Ronbrink Posted July 24 Posted July 24 10 hours ago, jd1923 said: I would not have an 1/2” ID hose. It’s like having a built in water restrictor! You want 5/8” with 3/4” fittings, min. Commercial hoses are 3/4” end-to-end. Per Ron, get the gray if you gotta have this brand! Since the 1/2” hose is only used for washing/cleaning, it is fitted with an adjustable spray nozzle which provides adequate stream volume for its purpose. To ensure max pressure, I have a ‘Y’ fitting at the spigot, thereby enabling full CG water pressure for this setup and use of a typical water pressure regulator valve for the Oliver’s water supply. You are correct however, in recommending the larger diameter hoses where max volume is of more benefit to the need. That said, it is important to use larger diameter fittings to prevent flow restrictions; ELEY commercial duty hose QC sets are 3/4” full-flow and designed for standard 3/4” GHT hoses, faucets and watering tools. Here’s a pic of my spigot and Oliver connections. 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Ronbrink Posted July 24 Posted July 24 On 7/21/2025 at 10:24 AM, Teaney Hull 292 said: About to buy a 50 foot drinking hose and seeing some HORRIBLE Amazon reviews. What has worked for you? Thanks Gary Hull 292 You would be better off buying two 25’ hoses, most CG spigots are near the campsite. You can then connect the two if a longer length is needed. When storing my “drinking” hoses, I connect to ends to ensure cleanliness next use. 3 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Patriot Posted July 24 Posted July 24 @Teaney Hull 292 Gary, When all else fails….😄 1 2 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️Recent Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderators mossemi Posted July 24 Moderators Posted July 24 @Patriot It looks like you had all of the latest technologies growing up! 😉 Mossey 3 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
johnwen Posted July 24 Posted July 24 34 minutes ago, mossemi said: @Patriot It looks like you had all of the latest technologies growing up! 😉 Mossey Mike, I got me one of those after Hurricane Hugo...worked great until the next hurricane came along (7 years later) and hooked it back up on top of the pipe. That's when I found out about the leather gasket. Dried and shriveled and beyond repair! John 1 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
Galileo Posted July 25 Posted July 25 On 7/23/2025 at 8:38 PM, jd1923 said: I would not have an 1/2” ID hose. It’s like having a built in water restrictor! Unless you can engineer and build your water system with large-bore plumbing end-to-end, the 1/2” ID hose isn’t going to affect your water flow much - if at all. The typical “hose Bibb” all of us hook up to a campgrounds are usually of the style shown in the attached picture - with an internal restriction of about 1/3” - so using a half inch diameter hose isn’t gonna slow down you water flow. If you look at your household plumbing, you almost certainly have 1/4” supply lines to your sinks and toilets. It doesn’t matter if your PEX, PVC, Copper, or galvanized iron piping is 3/8”, 1/2”, or even 3/4” - it all goes through those 1/4” supply lines before it hits the faucet. Most aerators and shower heads have far smaller offices - like 1/8”. Back when we had the farm, I replaced all the hose bibs with 3/4” ball valves and GHT adapters. I wanted my irrigation systems to have maximum flow. For that matter, I also liked to be able to fill a 5 gallon bucket (which small farms are built around) in under a minute. In that case, a 1/2” hose would be the choke point. With RVs, we don’t wanna have a lot of flow. Our holding tanks are the limiting factor. Unless you’ve reworked your water system, I’m pretty sure the piping in the Oliver is all 1/2” PEX. So there’s your restriction. I suppose inquiring minds who just gotta know for themselves, try an experiment by timing how long it takes to fill a bucket with a 1/2” vs a 3/4” hose. Unless you’re attached to a spigot with a ball valve (and no choke points upstream) I’ll bet your fill times will be virtually the same regardless of your hose. The case FOR the 1/2” hose is that 50 feet of 1/2 hose is smaller and lighter than 50 feet of 3/4” hose. In the world of having to tote stuff with you - that’s a bigger deal than flow rate. 1 1 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Teaney Hull 292 Posted July 25 Author Posted July 25 On 7/24/2025 at 8:57 AM, Ronbrink said: You would be better off buying two 25’ hoses, most CG spigots are near the campsite. You can then connect the two if a longer length is needed. When storing my “drinking” hoses, I connect to ends to ensure cleanliness next use. I took your advice and bought 2 25 footers. Thanks Gary 2 Gary and Anita Teaney and Ranger 2017 Oliver Elite II Hull 292 2018 Nissan Armada Tampa, FL
Teaney Hull 292 Posted July 25 Author Posted July 25 On 7/24/2025 at 9:44 AM, mossemi said: @Patriot It looks like you had all of the latest technologies growing up! 😉 Mossey My Grandmother had one like this. I learned how to prime the pump at an early age. 2 Gary and Anita Teaney and Ranger 2017 Oliver Elite II Hull 292 2018 Nissan Armada Tampa, FL
Teaney Hull 292 Posted July 25 Author Posted July 25 On 7/21/2025 at 2:23 PM, jd1923 said: Keep in mind, flat hoses and other compact hoses recommended do not work for filling the fresh tank via the boondocking port. Something we do often, filling from our extra 35-gal fresh tank in the pickup bed. When pulling water by suction you need a rigid hose, one that will NOT shrink or flatten. We go with the standard Camco hose. 35 ft is what's needed to get from our truck to the boondocking inlet when hitched. I had a 25' hose so purchased a 10' hose which is great alone when we have water hookup at a campground. They are firm and many complain about rolling them up. I roll in big loops and it fits in the Oliver Trunk and unwinds nicely. Good reviews on this Amazon item: https://www.amazon.com/Camco-TastePURE-Heavy-Duty-Construction-22843/dp/B004VHXS20/?th=1 Thanks Gary Gary and Anita Teaney and Ranger 2017 Oliver Elite II Hull 292 2018 Nissan Armada Tampa, FL
jd1923 Posted July 25 Posted July 25 37 minutes ago, Galileo said: The typical “hose Bibb” all of us hook up to a campgrounds are usually of the style shown in the attached picture... We generally see more of the frost-proof hydrant style (an example pictured below) which do not have these restricting smaller orifices. I have seen some launch water 30 feet though the air, even through our filter system which also has 3/4" fittings. I've measured over 5 GPM flow rates at many campsites, but I've seen as bad as 0.5 GPM rates at others, waiting forever to fill our FWT! We fill the fresh tank and run from the fresh tank since we are more often boondocking and are not used to using the City Water connection. We just want to fill the empty FWT quickly! I promise you, the fresh tank can be filled faster with a greater diameter hose at many hookups. Also, our 35-gallon extra tank onboard the TV has 3/4" ID fittings at the tank outlet. If I was to draw water with a 1/2" hose it would take considerably longer. 50 feet of 1/2" hose will create more back-pressure, working the pump harder, than a single point orifice or the 5 ft of 1/2 plumbing internal to the Oliver to the pump. And if I was to try the hoses suggested here that compress or flatten, pulling water through the boondocking inlet would not work at all! 🤣 Nice and handy, just not usable for our needs! 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
