2 hours ago, Derek B said:
@Teaney Hull 292 there are 3 ongoing post on the forum right now about lithium up grades and I must admit I have gotten confused on what was said in each one.
What I haven’t seen in your post is mention of disconnecting the charge wire for you 7 pin connection.
Just want to make sure you don’t miss that requirement when going to lithium.
It was discussed recently @tallmandan thread below,
https://olivertraveltrailers.com/forums/topic/10748-epoc-lithium-keep-it-simple-upgrade-advice/
Good to know. Will check on this.
Gary and Anita Teaney and Ranger
2017 Oliver Elite II Hull 292
2018 Nissan Armada
Tampa, FL
On 3/27/2025 at 1:27 PM, Galway Girl said:
If your current PD4000 Charging board does not have the AGM/Lithium Jumper setting, the PD4000 Series Lithium converter upgrade board is available via E-Trailer.
Please check which original converter board you have....60Amp or 45 Amp.  (ours was 60Amp)
To upgrade your trailer if you have a 45Amp board, stick with the 45AMP LI plug in...if you have 60Amp board, then use 60amp LI version. (Safety for wires is important.)
This upgrade only takes about 30 minutes to complete.
Here's the overview link to the Progressive dynamics site that shows the lithium replacement part number.
https://www.progressivedyn.com/lithium-converter-replacement-units/
Snip from that page:
 E-Trailer has both boards available.
45 Amp Version
https://www.etrailer.com/Accessories-and-Parts/Progressive-Dynamics/PD4045CSV.html?feed=npn&gad_source=1&gbraid=0AAAAAD_vMtnZsg_-Is9SAt6Ew5v33GB0V&gclid=EAIaIQobChMIpem7gN-qjAMVpiytBh3oeBfeEAQYASABEgLqC_D_BwE
60 Amp Version
https://www.etrailer.com/Accessories-and-Parts/Progressive-Dynamics/PD4060CSV.html?feed=npn&gad_source=1&gbraid=0AAAAAD_vMtnZsg_-Is9SAt6Ew5v33GB0V&gclid=EAIaIQobChMIi-LJ9N-qjAMVY83CBB3qGQb2EAQYASABEgK0DvD_BwE
One big difference between the bigger victron or xantrex charger/inverters is that they charge the batteries at >120Amp output...so faster charging. But you spend a lot more for functions you already have in your trailer.
Often the simple path is often the best....with a simple plug in board upgrade and new LI batteries you'll be served for many years.
Craig
Craig, I often go the path less traveled, and end up in the briars and brambles. For $184 I can add the 45 watt charger board. I also am looking at the Xantrex 3000 watt to get the higher amp output. May just go with the 45 watt board and see how it works with my new Lithium batteries.
2018 Nissan Armada
Tampa, FL
On 3/27/2025 at 6:25 PM, CRM said:
And this can be a deciding factor if you boondock with a generator. Depending on which PD convertor/charger you have you'll be running the generator 2x or longer than you would with a 120 amp Victron to top off your batteries.
With the 45 amp upgrade, maybe 3 times longer. Spend more now, to save money later??? Or jump in all in. Decisions, decisions.
2018 Nissan Armada
Tampa, FL
7 hours ago, jd1923 said:
We stopped using a generator after we sold our Class-C. As you know, we have the Victron Multiplus II 12/3000/120-50. The numbers translate to 12VDC output / 3000 KVA inverter capacity / 120A max charge output / 50A max AC input (shore power/generator).
I've had our charge output on the MP2 set to 50A ever since we installed ours last summer, and in our case we do not have a reason for faster charging. Specs for the 300AH Epoch Essentials show "recommended charge current" at 50A. Max charge current is 200A, so they could certainly take every bit of the 120A, but why is 50A recommended? Perhaps the lower charge is better for the life of the batteries.
With 600AH we can go for days, a week or more off grid, assuming no use of A/C. Given the SW skies cloud up for awhile (rarely except when caused by chem-trails🙁), we can eventually get low on SOC. Under 50% is rare, but I do remember one trip it got down to 20% and the red warning light was on the Victron Connect app! (I set this to 20%.)
What we did that time, and would do again whenever needed, is merely to stay one night somewhere with electric hook-ups. Plug into shore power and the MP2 is giving a full 50A to the batteries. At 20% SOC, down 80% on 600AH is 480AH to charge. Let's round up to 500AH (worse-case scenario). To re-coop this would take 10 hours to charge at a 50AH rate. We are going to check-in late afternoon say about 4PM, and even if you're the type to leave before the sun rises (not us!), you're going to be connected for 12-14 hours minimum. SOC is back to 100% HOURS before we would leave and we're good for another week.
I much prefer this to carrying a generator and extra fuel. You like to camp summers in the SE, God bless ya, get hook-ups because if you're running your generator all day you will get ugly looks from me and many others! Generators rules at campgrounds are generally no use after 10PM and boondocking in the SE is rare where you could be far enough away from neighbors to run a noisy generator and even worse, the awfully noisy Dometic Penguin II! 🤣
Well said. Thanks
2018 Nissan Armada
Tampa, FL
6 hours ago, jd1923 said:
Didn't I read @Patriot write something like this? Also, @Ronbrink or @MAX Burner might have commented the same. Who else is still carrying RV technology of yesteryear and rarely to never using it?
With 600AH LiFePO4 and 720W solar we're good for emergencies. I get it if you have no solar, but do get solar so you can loose the generator! We also carry 35 gal extra water in the TV for boondocking and emergencies. We can get stuck somewhere for days but TG this had not occurred! Chris loves boondocking, and we much prefer it to campgrounds and truly dislike RV parks (or worse "RV resorts" 🤣). More often than not, when we have hook-ups, we don't use them, and if we need to we charge up, fill water and dump tanks prior to leaving so we're good for another week or so.
I preferred adding a 400W solar suitcase vs. a generator, since we live SW, have mostly sunny days and rarely ever need A/C. We have only used the suitcase twice, so it is near the category of the rarely used generator, but no need for fuel and takes less space standing up in the TV. I can have it position the night before so it starts charging before we get up in the morning and it's on all day without bothering neighbors. WE move it to face the sun occasionally but not anal about doing so. Just other ideas to consider...
Looking at adding about 600AH from your earlier comments, Have 380 portable solar. Will add the Lithium and the 4045CVS board and see how that works.
2018 Nissan Armada
Tampa, FL
6 hours ago, CRM said:
Personally, I won't go anywhere without my little Honda generator. Haven't had to use it yet but it's nice to know it's there in case of emergency. Can run the AC on it for 6-8 hours on just a gallon of gas. Not having solar installed yet is another reason I carry it, so I can top off the batteries in the unlikely event we're ever boondocking (wife hates it 😂).
Also, I get that lower charge amps might extend battery life, but in your setup you're only charging each battery at 25 amps, not 50. To get to the recommended 50amps you'll have to set your charger to 100.
Oh, did not know about 2 Lithium batteries, means 45 amps with the new 4045CVS board will only charge 22.5 amps. Will have to camp in cool months/up North.
2018 Nissan Armada
Tampa, FL
6 hours ago, Ronbrink said:
I use mine to run the a/c at nights, as needed, which is often as we make our way to and from a far destination. In doing so, my house batteries get a boost, as well, with no solar. Although I can run the a/c on inverter for several hours, I like knowing we can stay comfortable in the event of a lengthy unplanned holdover. Happy wife, happy ‘travel’ life!
So your 460AH Lithium batteries will run the AC for a few hours? We have the 13,500 Dometic Penguins
2018 Nissan Armada
Tampa, FL
I'm an engineer, certainly a numbers geek, and OMG! I never added this up before. 🤣
Yes, you are absolutely correct. The Epoch app displays total amps +/- and amps to each battery. This was taken on a recent winter day, snow on the solar panels and I plugged in after several days of this weather.
You can see +48.4A net charge to the batteries, with individual batteries receiving 22.8A and 25.6A (see pic). I should set our Victron to 100A charging and next time I'm down to 20% SOC we can recover in under 5 hours.
Another reason we love this forum. Even the Master learns here.
2018 Nissan Armada
Tampa, FL
No, you will still get the full 45 amps of charging, it's just that it's split between two batteries when wired parallel, sending 22.5 amps to each.
I get it. With home base of Houston or Tampa you guys have different needs. We will never come to visit you during the summer months!
You are welcome any winter to visit us in Tampa
2018 Nissan Armada
Tampa, FL
5 hours ago, CRM said:
I will definitely be adding solar sometime next year.  My son will be going off to college and my wife and I will be hitting the road for a VERY extended period. Want to be ready for boondocking, which I know we'll have to do along the way, whether she likes it or not! In the beginning stages of planning now and will stuff in as many amp hours worth of batteries, and as many watts of solar as possible, but still crunching numbers and comparing all the other parts and pieces. I really just wanted to go all Victron since I love their monitoring system but when comparing the invertor function of the MultiPlus 12/3000/120-50 to the Xantrex XC Pro 3000 I found a substantial difference in wattage ratings as the temps climb. At 104 degrees and above the Victron de-rates much more than the Xantrex and it only has 1760 watts available for inductive loads while the Xantrex has 2400. Gets even worse at 113 degress where it's 1628 vs 2220. I know we'll eventually end up in some pretty hot places where we'll need to run the AC for a while and I want to be sure I can run it under those conditions, so for now I'm stuck on what to do.  Thankfully I have time to figure it out and make a decision.
Sorry to hijack your post, @Teaney Hull 292! I'll buy the first round next time!
I’ll buy the 2nd round. It’s all good,.
2018 Nissan Armada
Tampa, FL
4 hours ago, jd1923 said:
I've been amplifying the hi-jack but I imagine @Teaney Hull 292 got what they needed in 2 pages and we're all here for more questions from any and all members!
I would not worry about the 104F heat issue unless you plan to exterior mount your inverter in the sun! 🤣 Ours is under the streetside bed. It did get up to 104 during testing  August afternoons where we get pretty hot, when sitting in the sun. I installed the dual Beech Lane fan, like the one I installed in the fridge cavity. It pulls air from the streetside basement, all the way from vents I added in the bath, closet, etc. With the fan on 104F drops to about 88F, with A/C on and the interior about 74F.
Reason you want the Victron is you can run your A/C on generator with the Victron supplementing extra power from your batteries when the compressor is running and when the compressor shuts off your generator would be back to charging batteries. You likely know this already. Victron calls the feature Power-Assist.
Re your other comments, she may learn to like boondocking. We love where we can go where there are paved roads and campgrounds. More opportunities west than east. Oct we plan to park the Oliver on the edge of the North Rim!
If at a point where we truly want to run A/C on batteries, after we replace the Dometic with something efficient, a third 300AH could be in our future. Given you have the Honda, I do NOT suggest the suitcase addition. We rarely use ours and wish I had saved the $800+ for the suitcase, the Victron 30A MPPT, cabling, connectors, etc. I would certainly suggest adding 400W or as much as you can get on your rooftop. Our 2x 160W panels are now 10 years old. I wonder how efficient they could be. Given that and the flat mounting we usually only get +10 to 12A net charging rates (winter afternoon sun). The 400W Renogy suitcase will double those numbers, from a combination of newer panels and being angled towards the sun.
I'm looking forward to reading about your upgrade when you get to it! 😂
Just so you all know, my brain is overflowing with all the great on and off comments. Love them all. I’ve been cutting and pasting notes, and should have created a separate folder for just Batteries and Solar and install. You are all giving me a college course in Oliver Trailer Life. Thanks
2018 Nissan Armada
Tampa, FL
My former a/c was the 11K DPll and I would run the LFPs to 50% SOC, never had a reason for a longer period of discharge. Last September a more efficient Dreiha Atmos 4.4 (15K/12K heat pump) was installed and looking forward to a hot summer test for run duration. In general, I run on inverter for lengthy periods at the Cow Barn when performing maintenance, cleanup, travel prep or just hanging out. Upon departure, shore power then provides 80A charge via the Xantrex 2000, however if the SOC was dropped below 75% an auxiliary onboard 30A Victron Blue Smart  charger kicks in via a Cerbo for a combined 110A of rapid charge. When traveling, the a/c is run on inverter during various stops to eat, shop, rest etc., as necessary, and when back underway a 40A DC-DC charger then restores the SOC until a destination is reached. If the night’s stay is off grid and a/c is needed, a small dual fuel genny on propane is deployed, which also brings the LFPs to 100% SOC. This is how we roll given our style of camping; lack of solar has never been an issue, nor thoughts of a larger Ah battery bank.
Edited by Ronbrink
2020 OLEll, Twin, 579:
