue with the AquaGo except in the Oliver trailers. One "expert" saying there is an issue does not necessarily make it so. Doesn't make it not so, either. Haven't seen a recall on the transfer switches that burn up, but certainly some indication that there is a problem there, too. EDIT: As I contemplate the potential danger here, those of us that have converted to Victron components - it would be pretty easy to add temperature sensors to each battery for monitoring by the Cerbo GX with it's four temperature inputs. Probably easy to do with other brand components as well.
  5. Still confused. If the shore power receptacle (30 amps) is wired to the transfer switch (either a 15 or 20 amp rated switch) in the earlier trailers - how was that acceptable? One doesn't switch a 30 amp power source with a 15 or 20 amp switch. That's my confusion. Our trailer has a 30 amp ATS fed by the two shore power receptacles. That makes sense.
  6. I must be missing something and/or am very confused. If the shore power cable goes directly to the ATS (from either external power receptacle), how can either a 15 or 20 amp ATS be acceptable? I admit I have no idea how these were wired on earlier trailers, but it just seems wrong to have a 30 amp source feeding into a 15 or 20 amp switch.
  7. One other possibility to consider is moisture in the tank. If that exists, the expansion of the propane can drop the temperature of the gas below the water freezing point and it can block the line. We had that happen on a previous RV where the tanks weren’t properly purged prior to filling. I had a propane supplier add some alcohol (I believe it was ethanol) to the tank and that cured it. The ethanol absorbed the moisture and it passed through the regulator without freezing.
  8. Has anyone with the 5200 lb axles factory installed had a leaf spring failure?
  9. Contrary view here. I went with 4 leaf ALCAN springs and have had more "content shifting" than with the OEM Dexter springs. The 5 leafs are stiffer yet. Much like a 2500 or 3500 series truck will have a stiffer ride than a 1500 with the same cargo loading. Only makes sense.
  10. McMaster-Carr is also a good source. Fast shipping. https://www.mcmaster.com/products/pins/quick-release-pins-2~/
  11. Stop drilling is how aircraft mechanics deal with small cracks in sheet metal skins, as well as acrylic windows, etc. I assume the same would work for fiberglass. Sharp corners create stress risers which can lead to cracks. Thread drift, sorry - The deHavilland Comet suffered multiple catastrophic failures due to stress risers that occurred with sharp corners. The phenomenon was not well understood at the time (1950's) but the engineers quickly figured out the cause and aircraft design, especially for pressurized aircraft, changed as a result.
  12. Still no Hybrid models (same engine and plenty of failures) and surprisingly didn't see the Sequoia listed in the latest recall. I'm going to call BS on the "manufacturing debris" in the engine 3+ years after the first reports. This looks much more like a design failure that they haven't yet figured out. I see that RAM is bringing back the V8. Wonder if Toyota will do the same. The UR series engines are known for their reliability.
  13. IIRC, the Dometic thermostat used originally for the Dometic Turbojet Penguin A/C, had a digital communication protocol to the control box located in the Penguin. This box had a couple of relays that were used to control the Suburban furnace. There are a few posts somewhere on this forum on how I (and others) modified that box to continue to work with the Suburban. Others have replaced the Dometic thermostat with a more conventional "analog" style to work when they removed the Penguin.
  14. I understand why you might want to reinstall the same unit as you removed - but I feel really bad for you that some dealer took advantage of you. These units are available online for much less and as @jd1923 said - the more capable and robust Victron Multiplus II is even less. Given Xantrex's response to you - I'm a bit surprised you didn't consider other options. Not that it matters, but my opinions is that Oliver would be doing their future customers a big favor by ditching these other brands and going to an all-Victron electrical system.
  15. Not surprised, really. As to feedback from one of us that have the 4 leaf Alcan springs - did a two thousand mile trek to Oshkosh and back in late July plus a recent trip to South Carolina and back last week (about 300 miles round trip). No issues and really no difference noted in handling from the previous Dexter OEM springs. Tire pressure reduced from 50 psi to 45 psi. Single data point doesn't prove or disprove anything.
