CRM Posted June 28, 2025 Posted June 28, 2025 4 minutes ago, rideandfly said: What's interesting on the above list 2010 #45 LE2 has 50.5" axles. Yep, and I've triple checked it. Hull 45 was the last trailer sold prior to the shutdown and was built with leftover 5200lb axles used on the LE1's. There aren't any of those on the list but I'd bet all of those early models have the same measurements. 1 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
rideandfly Posted June 28, 2025 Posted June 28, 2025 12 minutes ago, CRM said: Yep, and I've triple checked it. Hull 45 was the last trailer sold prior to the shutdown and was built with leftover 5200lb axles used on the LE1's. There aren't any of those on the list but I'd bet all of those early models have the same measurements. Agree, only axles with SC 50" on the list so far are 2014, 2015, & 2016 LE2s. 1 Bill 2015 LE2 #75 2024 F350 6.8L
Moderators Wayfinder Posted June 28, 2025 Author Moderators Posted June 28, 2025 15 hours ago, jd1923 said: Wow, it's been almost a year, right?! Chris in another thread, I wrote that I just placed a special order with Alcan Spring for Dexter D52 50.00 axles. They are an authorized Dexter distributor. Soon I should get confirmation and a part number for the correct axles for our hulls. If you are going to install yourself or in your home town, you could do the same given it works out for me. But perhaps you'd be going to back Hohenwald which is out of the question for me. Let us know what OTT says now and I will post here when I hear something. yeah, I'm not really up for all that. My full-time job is keeping me busy enough. The old body doesn't like it either. 1 Chris 2016 Legacy Elite II o-o Hull #110 o-o "Rock'in 110" o-o Twin Bed (sometimes converted) o-o 5-leaf Alcan Springs (installed Feb 2026) 2020 RAM 1500 Limited 5.7L Augusta, Georgia
ScottyGS Posted June 20 Posted June 20 I know this is an old thread but.... I am currently in the market for the Nev-R-Lube Axles and wanted to share that Hull #145, a 2016 model, picked up in June has the 50.5" axles. I also assume that current LE2's are provided the D52 axle with an SC measurement of 50.5"..... If someone would confirm that for me I would appreciate it. TIA, Scotty Gregg & Donna Scott and Missy the Westie - The Flying Sea Turtle - 2016 Hull # 145 2024 Nissan Titan XD - Western NC
