HDRider Posted May 31, 2024 Posted May 31, 2024 Has anyone else broke the tip off the freezer door? How did you fix it? Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
HDRider Posted May 31, 2024 Author Posted May 31, 2024 Unbroken side 1 Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
Moderators SeaDawg Posted May 31, 2024 Moderators Posted May 31, 2024 I bought a new door. If your fridge is a cf130, same door as my truckrfridge tf 130. Same puny pins. I broke mine a few years ago because I tried tp close it with too much frost buildup. Part is readily available, and install is about 1 minute. 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Ronbrink Posted June 1, 2024 Posted June 1, 2024 Had a similar hinge break on my Norcold three-way. Thinking a fix with Super Glue or similar product. Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Geronimo John Posted June 2, 2024 Posted June 2, 2024 11 hours ago, Ronbrink said: Had a similar hinge break on my Norcold three-way. Thinking a fix with Super Glue or similar product. I am thinking JB Weld it. GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
HDRider Posted June 2, 2024 Author Posted June 2, 2024 On 5/31/2024 at 6:02 PM, SeaDawg said: I bought a new door. If your fridge is a cf130, same door as my truckrfridge tf 130. Same puny pins. I broke mine a few years ago because I tried tp close it with too much frost buildup. Part is readily available, and install is about 1 minute. Where do I find out the model of my fridge? Measuring my door, it seems to match this door. SGC00294AA Isotherm Elegance Cruise Evaporator Freezer Door Replacement (pantherrvproducts.com) Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
rich.dev Posted June 2, 2024 Posted June 2, 2024 1 hour ago, HDRider said: Where do I find out the model of my fridge We also have a 2023 LE2, model# is next to the light switch, should be CR130EL 1 1 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Ronbrink Posted July 1, 2024 Posted July 1, 2024 (edited) On 6/1/2024 at 7:58 AM, Ronbrink said: Had a similar hinge break on my Norcold three-way. Thinking a fix with Super Glue or similar product. Well, before I had a chance to attempt a fix of the broken hinge, the other side broke shortly into a week’s trip. I did take a quick look prior to departure, but determined glue would likely not hold and besides, I misplaced the tiny spring. There was no urgency when heading out, since the single functional hinge had enough spring action to hold the freezer door closed. However, once it broke I had a troublesome floppy door to contend with. No bueno! Thankfully, I carry some Velcro strips and was able to rectify the problem temporarily. In fact now that I know the replacement hinges are fairly pricey, I may extend use of this fix for awhile longer. Double trouble: Short ‘hook’ section on each side of right door end: Back-to-back ‘hook’ and ‘loop’ strap for the door closure: Mas bueno! Edited July 1, 2024 by Ronbrink 3 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
