Installed these today game changer. Simple connection to Victron system. Now I can get rid of the gateway for SensorPush in the attic. Seamless integration with VRM for remote monitoring. Have to get a couple more for the MP2 inverter and battery bank bay.
IMG_8414.thumb.jpg.dbe6a2edf29cc632f4f88bf8431f1571.jpgIMG_8415.thumb.PNG.a9388e3a664f1dace1aaf35bc44a0734.PNGIMG_8416.thumb.jpg.0d8ecea254ae014f3735731b8fb59c50.jpgIMG_8417.thumb.jpg.662375879a32787acfbdd8e13aa13279.jpgIMG_8418.thumb.PNG.e2b6c5be68d3ef222be07796d21f60e3.PNGIMG_8419.thumb.PNG.887d9abce363b86aceb5db012e691c33.PNG
Edited by rideadeuce
5 hours ago, rideadeuce said:
Installed these today game changer. Simple connection to Victron system...
Awesome Mike! I don't have Victron Comms or the BMV712, just a few sensors here and there. This is my Control Dashboard. 🤣
Nice. I have some Mopeka's coming tomorrow as well for the propane tanks. They also play nice with the Victron system,  excited to have most everything going through the Victron VRM. Always switching between apps to monitor things. Still have a separate app for TPMS, LevelMate Pro, EasyTouch RV thermostat, and my Grilla Grill. Ha! A lot of batteries to change but no more gateways to deal with or use up energy.
Do you find the Mopeka propane sensors accurate?
No sorry, not at all! We came home from 2 1/2 weeks to Utah and it was reading OK along the way and got down to 16%. Now it reads 51%! What-the! The 16% reading is likely closer, will only know when I fill, since a 30 lb tank fills at 6.8 gallons.
During this first trip with Mopeka sensors, it often had a warning, re positioning of center. The Mopeka is a flat sensor disk mounted to the round bottom LP tank, go figure. When I fill the tank, I will carefully cut a 1/4” bead  of VHB tape around the perimeter of the Mopeka sensor to mount it securely, while it has a magnet. Next time, I would save the $120, since it is so easy to use one tank at a time with the directional valve.
However, if you want all the toys go for it. Taped into position (do this initially) it should perform. 😂
Edited by jd1923
I cant recommend the mopeka sensors enough, an absolute must have for winter camping and from the things ive heard there is no better product for the job. The issue with the level bouncing around is because they use sonar so when it gets low it has trouble determining where the level is but by then youre already down below 10-15% and its time to refill anyways unless you like waking up freezing in the middle of the night. Getting them setup properly helps but itll still start bouncing around when it gets low enough. calibrate the sensors on a perfectly level surface before attaching then stick onto the tank and use the same surface to adjust it to the right position. the magnets are strong enough that you shouldn't usually need to reposition them unless they really get knocked around hard
2018 F150 FX4 5.0v8
2022 Oliver Elite Hull #1285
2023 Oliver Elite Hull #1434
  • 1 year later...
At first, I was negative re Mopeka, but after their customer service sent me a replacement pair at no cost, without shipping costs nor returning the original pair, I certainly agree with this statement! They have been accurate.
Also, I used the original pair at home on two 20# tanks for our grill and home fire ring. They have been performing as well. Perhaps since they are stationery. Anyway, very happy! 😂
This was originally a Ruuvi thread. I love them! Had purchased a set of 4, the standard type pictured above. These are hard to find today. Anybody have a source?
I purchased two more that I believe they call the Pro model. Black with slots for mounting straps, a bit more expensive. I have the original 4 monitoring cabin temp, back of basement by the plumbing lines, Oliver fridge and Freezer. The two new ones are in the truck cab and our newer Dometic CFX5 refrigerator in the truck bed.
After two years of use, one original Ruuvi that was in our Oliver freezer has gone bad. It no longer reads from the Bluetooth app, same with new battery installed.
They're likely beyond limited warranty, but anybody know of a US-based Ruuvi Customer Service number or website. It seems searches always go outside the US. Is Ruuvi a Finland company? Any info would be helpful. Thx
According to AI (for what its worth):
Support & Contact
For technical support or issues, the primary method is to email support@ruuvi.com. They also maintain an active community forum, Slack, and Telegram for user support.
Just as an FYI, new tech is out there!  Although probably impracticable for most, others might love the Safiery LP tank sensors!  Check out today's new post "AI is here for your trailer!"
Cheers, Geoff
