Skipster
1 Follower
    822
    Legacy Elite
1,932 profile views
Skipster's Achievements
Enthusiast
Enthusiast (6/14)
44
  1. So took it to bish rv in Bozeman the inverter has power coming in. I had called Zantac support and I will call back tomorrow . They told me 3 year warranty. Our Ollie hull number 822 is going on 4 years old. A new inverter is 1800$ plus labor. Hope xantrax will help.
  2. Thankyou all. I will update when I find out more
  3. What would be my next step
  4. I tested and do have 12v power on either side of the big breaker. I also tested(picture) inside zantrex panel and have power there as well
  5. Took cover off and nothing seems loose. Couple pics with cover off Will check for power with a meter tomorrow
  6. Took cover off and nothing seems loose. Couple pics with cover off
  7. That little button on the end of the inverter is not popped out and does nothing when I push on it
  8. Took off breaker panel to have access to remote plug. Unplugged and put back in a few times when I turn inverter breaker off and then back on I hear a beep and another noise but inverter still not switching on I do not see where microwave would plug in We do not have a microwave and access is through the seat or by taking breaker box off
  9. here are some pictures of the inverter and nearby fuses ect I will get tester and I have a testing 12v light stick. but the problem is I do not know where to put the tester or the light 12v tester.... sorry for my ignorance Its pretty tight in there
  10. still hoping guess Ill look for a rv guru nearby or take it to bozeman mt to get it fixed. should be something simple. but not obvious
  11. seems like it would have to be a fuse but i opened the 3 atached to the red wires coming off a breaker with red button opposite inverter installation underneath seat and tried the main breaker on panel and checked for loose cables. but thinking it has to be a blown fuse not to have any power Im trying to find the other fuses
  12. trying to find inverter gfci output and big input fuse Members 141 Location: Upstate NY Posted 13 minutes ago 12v power on inverter input lugs? GFCI tripped on inverter output? Tried on/off switch right on inverter face panel? Big input fuse feeding inverter blown
  13. tried it all still no power to inverter on dc or ac
  14. Thanks. No power at the inverter itself there are 3 inline fuses in the red wires opposite the inverter. Turn off all power and checking them next
