John Dorrer
Everything posted by John Dorrer
  1. They come in 16's
  2. Sorry you had that happen. Oliver was probably correct with their assessment. People driving on washboard roads, chemically treated roads, and a bad Chinese spring, can all come into play. Not much Oliver can do as they just install the Dexter suspension There is a former Oliver owner that sold their Oliver and bought a different brand. On their first trip their springs flattened. They were replaced and flattened again. They upgraded to a 5th Wheel and I believe doing an Alcan upgrade. Unfortunately, things happen. We have a 3 week trip and then get them replaced June 1st.đŸ€ž
  3. Unaware of any issues on the 5200 lb. Axels since Oliver switched to the 5200 lb. axels. After 5 years we are replacing shocks and having Alcan 4-leaf springs installed. The place that services our suspension said they noticed a slight flattening of the springs. The Alcans just arrived.
  4. I get that, but the axels should be 5,200 on all Oliver's starting in 2022. Maybe I misread what he said. He said he has D35 axels, when it should be D52, rated at 3,500.
  5. The axel weight doesn't seem right. In 2022 Oliver switched to the D52 (5,200 lb), rated at 3,500 lbs due to the 4-leaf spring. Why would Oliver switch back to 3,500 lbs? I'm not sure you are providing the correct information. The older trailers were 3,500 lbs. and these trailers are experiencing the spring breaking. 5,200 axels have been installed since 2022.
  6. Davis Lake was a great stop on our journey from Nashville to Natchez on the Trace.
  7. Welcome and Congrats from Hull #1045, Jolli Olli
  8. Just ordered mine at O'Reilly's. Supposed to be in next week. June 1st for spring and shock replacement
  9. Just received our Alcan Springs 5-leaf with heavy duty hardware. We will be having them installed as 4-leaf. Scheduled for first of June around a short Indiana trip. Will do the two 50 mile drives same day and they will re-torque, and then after our Indiana camping trip for the 500 re-torque.
  10. A 2' level does the job. Set on the rear bumper for side to side. Add levelers as needed, chock and disconnect. I take the 2' level up against the belly band and raise or lower to get level Actually a good idea to have the tongue raised slightly to allow flow in the tanks toward the back. Very simple
  11. Both sinks and shower drain are plumbed to the gray tank. The toilet drains into the black tank only.
  12. GFCI's fail frequently. You need to find another place to plug in. As mentioned previously get a 30 amp (120/single phase) installed in your barn.
  13. The black one is a Progressive 30-amp tester. Never rely on any shore power without testing it.
  14. You should have these testers to check the shore power before you plug into your trailer. You have been asked where your trying to plug in, home, campground, 30amp, 120, 120 with GFCI. You should never plug your trailer anywhere without testing the shore power.
  15. If you are plugging into a GFCI at home, that is more than likely your problem. Get a dedicated 30 amp (120/single phase for RV). What are you plugging into and where? Did you test the shore power plug with a 30amp ot 120 tester to make sure the shore power is safe?
  16. We got hard copy manuals when we picked up our 2022 LE 2. There were instructions with pictures. I have had Oliver make needed adjustments when the trailer was in for service. You need to make very slight adjustments. Too much and the motor will keep running and could burn out the motor. If you Google Girard Awning adjustments you should get a detailed "How To".
  17. You might want to look into Coy's mobile tracking solar set-up that several Oliver Owners are using. Hopeful these owners will chime in and provide info on contacts and how the system works. With your set-up that could be a game changer.
  18. "The Mayor of Prescott" 😊
  19. Mike Sokol will do his own test and that should be a good comparison with Will Prowse. We shall see.
  20. Thank You. I have time to decide. Our 2022 LE2 has the 5,200 lb. axle. I can do 4-leaf and add the 5th leaf later, or have the 4-5 leafs in the basement when we decide to sell.
  21. The later Will Prowse videos were done with battery intact
  22. Here is the Mike Sokol Battleborn interview with Battleborn. I can't figure out how to make this viewable to everyone. For Facebook members, you can open the post before this one. Mike Sokol interviews Denis Phares from Battle Born Batteries on lithium battery terminal overheating! “I reached out to Dragonfly Energy (Maker of Battle Born Batteries) a few months ago after a number of my readers at RVelectricity.SubStack.com asked me to investigate if there was a design flaw with Battle Born Batteries that could cause them to overheat in their RVs. After a few in-depth conversations with Dragonfly Energy’s Founder and CEO, Dr. Denis Phares, I asked for a written interview. Following are my unedited questions and Battle Born’s answers.” - Mike Sokol Mike Sokol: Exactly who is Dragonfly Energy and when did they start building Battle Born batteries? Denis Phares: Dragonfly Energy is a U.S.-based energy storage technology company headquartered in Reno, Nevada. We design and manufacture lithium iron phosphate battery systems for applications including RV, marine, off-grid, and commercial use. Battle Born Batteries is our flagship brand, focused on deep-cycle lithium batteries and complete power systems for real-world applications. We brought our first deep-cycle LiFePO4 battery products to market in 2014. Mike: How long has this core battery architecture been in use, and what does its track record look like across real-world deployments? Denis: The core battery architecture for the 100Ah models was developed and validated between 2014 and 2017, with the product first reaching market in 2016. Since then, it’s been deployed at large scale across RV, marine, off-grid systems and in commercial applications. That long-term field use, combined with consistently low warranty rates, gives us a clear, data- backed understanding of how the design performs across a wide range of real-world conditions, environments, and installation types. At this point, the performance isn’t theoretical, it’s based on years of observed behavior in the field. The design has also been repeatedly validated through third-party certification testing. This includes achieving the ETL mark by Intertek, where the batteries were tested to UL 2054 standards, among others. The most stringent electrical test requires the battery to survive a short circuit where the primary protection mechanism is faulted. In our case, this amounted to completely bypassing the Battery Management System (BMS). Our 12V 100Ah (BB10012) model in particular is among the most extensively tested and certified deep-cycle LiFePO4 batteries in its class. Taken together, that combination of certification testing and long-term field data provides a consistent and well- understood picture of how the products perform. They perform safely and as designed. Mike: How many Battle Born batteries with this design architecture are currently in the field? Denis: Based on our sales information, there are over 400,000 Battle Born Batteries in the field today across a wide range of models and applications. A significant portion of that installed base is our 12V 100Ah batteries, which are the most widely deployed configuration. That scale spans everything from RV and marine systems to full-time off-grid and commercial use. Mike: Since there’s approximately 400,000 Battle Born batteries in use, have there been any large design changes based on user feedback or returns? Denis: There have been no fundamental changes to the core battery architecture. That consistency is intentional. The design was validated through extensive internal testing and third-party certification, and the long-term field data has remained consistent with those results. Maintaining these certifications requires that any component changes be relisted and revalidated through third-party testing, ensuring continued compliance with the same safety standards. Mike: At a high level, what layers of protection are built into Battle Born lithium batteries, and how do they work together to assure maximum safety? Denis: Battle Born Batteries are designed with multiple layers of protection that work together as a system. At the chemistry level, we use lithium iron phosphate (LiFePO4), which is inherently more stable and resistant to thermal runaway than other lithium chemistries. At the electrical level, the battery management system actively protects against overcharge, over-discharge, overcurrent, short circuit, and temperature extremes. At the mechanical level, the batteries use a flame-retardant enclosure and cylindrical cells, a format known for mechanical durability, efficient heat dissipation, and integrated pressure relief features, along with physical spacing that enables passive thermal management. Each of these layers is independently effective, and together they provide a system designed to prevent conditions from escalating. Mike: Why does that internal fail-safe system exist in your batteries in the first place? Denis: The internal fail-safe exists because of how these batteries are evaluated and used in real-world RV OEM applications. To be used in RV OEM installations, batteries must meet safety expectations aligned with RVIA standards, which rely on certifications like UL 2054. That standard includes the single-fault short-circuit test, where the battery is subjected to a direct short with no electronic protection active and must not produce fire. This testing is repeated across multiple units to ensure consistent results. The battery architecture was designed with that requirement in mind. In addition to the battery management system, the design includes a passive, built-in fail-safe within the positive terminal inside the battery pack. Under normal operation, it conducts power with very low resistance. Under sustained fault conditions, it transitions to a high-resistance state and stops current flow. In practical terms, this creates a defined point where current can be interrupted if conditions become unsafe. That behavior has been validated through both certification testing and long-term field data, where the outcome is consistent: the battery stops delivering power rather than allowing the condition to escalate. Mike: When people notice heat at or near the battery terminals, what’s usually going on electrically—and how is that different from an internal failure in a battery causing the problem itself? Denis: In high-current DC systems like RV and off-grid applications, heat at or near battery terminals is almost always related to resistance in the external electrical system, not an internal battery issue. Common causes include loose connections, improper torque, undersized wiring, or resistance elsewhere in the system such as bus bars, disconnects, or inverter connections. When current flows through a high-resistance point, it generates heat. Heat can also travel along conductors, so it may appear to originate at the battery even when the source is elsewhere in the system. The battery is designed to operate normally under proper installation conditions. If a sustained fault develops, such as prolonged heat at a connection point, the internal fail-safe at the positive terminal responds by increasing resistance and interrupting current. So, in most cases, what people are seeing is not originating within the battery itself, but the battery responding to conditions elsewhere in the system in a controlled way, as designed. Mike: There’s been a number of YouTube videos showing overheating of Battle Born batteries. Is that a normal occurrence with an intact battery, or has disassembling the battery for demonstration videos actually created the overheating condition? Denis: The videos questioning the positive terminal design in our 100Ah battery are technically invalid, and here's exactly why. The positive terminal in a Battle Born 100Ah battery is a sealed, structurally constrained assembly. The brass terminal is epoxy-bonded to the lid, which holds the internal components under fixed compression. That's not incidental to the design, it's central to it. Under a sustained thermal fault condition, the polymer layer softens, reducing contact pressure at the metal interfaces. As that pressure collapses, current concentrates at microscopic contact points, causing rapid localized heating. This accelerates the formation of an insulating aluminum oxide layer, which quickly drives the terminal into a high-resistance state and stops current flow. The battery shuts down. No fire, no escalation. When you remove the lid to film what's happening, you've eliminated the structural constraint the mechanism depends on. The terminal is now free to move. Cable torque drives continuous motion between the contacts, which keeps exposing fresh metal surface at the contacts, preventing the protective oxide from ever completing. The result is sustained arcing that looks alarming on video, but is entirely a product of the disassembly, not how the intact battery behaves. In other words, opening the battery to observe the safety mechanism creates a measurement artifact. An intact battery in the same fault condition shuts down effectively. The data, science, and more than a decade of field use consistently support that. Mike: How many battery terminal overheating complaints have you had at your help desk, and what percentage of your help desk calls are from terminal overheating? Denis: Relying on data from 100Ah batteries evaluated through our warranty process since early 2022, approximately 0.2% of units across the installed base have exhibited elevated resistance at the positive terminal. These cases do not appear to be the result of an internal battery failure. Based on our examination of the returned batteries, they are overwhelmingly associated with external factors such as improper installation, poor connections, or system conditions that create resistance and heat at the connection point. Importantly, these events have not resulted in any outcomes that would indicate a battery safety issue and are typically resolved through straightforward troubleshooting or warranty support. We have also closely monitored support activity following the recent videos. While they prompted increased customer inquiries and inspections, we did not observe any increase in or change in type of warranty claims. Terminal-related inquiries represent a small portion of overall support volume. The majority of help desk interactions are related to system setup, charging, or integration, not battery safety concerns. Mike: Have you separated out any battery terminal overheating failures into DIY and Dealer installations? If so, what are the numbers and percentages? Denis: We do not categorize every case with a formal DIY versus dealer label, but we do analyze warranty data across OEM and non-OEM installations, and the pattern is consistent. In OEM installations, where torque specifications and conductor sizing are standardized, cutoff events are extremely rare. The cases we do observe are overwhelmingly concentrated in non-OEM installations, where factors such as connection quality, loose terminations, undersized cables, or improper torque can introduce resistance at the terminal interface. This is not a generalization about DIY installations. Many are done very well. The consistent observation is that installation quality and system conditions are the primary drivers of these events, rather than an issue within the battery itself. Mike: From an installation perspective, how important are best wiring practices, proper torque of terminations, and correct conductor size compared to internal construction the battery itself? Denis: They are critical. In high-current DC systems, connection quality, proper torque, and correct conductor sizing are just as important as the battery itself. Even a small amount of resistance at a connection point can generate significant heat under load. If connections are loose, undersized, or improperly installed, heat will develop regardless of the battery being used. Mike: Do you train your dealers on best practices for Battle Born battery installations? Denis: Yes. Education has been a core part of our approach from early on, and we provide ongoing training and support to dealers and installers on best practices for system design and battery installation, including wiring, connection methods, and overall system integration. This includes technical documentation, direct support from our U.S.-based team, and formal training programs, including RVTIA Level certification courses. The goal is to provide the support to help ensure installations are done correctly and consistently. Mike: How does Battle Born’s Nevada-based technical support team handle questions about battery design and safety, especially when the issue may involve the broader electrical system? Denis: Our Nevada-based technical support team takes a system-level approach. When customers reach out with questions, we don’t just look at the battery in isolation. We work through the full electrical system, including wiring, connections, charging sources, and loads, to identify where issues may be coming from. That often means helping customers troubleshoot installation-related factors such as connection quality, conductor sizing, or integration with other components in the system. The goal is to provide clear, practical guidance to help ensure the entire system is operating safely and as intended. Mike: How does Battle Born’s technical support team adapt as new questions or concerns trend within the RV and off-grid community over time? Denis: Our technical support team has been doing this for a long time, and they’re not just repeating information. They’re actively problem-solving. We’ve been supporting lithium battery systems in these applications for over a decade, so the team has extensive experience working through a wide range of system behaviors, including more complex or less common configurations. As new questions or trends emerge, the team works directly with customers to identify root causes and practical solutions. Mike: For customers worried about internal battery issues, what can they realistically observe, and what should prompt them to reach out for Battle Born support instead of guessing or watching a YouTube video? Denis: In most cases, customers are not going to observe an internal battery issue directly. What they’re seeing are system-level symptoms. Things like heat at a connection point, intermittent performance, or unexpected behavior are typically related to the broader electrical system, not the battery itself, and are not unique to any one brand but common considerations in any battery-based system. If anything seems abnormal or persistent, such as excessive heat or loss of performance, the best next step is to reach out to our technical support team rather than trying to diagnose it based on assumptions or online videos. Mike: If a customer notices overheating at battery terminals or wiring, intermittent performance such as loss of capacity, or anything that doesn’t seem right in their electrical system, what’s the safest next step and who should they contact?” Denis: If something doesn’t seem right, the safest first step is to stop using the system and disconnect power if it can be done safely. From there, they should contact our technical support team so we can help diagnose the issue and guide next steps. END Mike Sokol from RVelectricity.com and the NoShockZone is an independent electrical safety instructor and consultant working out of his FunkWorks Lab in Funkstown, Maryland where he tests a variety of electrical products and systems for the RV industry. As many of you know, Mike’s been producing electrical safety and use articles for RV consumers and technicians over the last 16 years. Sokol_Bb_Interview_Substack.pdf
