aaronorange Posted June 18, 2025 Posted June 18, 2025 I have the Xantrex 3000 in a 2022 E2 w/390ah Lithionics. The 300A Optifuse continues to trip. This happens when the battery charger is charging while on shore power. Or when I run the AC at around 1000 ish watts on the inverter, it will typically throw an error 20 in that case as well. It seems to do short runs on the microwave oven (1 to2 min ok, haven’t tested long run times). As far as the inverter charger setting Oliver requires the Charger Current set at 150A. If left at 150A it trips. If I set it at 90A it seems to hold. We originally started with the Dometic A/C with soft start, same issue. Have since upgraded to the Truma A/C. Understand this doesn’t affect the charging side of the problem. I did open a ticket right after I bought it. Oliver sent a new Opifuse saying it must have been bad. Opened a second ticket but the issue goes unresolved. Is it possible the replacement Optifuse is bad? Any ideas? Thanks! Hull #1238 - Legacy Elite II, TB. TV 2017 Tundra TRD.
John Dorrer Posted June 18, 2025 Posted June 18, 2025 (edited) 9 hours ago, aaronorange said: I have the Xantrex 3000 in a 2022 E2 w/390ah Lithionics. The 300A Optifuse continues to trip. This happens when the battery charger is charging while on shore power. Or when I run the AC at around 1000 ish watts on the inverter, it will typically throw an error 20 in that case as well. It seems to do short runs on the microwave oven (1 to2 min ok, haven’t tested long run times). As far as the inverter charger setting Oliver requires the Charger Current set at 150A. If left at 150A it trips. If I set it at 90A it seems to hold. We originally started with the Dometic A/C with soft start, same issue. Have since upgraded to the Truma A/C. Understand this doesn’t affect the charging side of the problem. I did open a ticket right after I bought it. Oliver sent a new Opifuse saying it must have been bad. Opened a second ticket but the issue goes unresolved. Is it possible the replacement Optifuse is bad? Any ideas? Thanks! On our 2022, it tripped day 2 after pick-up. Oliver told me how to reset it. 2 months later it happened again and Oliver sent a new one. For 2 years no issues. I was having problems late in 2024, and Jason E. looked at it at the Texas Rally and it was in Oliver for service this past February. It was determined the inverter breaker was bad. Oliver switched to a new fuse system and didn't have any of the breakers and couldn't get one. I replaced the breaker a month ago and even ordered a back-up. When I went to remove the old breaker (all power off, solar, inverter breaker manually tripped and the 3 Lithonics batteries), I found the nuts on the breaker posts loose. I also found the flat cable ends pitted, apparently due to loose connections and apparent arching. I sprayed these ends with a conductivity product. When it dried I installed the cables using Locktite Green per Jason E. This appears to be my issue for not checking all my electric connections annually. It is possible there was nothing wrong with the breaker, just a loose connections. Since I bought a new one, I didn't want to take any chances. I guess it is possible your replacement was bad. I would continue to work with Oliver. I would turn off everything and make sure the nuts are torqued properly. Did you use Locktite? Jason said Green was the best. Edited June 18, 2025 by John Dorrer Updated Comment John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
aaronorange Posted June 18, 2025 Author Posted June 18, 2025 Thank you! Yes, I have triple checked all the connections for tightness. Including the post inside the inverter. I’m really puzzled as to reason why this keeps happening. Because of heat issues and potential fire I don’t want to just start changing parts. However if I get the okay from Oliver or Xantrex I will replace the Optifuse/breaker with a fuse. I would rather have it in the battery compartment for access. It’s always a pain to get under the bed to reset the Optifuse. Especially in the middle of the night. I was at the Texas rally last year and will be there this year as well. When we left last year we went to the factory to switch out our noisy Dometic A/C for the Truma. I asked the other Jason about my Optifuse issue and he said he had never heard of such a problem and had no solutions. We are headed to Murfreesboro for a ceramic coating this summer so maybe I will try stopping by Oliver. 2 Hull #1238 - Legacy Elite II, TB. TV 2017 Tundra TRD.
John Dorrer Posted June 18, 2025 Posted June 18, 2025 4 hours ago, aaronorange said: Thank you! Yes, I have triple checked all the connections for tightness. Including the post inside the inverter. I’m really puzzled as to reason why this keeps happening. Because of heat issues and potential fire I don’t want to just start changing parts. However if I get the okay from Oliver or Xantrex I will replace the Optifuse/breaker with a fuse. I would rather have it in the battery compartment for access. It’s always a pain to get under the bed to reset the Optifuse. Especially in the middle of the night. I was at the Texas rally last year and will be there this year as well. When we left last year we went to the factory to switch out our noisy Dometic A/C for the Truma. I asked the other Jason about my Optifuse issue and he said he had never heard of such a problem and had no solutions. We are headed to Murfreesboro for a ceramic coating this summer so maybe I will try stopping by Oliver. Oliver is no longer using a breaker. They have switched to a large, more dependable fuse. Not sure what the cost would be to switch to the new system. Jason E. suggest I stick with the breaker. I'm going to watch things closely. 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Geronimo John Posted June 18, 2025 Posted June 18, 2025 (edited) There are several clamp on multi-meters that owners have suggested as cost effective and easy to use. Chasing breaker trips without knowing what the amp draw and breaker resistance is a really difficult task. John Davies recommend this one many years ago. It has been updated several times, but the line is still well received. I have purchased four of them for my boys and brother. Highly recommend. That said, if you google the topic, you'll find a whole bunch more of them that are popular with this group. GJ Edited June 18, 2025 by Geronimo John TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
rich.dev Posted June 19, 2025 Posted June 19, 2025 9 hours ago, aaronorange said: Thank you! Yes, I have triple checked all the connections for tightness. Including the post inside the inverter. I’m really puzzled as to reason why this keeps happening. Because of heat issues and potential fire I don’t want to just start changing parts. @aaronorange Also make sure the order in which your terminals, fuses, washers etc. are connected are correct, if not that can also mess up the flow of power. Here’s a great video by Nate from Explorist Life explaining the correct order. 1 1 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Ronbrink Posted June 19, 2025 Posted June 19, 2025 20 hours ago, aaronorange said: However if I get the okay from Oliver or Xantrex I will replace the Optifuse/breaker with a fuse. My 2020 LEll did not come with a battery cutoff switch and thus, the stock 200A breaker leading to the Xantrex 2000 serves that purpose in my situation. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Geronimo John Posted June 19, 2025 Posted June 19, 2025 8 hours ago, Ronbrink said: My 2020 LEll did not come with a battery cutoff switch and thus, the stock 200A breaker leading to the Xantrex 2000 serves that purpose in my situation. Likely only to a point. For all the trailers I have seen, there are other power feeds off your batteries that would not be disabled without also making them safe. That 200 amp "breaker" likely is in the path of the 4/0 cable to your inverter. That "breaker" would be a bit odd as normally it is a "FUSE". But I seem to have heard that on a few units they did use a breaker. If it's a breaker, then conversion to a 300 amp fuse would be beneficial for several reasons as stated by others on similar threads. GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ronbrink Posted June 19, 2025 Posted June 19, 2025 (edited) 4 hours ago, Geronimo John said: That 200 amp "breaker" likely is in the path of the 4/0 cable to your inverter. That "breaker" would be a bit odd as normally it is a "FUSE". But I seem to have heard that on a few units they did use a breaker. If it's a breaker, then conversion to a 300 amp fuse would be beneficial for several reasons as stated by others on similar threads. You are correct, the 200A breaker is used to turn off battery feed to the inverter and thus, all AC circuits. There is also a second 60A breaker that turns off all DC loads. Between the two, the battery bank is isolated. Also, when I upgraded to LFPs a 250A ANL fuse was installed in the battery bay on the positive lead from said bank (See pics). For major disconnect, I have removed the fuse from the bus. Finally, with mention of a 300A fuse, should the 250A be replaced for optimum protection? Edited June 20, 2025 by Ronbrink 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Geronimo John Posted June 19, 2025 Posted June 19, 2025 5 minutes ago, Ronbrink said: Finally, with mention of a 300A fuse, should the 250A be replaced for optimum protection? If you are using a 2,000 watt inverter no. If you are using a 3,000 watt inverter.... personally I would buy a 300 amp fuse for spare parts. Most of us are not likely to be running the inverter hard enough to blow it. But it is possible with my wife firing off her 1500 watt hair dryer the same time I decide to nuke my coffee and the A/C compressor all three together decide to "Make My Day". Not likely, but Mr. Murphy is a permeant resident for some of us. But with power management that we all normally do it likely will be years before Mr. M says bye bye to your 250 amp fuse. 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ronbrink Posted June 19, 2025 Posted June 19, 2025 24 minutes ago, Geronimo John said: If you are using a 2,000 watt inverter no. Thanks for your input, the Xantrex 2000W was the only upgrade option in 2020. I’ll keep your fuse upgrade in mind if ever a 3000W dominates my dreams. As for Mr. M, he comes around but I won’t let him stay long! 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
aaronorange Posted June 20, 2025 Author Posted June 20, 2025 On 6/18/2025 at 5:07 PM, Geronimo John said: There are several clamp on multi-meters that owners have suggested as cost effective and easy to use. Chasing breaker trips without knowing what the amp draw and breaker resistance is a really difficult task. John Davies recommend this one many years ago. It has been updated several times, but the line is still well received. I have purchased four of them for my boys and brother. Highly recommend. That said, if you google the topic, you'll find a whole bunch more of them that are popular with this group. GJ At the time it tripped it was pulling 88 amps. This happened today, stopped at a rest stop for lunch and thought I’d give it another try. The A/c ran a couple minutes and then tripped. You’d think it would until the batteries were too low. Incidentally the batteries were at 100%. I charge them at 90A instead of the posted 150A. If the 150A charge setting is used it also trips the 300A Optifuse. Hull #1238 - Legacy Elite II, TB. TV 2017 Tundra TRD.
Geronimo John Posted June 20, 2025 Posted June 20, 2025 4 hours ago, Ronbrink said: You are correct, the 200A breaker is used to turn off battery feed to the inverter and thus, all AC circuits. As I know you know, but I think for clarification: Yes so long as you are not even for a second hooked to shore power, the 200 amp does as you said. It stops the flow of power to the AC circuits. But if shore power is restored, even just for a few milli-seconds, the auto transfer switch sees shore power, and transfers power to the 120 circuits. Hence killing the 200 amp breaker with cycling of 120V shore power does not make the 120V system "Safe". Such has occurred when one of my unit's generators simply ran out of diesel. The electrician was inside checking voltages and the Sgt refueled and restarted the unit. Fortunately the electrician had one hand in his pocket and the other in the panel. He was pretty upset with Sgt, but was not injured. My lesson: LOTO and Strict Key control. For us, it is just please also disco the short power. cord flip the breakers where needed, and be sure that your inverter is also disabled. 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Geronimo John Posted June 20, 2025 Posted June 20, 2025 (edited) 40 minutes ago, aaronorange said: At the time it tripped it was pulling 88 amps. This happened today, stopped at a rest stop for lunch and thought I’d give it another try. The A/c ran a couple minutes and then tripped. You’d think it would until the batteries were too low. Incidentally the batteries were at 100%. I charge them at 90A instead of the posted 150A. If the 150A charge setting is used it also trips the 300A Optifuse. It sounds like you may have either a high resistance connection. It would be heating up a lot. A thermal sensor (Like we use for checking brake temperatures) would spot that easily. Or you have loads that are not on your view screen yet. For example: Like your litho's are force charging the TV AGM's. Like the hot water heater switch is on 120V (Switch lower left hand corner of the hot water heater (outside). With your Clamp on Amp meter/Multi Meter you can trace the current flows and voltage drops to see where all that energy going. You can also check the accuracy of what you Gizmology is telling you. GJ Edited June 20, 2025 by Geronimo John 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
aaronorange Posted June 22, 2025 Author Posted June 22, 2025 On 6/19/2025 at 7:54 PM, Geronimo John said: It sounds like you may have either a high resistance connection. It would be heating up a lot. A thermal sensor (Like we use for checking brake temperatures) would spot that easily. Or you have loads that are not on your view screen yet. For example: Like your litho's are force charging the TV AGM's. Like the hot water heater switch is on 120V (Switch lower left hand corner of the hot water heater (outside). With your Clamp on Amp meter/Multi Meter you can trace the current flows and voltage drops to see where all that energy going. You can also check the accuracy of what you Gizmology is telling you. GJ When the 300A Optifuse trips only the A/C was running nothing else is running except maybe an LED cabin light. This has been an issue since day one. It pretty much forces me to use shoe power all the time. Any (inverter) microwave run time longer than 2min will also trip the thermal breaker. I have had it to the Oliver service center but Jason said he had never heard of the issue and did not have a solution. I don have a thermal temp gun but It is very hot to the touch both the battery wire and 300A Optifuse. This was a factory installation and there have been no modifications. 2022 built. Hull #1238 - Legacy Elite II, TB. TV 2017 Tundra TRD.
jd1923 Posted June 22, 2025 Posted June 22, 2025 1 hour ago, aaronorange said: When the 300A Optifuse trips only the A/C was running nothing else is running except maybe an LED cabin light Delete the Optifuse asap (China cr@p) and replace it with a 300A ANL fuse. On a recent post by @John Dorrer I listed Amazon links for the parts required. I have an ANL fuse in line with our Victron inverter and can run the A/C and microwave simultaneously! Not that you’d want to, but it does so without blowing the fuse! You don’t want a breaker for this connection and OTT knows this (finally), now that they’re not using the Optifuse anymore. That’s what Jason should have told you. 1 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Geronimo John Posted June 22, 2025 Posted June 22, 2025 Energy does not simply disappear. It is going somewhere. The wiring in our OTT's is mostly protected wire by wire with loom. I recommend that you: A. Pry the loom open and using your clamp on amp meter, to figure out where all that energy is going. B. Get a thermal meter and use it to do follow the heat trace of the current flows. If this is technically beyond your abilities, then time to seek out on site assistance. That's about all I can do for you from Hawaii. Good luck. GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
aaronorange Posted June 22, 2025 Author Posted June 22, 2025 2 hours ago, jd1923 said: Delete the Optifuse asap (China cr@p) and replace it with a 300A ANL fuse. On a recent post by @John Dorrer I listed Amazon links for the parts required. I have an ANL fuse in line with our Victron inverter and can run the A/C and microwave simultaneously! Not that you’d want to, but it does so without blowing the fuse! You don’t want a breaker for this connection and OTT knows this (finally), now that they’re not using the Optifuse anymore. That’s what Jason should have told you. Thanks again! Hull #1238 - Legacy Elite II, TB. TV 2017 Tundra TRD.
aaronorange Posted July 22, 2025 Author Posted July 22, 2025 Update, I did eliminate the Tiwan made Optifuse and put in an inline 300 amp ANL fuse. Worked pretty good but the lug ends were heating above 130° (in a few minutes time). I went ahead and replaced the lug ends and the temp on those dropped 30°. Which confirmed my suspicions of bad crimps. Tested the Xantrex charger set to 150 amp as suggested by Oliver, the fuse will quickly heat up to 130° ish. (currently keep it set to 75 amp) When running the Truma AC which pulls 900 to 1200 watts and the fuse will get up around 138° and lugs 95°-112° (10 min. run). Not sure but guess these are normal temps. I had an RV solar technician tell me I could use a 400 amp ANL fuse since it uses 4/0 wire between the battery and inverter. I will test temps and research the use of a 400 amp fuse. Oliver sent me an email suggesting I remove the Opifuse and replace with a disconnect switch. I’m apprehensive about sleeping above an unfused wire. Thanks for all the suggestions. 1 Hull #1238 - Legacy Elite II, TB. TV 2017 Tundra TRD.
