Nick and Linda Stratigakis Posted April 29 Posted April 29 Currently on a trip.last night I discovered that the water valve is leaking . Understand I will have to replace the valve and found one in Amazon. My question is how hard is to remove the old one and replace with a new one .seems the kit includes everything I need. thank you for any guidance or suggestions
Galway Girl Posted April 29 Posted April 29 (edited) This you tube shows the trick is getting one screw (that's very hard to see on the back) removed before trying to pop out the valve. See the 2:12 Mark on video...easiest to use a 1/4" socket to remove screw.]\ Edited April 29 by Galway Girl 1 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine Aug 2024 on way to Nova Scotia.
Nick and Linda Stratigakis Posted May 1 Author Posted May 1 Thank you for the recommendation of using a 1/4” socket. It made my work much easier. 1
