4 hours ago, CRM said:
The convertor converts your onboard 12v DC to 57v DC so no AC power needed at all.
I see the Starlink Gen 3 Step Up Converter on line and it seems a pretty easy install!
3 hours ago, Snackchaser said:
Hi John,
We cut the cable years ago, and I’ve used the larger units, Gen-1 and Gen-3 for the Oliver.  Now I use the Mini exclusively with no complaints and we still keep the Gen-3 active at home for security devices and guests while we're away.
The Mini, with it’s built in Routrer, looses speed the farther away it is.  This is due to the WiFi signal dropping off.  So if you go with the Mini Dishy, then I recommend getting a Mini Mesh Node Router for $40 because there are times when you will need to move it farther away to find clear sky.  See my post: The new Starlink Mini Router, for what ails you.
Starlink Beam Switching keeps improving and there are increasing numbers satellites so reception keeps improving and the Mini seems to work as well as the Gen-3 in that regard.  My Mini isn’t quite as fast as the Gen-3, but it’s still blistering fast, and way faster than most cable connections.
There are a number of options to run the Mini from the trailers 12 volt system.  You just can’t use the included 50’ cable because of voltage drop without boosting the voltage.  You can do that with a voltage converter to increase voltage, or one of the available power supplies, or use a shorter cable.
Hope that answers your questions!  Cheers!  Geoff
Thanks, Geoff
I'm now refocusing on the Gen3 because of obstacle interference, it's going to come down to "Does the larger unit actually receive any better with partial tree obstruction?"   Wish us luck :)
13 hours ago, Snackchaser said:
Hi John,
Geoff,
Did you see any/much difference in satellite acquisition with regards to obstacles between the Gen3 and the mini?  That's my main concern.  And where/how did you install the  Starlink Gen 3 Step Up Converter?  Is there any conversion loss with the converter like there is with my inverter?  Thanks so much for your help :)
19 minutes ago, johnwen said:
Geoff,
Well it seems there is no difference (according to ChatGPT) between the 2 concerning obstacle tolerance. The Gen3 is more powerful and faster but the mini's small size is so attractive, and now that it appears they both negotiate obstacles equally I reckon to be back in the mini market :)  I don't think I really need the speed difference between the 2.  This back and forth frenzy is fast coming to a conclusion...yay!
3 minutes ago, johnwen said:
Well it seems there is no difference (according to ChatGPT) between the 2 concerning obstacle tolerance. The Gen3 is more powerful and faster but the mini's small size is so attractive, and now that it appears they both negotiate obstacles equally I reckon to be back in the mini market 🙂 I don't think I really need the speed difference between the 2.  This back and forth frenzy is fast coming to a conclusion...yay!
Hey John,
Chat GPT is often wrong because it relies on opinions like mine🫢  My opinion is that Gen-3 has slightly better reception because of the larger surface area and its motor driven alignment.  However, I don't think it is a significant difference, certainly not enough to offset the benefits of the Mini.  When there are too many obstructions, neither one is going to work well.  But I agree that the Gen-3 is faster, I think probably because of a better Wifi signal, hence I recommend using the Mini Mesh Node Router with the Mini Dishy.  See my post:  "The new Starlink Mini router, for what ails you."
We used to turn-off the power hungry Gen-3 at night to save our battery, the Mini stays on 24/7, a big benefit.  Also, the dishy spends most of its time on a mast, and the heavier Gen-3 on the same mast used to rock the trailer in breeze.  The mini is small and light as a feather in comparison.  See my post "Tacky Starlink mast."  BTW, I see folks buying padded cases and protectors for the Mini, but  they're pretty rugged and mine just lives in the hidden drawer below the pantry when traveling.
It's more challenging to route the Gen-3 cable into the trailer, I've posted some designs on this too, see:  "Great news! Starlink Gen-3 is here and it has Rj45 connectors."  Other folks have posted ways to power it from DC, but I've never looked into that.
The Mini is easy to power, and there are portable power supplies available that can be  taken on  hiking trips.  I make a 3d printed version with built in battery charger, hit me up if interested.  I also have a post on powering the Mini from 12 volts with a 12-48 volt Victron converter, this was for one of the early Mini's and before any commercial solutions were  available.  See my post: "Starlink Mini installation, cracking the 12 volt  barrier... or not."  That post also includes a clean method to get the power cord into the trailer.  I still use that power supply today, but there are cheaper power supplies now available.  Albeit, not as good or energy efficient😆
Hope that helps with your decision process!  Cheers, Geoff
@johnwen if you go with the Mini, I strongly suggest forget about all the wiring schemes and just get a battery for it!
You can use the power adapter included 50 ft cord, 30V output plugged into a your 110V outlet with your inverter running. You can do what Geoff did adding a DC converter to up 12V to 24-30V so you can run the longer cable. OR you can just wiring it to any DC battery from 12V to 30V.
For us it made perfect sense to go with the DeWalt batteries we already have several Dewalt power tools and batteries we bring with us. They run at 20V which is a good voltage for the Mini. It seems that we get close to 1 hour of runtime for each Ah of battery. I purchased two 10Ah batteries and each runs the mini for 8+ hours. Connect one in the morning. Swap the other before dinner and its will run way past when we fall asleep. We move the Mini anywhere required without untangling and tripping over wiring. I mounted a Dewalt battery charger in the Oliver Attic!
This part will connect to any battery terminal:
https://www.amazon.com/CERRXIAN-DC5521-Power-Pigtails-Cable/dp/B0F8Q4V9FC/
This part works for DeWalt and there are so many other battery choices:
https://www.amazon.com/Adapter-Battery-Converter-Terminals-Robotics/dp/B0CDGR4Y8K/?th=1
BTW, Starlink is offering factory refurbished Minis for $299 now. Sure wish they offered this earlier this year when we made our purchase at 10% off $499.
Edited by jd1923
Thanks, John!
24 minutes ago, Snackchaser said:
Hey John,
Geoff, I appreciate all the time you ( and all ) have taken to help me with my decision.  I'll read the rest of your posts today and tomorrow I'll be at the Bozeman BestBuy spending my money :)  I think the way for me is the mini.  We're not power users...just like to watch a few movies now and then.  Most of our use comes through our Verizon data plans, usually at 2 or 3 bars, sometimes 1 :(  I'm sure SL will outperform if not too many obstacles.  I am interested in using the full length of cord to reach open areas and boost the signal if too far away.  Are those Mini Mesh Node Routers generic or specific to the SL?  And since much time is spent boondocking we want to use DC when we can.
Thanks,
I visited DISHYtech youtube and see it's an SL product :) $40  So, it looks like I should run 1 powered cable out to the mini (using the 50ft provided cable) and one (not provided) from the mini back into the trailer.
Edited by johnwen
Hey John,
So I can use the supplied 50ft cable and the supplied power adapter connected to my A/C with my inverter and all will work well?  I suppose I can also connect to my 1000wh Anker Solix solar generator/battery as well... it also supplies A/C with its internal inverter.  I can at least get up and running and figure all the power options at a later date.
Yes, that's all you need to get started! Later you can add features to make usage easier.
I purchased the Mini Router after @Snackchaser proved its effectiveness in allowing for good access speeds at greater distance. I truly purchased it hoping I can interface the Mini Router to our Pepwave router. This would allow one Wi-Fi login and the Pepwave would link the Mini when cell signal is weak. The Mini Router may not be capable of that, but I thought for $40 I'd take a chance. I have not taken the time to use it yet or see if WAN interface to the Pepwave is feasible.
We had it onboard for our recent 5-week trip to Minnesota and back and did not need it, did not use it. I thought if distance was an issue somewhere I would break it out of the box, plug it with supplied wiring and give it a try. I'm not comfortable with the Mini being more than, let alone, 50 ft away from the Oliver for reasons of damage to the unit or theft. Most of our trip, being in the Midwest, we did not need Starlink as our T-Mobile and cell router had good signal. In WY and CO we used Starlink quite a bit, but we never needed it to be more than 20-30 ft away from the Oliver, so the Mini Router sat in the box. I prefer when I can place the Mini in the Oliver front basket or the bed of our pickup truck to keep it out of the wind and out of site to other campers. We only had 2-3 days where I had to placed it away from the truck.
Minimal setup, just buy the Mini and use the provided power cord and adapter plugged into your 110V outlet, inverter ON. Want to invest more, get a battery setup to move the Mini at will without wires getting in the way. Later, think you need greater distance? Then buy the Mini Router. Wire it to your TT or TV with provided power supply or something custom. This is independent of wiring the Mini dish. The Mini can be wired to the Mini Router by Ethernet cable but they also communicate over air and Geoff proved they're still quite efficient in over-air communication.
Now that we are battery-powered cord-free with our Starlink Mini, I would never entertain a wired solution. We just swap and charge batteries twice a day. No winding and storage of power cords!
Edited by jd1923
Minimal setup, just buy the Mini and use the provided power cord and adapter plugged into your 110V outlet, inverter ON. Want to invest move get a battery setup to move the Mini at will without wires getting in the way. Later, think you need greater distance? Then buy the Mini Router. Wire it to your TT or TV with provided power supply or something custom. This is independent of wiring the Mini dish.
All makes sense.... sounds like a deal closer :)  Thanks, John
How weather resistant is the battery powered set up? Will it with stand a torrential down pour? Is it water proof? We leave out Mini out all night long and do not think about whether it rains or not.
Just curious.
Edited by Patriot
1 hour ago, Patriot said:
How weather resistant is the battery powered set up? Will it with stand a torrential down pour? Is it water proof? We leave out Mini out all night long and do not think about whether it rains or not. Just curious.
Thanks for the question David, and the reminder to source a waterproof casing! 😂
Dewalt batteries are water resistant, not waterproof nor IP rated. Purchase of two (2) waterproof 24v LI batteries would be a good solution if you need something solely for this purpose. I went with DeWalt because I had them for other tools.
We don't travel much in rain but had several rainy days on our June trip to Minnesota. One overnight we left the DeWalt battery out, Starlink running. and in the morning it was discharged and drenched! I shook it out, wiped it dry, and let it sit in the sun for a couple hours. Later it charged without issue.
I try to place the battery under the dish or somewhere covered, or you could merely wrap in a heavy plastic bag or purchase an IP-rated case. Something like these products might work well as a waterproof casing:
https://a.co/d/5I9YH3M
https://a.co/d/9JbWYwV
Edited by jd1923
After looking at several options, I thought to buy this simple item to think through the possibilities! Hope to use it soon!
I would not screw down the cover as designed. Instead, I would think of a simple way to clamshell the two halves together while being waterproof. You need to change batteries every half day. Therefore, the container must open and close simply!
Rain is rare where we live and camp, so I could build a waterproof box, redundant wiring, $50 total as an option, to use on rainy weather days. Use the simple harness I've built 80% of the time... when it's just another sunny day in Arizona!
Our 10 Ah DeWalt batteries, measuring 5.5x3.5x3.5", should fit nicely in this case and soon we shall have a simple waterproof casing. 😂
https://www.amazon.com/dp/B0DHKW6DH3/?th=1
Edited by jd1923
The mini is up and running with what came in the box (thanks JD).  Will run this way for a while and find the best way to operate on DC only with minimal cabling.  Wendy is very happy :classic_smile:.  And thanks, Geoff (and all) for the encouragement.  I think I'm going to like going with the mini!
John,
Welcome to the SL Mini world. We have had ours over a year now and won’t leave home without it. Its portability, ease of storage and 5 min ease of set up has been a win for us. I hope you enjoy your mini as much as we do! Always remember set up facing north and no obstructions. 😊
We have really come to appreciate this well crafted aluminum protective case which adds a little weight to the Mini. - https://www.strikerfab.com/
David
Edited by Patriot
Mini cable wrap- https://shop.banthaoverland.com/products/starlink-mini-cable-wrap-81516?variant=
I am considering this cable wrap to quickly deploy and store my SL cable. I like the cable cap protectors also, they are proud of them.
The previous reels I purchased did not work as I had hoped. What is everyone using to reel up or store their Mini cable? I like to keep gear neat and buttoned up.
Edited by Patriot
The previous reels I purchased did not work as I had hoped. What everyone using to reel up or store their Mini cable? I like to keep gear neat and buttoned up.
David,
I just ordered the kit because it comes with a tripod mount that I hope can be used by my Benro tripod.
6 hours ago, johnwen said:
David,
Hey John,
It has solid reviews and will be easier to stow the cable than my present reel. Please up if this works with your tripod mount.
Thanks!
Edited by Patriot
Bought this at Ace Hardware for less than $20, works great! The smaller shown is from a roll of Paracord.
Ron,
Perfect! I will be headed over the my local ACE today.
Thanks!
David
Edited by Patriot
@Ronbrink Our local Ace HW did not have the cord holder like yours in stock. I found this at of all places our local “Wally World“ and picked up (2) for $3.97 each.
They are fairly robust and will allow me to keep my cables buttoned up when not in use.  They are the size I was looking for to fit in my HF case perfectly. Thanks again for the idea!
IMG_3711.thumb.jpeg.54291a41d328764aa2119c6789c0c15e.jpegIMG_3711.thumb.jpeg.54291a41d328764aa2119c6789c0c15e.jpeg
Edited by Patriot
