Wandering Sagebrush
Wandering Sagebrush last won the day on April 1 2025
Wandering Sagebrush had the most liked content!
3 Followers
    Northeast Oregon
    364
    2018
    All Terrain and Northern Lite truck Campers
Wandering Sagebrush's Achievements
Experienced
Experienced (11/14)
1k
  1. I’m late to the party, but having a truck with similar abilities, I definitely have an opinion. I would never tow my Ollie with my Ranger. The F350 does a fine job. In addition to being able to tow, the ability to stop should be considered.
  2. With respect to the crack. You might want to consider stop drilling the upper end to help relieve the forces in play. To be safe, it would be best to run this by Oliver.
  3. Dale Ann Bradley - Ripple cover
  4. A quick update, Mike Sharpe replied to my ticket, and let me know the hand piece is an ITC. They’re readily available from Amazon. Thank you, Mike.
  5. JD and all, Thank you!
  6. I lied, must be my geezerly memory.
  7. Hi JD, thanks. Unfortunately, ours is different. The hand piece has the female side. I will get a photo posted today.
  8. The hand piece on our outside shower has pinhole leaks along a molding joint, probably my fault. Does anyone have a source, or knows who made it? I did create a service ticket, but have not yet heard back. Thanks
  9. Have tried to use it (just to see if it works), but IMO the Furion stereo/tv is pure unadulterated amp sucking garbage. Oliver, are you listening?
  10. One more recommendation for a SafeJack kit, compressor (I have a Viair 400p), plug kit, and torque wrench. Your experience was a wake-up call for me to get solid lug nuts.
  11. A friend was recently camping at over 10,000 feet, and had the Truma throw an error code. I’m posting here to see if anyone in the Oliver community has had a similar experience. https://www.wanderthewest.com/threads/truma-varioheat-furnace-use-question.1201055/
  12. Craig, thank you. I’ve got the MC 4 to SAE adapter, with polarity reverse plug. Looks like I just need to pick up a controller. Thanks again…
  13. I may do something like this, but is it necessary? Does the wiring from the external SAE solar port connect directly to the batteries, or do they go to the onboard charge controller? I have 2 portable 160 watt EcoFlow panels that do not have a controller. If the external wiring goes from the SAE connector to the charge controller, all I need is a MC4 to SAE adapter, and possibly a reverse polarity adapter if the trailer side has Zamp polarity.
  14. I had a similar hitch on my cargo trailer. In 2020, when moving to NE Oregon, I hit an I-84 expansion joint so hard it popped the hitch of the 2-5/16” ball. The chains held, and in heavy traffic I made it to the very narrow shoulder. Somehow I got it reconnected. The hitch was properly connected. The trailer now has a Bulldog hitch.
  15. One more… Molly Tuttle covering Johnny Hartford’s Gentle on my Mind.
