Heavy but nice backup and works seamlessly with all their solar panels. 30 amp plug in back. 3600 watt inverter. 4kWh backup expandable to 20kWh. Lockable mount.
The one drawback to installing the MP2 the way I did was that it has to be on for power to pass through (shore or gen) so I haven't figured out yet if the Yeti can only be supplemental power outdoors, etc or if there is a workaround so it can actually be main power backup.
Best, M
IMG_7385.thumb.jpeg.ef59f0d719a123076424b37852237220.jpegIMG_7394.thumb.jpeg.41c18192a5aabf03c7f448270354eb9a.jpeg
  • Wow 2
No doubt it will be a great ‘backup’ power supply, but not certain it can be integrated into the Olivers electrical system in similar manner as a generator or shared solar input. This is one for the electrical engineers to chime in on!
https://goalzero.com/collections/escape-ecosystem-off-grid
They sell lots of different integration kits for off-grid use. So It can definitely be the primary power in ones TT but my specific application is trying to use it in conjunction with a Multiplus II. For me, I believe it will have to  be used boondocking for powering external equipment only. But all in all, tremendous upgrade for the GZ line of solar generators. LiFePO4 finally.
We have had a Goal Zero 400 Lithium power pack for 4-5 years. I got it as a back up to run my CPAP if home power goes out. I have taken it on every camping trip from truck camper to Oliver. I store it in the closet. I used the other night when we had severe storms for my CPAP and we charged our phones and my hearing aids. When we take our truck fridge, I use it overnight to power the fridge, and then plug it into 12-volt in the truck to charge it back up. I have their solar panel that I can take, but I find it bulky to take on a trip.
What you have had is Li-ion NMC. Lithium but very different than LFP technology. GZ first LiFePo4 solar generator was the Pro 4000.
Edited by rideadeuce
4 minutes ago, Wandering Sagebrush said:
Looks interesting and nice.  How will you protect it from weather?
Custom cover but it has some weather resistance, for the first time, built in as well.
  • 3 weeks later...
For anyone interested, got the cover in from Covarsandall.com. Strong elastic cord around the button to keep it secure and has velcro flaps 6 in from the top front and back for access. Lighter material than my last from from them but seems durable and waterproof. Welcome20 will get you 20% off.
Mike
IMG_7580.thumb.jpeg.6abb39c96cdf482c577229f154550dc2.jpegIMG_7581.thumb.jpeg.1da449a4aa45a7f6bb79da9ee5d99a2c.jpegIMG_7584.thumb.jpeg.04fa55a3a8871a4d72ad816d1055e082.jpegIMG_7585.thumb.jpeg.64b6d76d01a03081cf672a9f6ce4db09.jpeg
Hey, brother - just pulled into town early this afternoon.  Staying at an RV park near the airport.  D flies in tomorrow AM and we're headed to the owners rally on Tuesday.  Can you recommend a good "Monday Night" food joint nearby?  Just curious....
Cheers!
  • (SOLD) 2022 TUNDRA
@MAX Burner Wish I could have helped you find something but I don't get out to that side of town very often. Hope you have a great time at the Rally.
Cheers mate!
Oh, if you want a decent meal while in Guntersville check out The Rock House it is my favorite, Buck Pocket Steak house is good or check out City Harbor lots of good choices there.
Solid copy, @rideadeuce!  Thanks for the vectors in Guntersville, Mike - will look forward to them!
Cheers!
Edited by MAX Burner
typos
I am using this setup to charge my 4 x Battleborn batteries. The Main unit is under my bed and 2 x 2000 watt are under the garage. I drilled hole so they sit perfectly in dead corner of the garage. and main unit sits under my bed. Ill have to crawl and get pictures. FYI you could charge your main batteries with your goal zero. With 97 percent efficiency on the new dc to dc charger you will not lose much !
Edited by Ty J
2021 Legacy II Hull #728 Pulled by 2015 Toyota Tundra 5.7 with 6.6 bed with Decked pullout.
300 Watt Bouge cigs flat solar. dual 30# propane tanks w/GasStop safety devices and Mopeka tank sensors, Victron Multiplus II 12volt., 400 x Battleborn Batteries ,Victron SmartShunt, Victron cerbo and screen. 2 x Victron Smart solar 100/30 and 1 x Smart solar 100 x 15. 800 watts ground panels. Mopeka tank sensors x 2 , Tempature sensors fridge battery compartment Ruuvi tags with fans. 12 volt  Nova Kool refrigerator. Tosot A/C.  Pecron E3600 + 2000 and 2000 Batteries with victron Orion 50amp dc to dc charger.Electric water valves and IRVWPC2 water pump controller. Truma on demand water heater. Added outdoor side Table. Bumper Toolbox, and Many more mods thank you contributors!
