I dont have a two-way fridge..  my previous camper T@B. Had one ..turn the thermostat knob to the lowest..i think its ccw..toward zero.
spacer.png2022 Elite I  # 1179  |  2024 Tundra SR5 4x4 Crewmax. 5.5 ft. Bed. 3.31gears 10 spd.trans
I too, cannot figure that out. Turning it down to lowest setting and it will still run (when I need to defrost it). The only way I know to totally turn it off is to pull the 12v fuse. I been thinking about installing a switch to make it easier.
2023 Legacy II hull # 1446 "The Scout" . Lithium Pro Solar Package, twin bed
2020 Ram 3500 4x4 dually w/ 6.7 Cummins,
Ham radio callsigns     N4BBQ and KO4KSU (Jill)
I think you need to keep turning for it to turn off..  i found it at Oliver Universtiy 2023  i so therm manual..  If someone knows better with the new fridge..
Yes you have to keep turning it until you feel a click. The light however still comes on when the door is opened, even when the fridge is turned “off”.
I would install a switch at the fuse box.
Edited by jd1923
Yep! I placed a dish towel over the top of the door to keep the door from closing over the winter. If placed correctly, the door stays open but the light switch is depressed, shutting off the light.
Or, add a separate switch.
Steve - Northern Ohio, USA
Facebook - Instagram
I have the new fridge (2-way) and wondered how to turn off. Plus, I always leave frig door open when storing and now I have to deal with the light. Guess I will pull the fuse and breaker.
2024 E2 | Hull # 1527 |Truma | Lithionics (390Ah) |Compost |2024 Tundra| Airstream | Casita | Escape
I take the bulb out.
Then this happened.
I disconnect the light.
ARILINIAKSKYLAMIMNMONMOHOKPASDTNTXVAmed.
Your comment prompted me to go take another look at the fridge light.
My light and thermostat seem to be one unit with a wire going into the interior of the fridge.  I do not see a way of pulling the plug on the light.
Can you illuminate on  how you disconnect the light.
Certainly.
Pull forward on light housing:
Ignore bulb and remove electrical connection at back:
