Steve Morris Posted May 14 Posted May 14 (edited) Some may recall my plans to add an Anderson Powerpole 12V DC outlet to the front of Curiosity. My plan was to drill through the front of the propane housing, low, behind the front basket. I started that project today. The plan was to tie into the front jack wiring to supply power. But then I thought it might be easier to run the positive wire down from the jack switch terminal, avoiding cutting into the jack’s feed wire. When I pulled off the jack cover, I discovered the is a lot of extra room inside the cover. So, instead of drilling through fiberglass, I drilled through an inexpensive replaceable part. Easy peasey! All that’s left is the wiring (along with wiring the two outlets I added under the flip-up table next to the door.) EDIT: Yes, I will add an inline fuse, and not rely on the jack’s 30A slo-blow fuse. 😉 Edited May 14 by Steve Morris 7 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
Jason Foster Posted May 15 Posted May 15 (edited) 5 hours ago, Steve Morris said: Some may recall my plans to add an Anderson Powerpole 12V DC outlet to the front of Curiosity. My plan was to drill through the front of the propane housing, low, behind the front basket. I started that project today. The plan was to tie into the front jack wiring to supply power. But then I thought it might be easier to run the positive wire down from the jack switch terminal, avoiding cutting into the jack’s feed wire. When I pulled off the jack cover, I discovered the is a lot of extra room inside the cover. So, instead of drilling through fiberglass, I drilled through an inexpensive replaceable part. Easy peasey! All that’s left is the wiring (along with wiring the two outlets I added under the flip-up table next to the door.) EDIT: Yes, I will add an inline fuse, and not rely on the jack’s 30A slo-blow fuse. 😉 I dont have a power pole but I could add a nice USB plug for those times I want to charge my phone and leave it on the trailer tongue. edit: looked up powerpole thinking it was some kind of powered flag pole or mount for a Starlink satellite. Looks like it is just another type of dc connection. I guess for an additional freezer in the front basket? Edited May 15 by Jason Foster 1 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Moderators topgun2 Posted May 15 Moderators Posted May 15 8 hours ago, Jason Foster said: for those times I want to charge my phone and leave it on the trailer tongue. Why do I see a lost phone in the future? 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Jason Foster Posted May 15 Posted May 15 10 minutes ago, topgun2 said: Why do I see a lost phone in the future? Exactly. 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Steve Morris Posted May 15 Author Posted May 15 8 hours ago, Jason Foster said: I dont have a power pole but I could add a nice USB plug for those times I want to charge my phone and leave it on the trailer tongue. edit: looked up powerpole thinking it was some kind of powered flag pole or mount for a Starlink satellite. Looks like it is just another type of dc connection. I guess for an additional freezer in the front basket? It is for my National Luna 90L fridge/freezer in my tow vehicle while at camp. It uses an Anderson plug for DC power. We head to the Adirondacks June 1, where we’ll have no hookups or much sunlight for nine days. So I’ll use Curiosity’s giant battery to power the truck fridge instead of the 700W Bluetti power station I typically use, but only lasts 24-36 hours using the freezer. Anderson connectors of various sizes are widely used in DC systems. Most DC to DC setups use them, and you’ll see them on semi trucks, forklifts, golf carts, etc. They’ve been the industry standard high amperage connection for about 75 years. 2 3 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
Ollie-Haus Posted May 15 Posted May 15 I’ve picked up an EcoFlow dc/dc charger that’s going to be installed in the truck for the purpose of fast charging the EcoFlow lithium battery we keep in the truck for the same refrigerator purposes. For us redundancy is a necessity. 👍 1 1 What's today?............. the most frequently asked question as a retiree 🙄 Chris and Stacie Neuhaus Greenfield, Indiana 2021 Ford F350 7.3L Tremor (Redzilla) LE2 #1373 - Ordered 10/21/22 - Delivered 05/10/23
Jason Foster Posted May 15 Posted May 15 43 minutes ago, Steve Morris said: It is for my National Luna 90L fridge/freezer in my tow vehicle while at camp. It uses an Anderson plug for DC power. We head to the Adirondacks June 1, where we’ll have no hookups or much sunlight for nine days. So I’ll use Curiosity’s giant battery to power the truck fridge instead of the 700W Bluetti power station I typically use, but only lasts 24-36 hours using the freezer. Anderson connectors of various sizes are widely used in DC systems. Most DC to DC setups use them, and you’ll see them on semi trucks, forklifts, golf carts, etc. They’ve been the industry standard high amperage connection for about 75 years. Thanks. I didn’t know about this connection. I apparently live in the RV stone age where the only DC connection is a cigarette lighter plug in. I’ve only recently found out about USBs in dc operations. In my defense, I don’t sctually own a portable powered freezer. Mine uses ice. 2 2 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
MAX Burner Posted May 16 Posted May 16 On 5/15/2025 at 8:30 AM, Jason Foster said: Mine uses ice. Same here. 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
