DunnYet Posted July 26, 2025 Posted July 26, 2025 Would appreciate advice from those that have modified the fiberglass on their Ollies. We are considering a fridge that is about 3 inches taller than the current Isotherm. To meet the install size I will need to do one of the following: Go up - leaving very little fiberglass below the grey countertop. Go down - requiring removing the current fridge support structure. Combine the two. My concern is removing so much material at the top - will that lead to unintended flex and cracking in the fiberglass under the countertop? Is there a way to add strength back to that area? If down, do I need the flat surface or just use square stock to build back up? Any advice from those that have removed that fridge support structure - I could not figure out where to start. If both, how much should I target to leave at the top? And finally, what is the best way to cut fiberglass out of an area like this? Any and all tips would be greatly appreciated. Photos of the current situation attached. Current: 2023 Oliver Elite II - Hull #1364 "Reset 2.0" (Second Owner) Tow Vehicle: 2023 Ford F-150 XLT 3.5L EcoBoost /w 3.55 axle and Max Tow Package "SIlver" Original: 2022 Oliver Elite I - Hull #1030 "Reset" (Sold) Original Tow Vehicle: 2022 Subaru Ascent "Blue Moose" Home Base: Duncanville, TX
jd1923 Posted July 26, 2025 Posted July 26, 2025 1 hour ago, DunnYet said: We are considering a fridge that is about 3 inches taller than the current Isotherm. To meet the install size I will need to do one of the following: Go up - leaving very little fiberglass below the grey countertop. Go down - requiring removing the current fridge support structure. Combine the two. Cool project! What model fridge are you installing? In our Oliver, I replaced the vent under the bed with a filter housing. I had to make the opening a little wider in both directions and found the fiberglass cut easily with my DeWalt cordless jigsaw using a fine steel blade (see pics). Cutting the fiberglass should be easy as long as the base of a jigsaw can fit and sit level on the taped fiberglass. You may have to use a sawzall in the corners which is not as easy to control and cut in a clean straight line. Looks like there is ducting or something under the fridge base, so you may not get a full 3" there. I would work below first. Not much room up above either! You will likely need to "combine the two" approaches. Maybe make the base about 2" lower and cut 1" in the fiberglass above. Keep us posted! Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
DunnYet Posted July 26, 2025 Author Posted July 26, 2025 (edited) @jd1923 planning on getting the Dometic NRX 130 C that will be available in late August. Really like the freezer design (plus the fact that you can remove the freezer entirely if you wanted to use it as a fridge only and use a portable freezer. It’s 12/24 volt only, which should not be a problem as it will run off the batteries when rolling and when on shore power will still run off the batteries. From the tech notes it seems to be very power efficient as well. It’s just taller than the current Isothem 130 🙂 Thanks for the tips!! Well - I went and pulled the link to the NRX 130 C and forgot to paste it - 🙄 https://www.dometic.com/en-us/outdoor/boat/boat-refrigerators/boat-refrigerators/09-0904-090426-090426021-333336?v=9620017097 Edited July 26, 2025 by DunnYet Would forget my head if it was not attached. 1 Current: 2023 Oliver Elite II - Hull #1364 "Reset 2.0" (Second Owner) Tow Vehicle: 2023 Ford F-150 XLT 3.5L EcoBoost /w 3.55 axle and Max Tow Package "SIlver" Original: 2022 Oliver Elite I - Hull #1030 "Reset" (Sold) Original Tow Vehicle: 2022 Subaru Ascent "Blue Moose" Home Base: Duncanville, TX
Ronbrink Posted July 27, 2025 Posted July 27, 2025 18 hours ago, jd1923 said: found the fiberglass cut easily with my DeWalt cordless jigsaw using a fine steel blade (see pics). Cutting the fiberglass should be easy as long as the base of a jigsaw can fit and sit level on the taped fiberglass. 20 hours ago, DunnYet said: And finally, what is the best way to cut fiberglass out of an area like this? I used my Fein oscillating multi-tool to easily make cut outs for additional receptacle outlets. 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
jd1923 Posted July 27, 2025 Posted July 27, 2025 3 hours ago, Ronbrink said: I used my Fein oscillating multi-tool to easily make cut outs for additional receptacle outlets. Good idea! My son has one of those. I don’t have too much experience but an oscillating tool should work well to square new corners and where a jigsaw would not fit. 1 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
CRM Posted July 27, 2025 Posted July 27, 2025 22 minutes ago, jd1923 said: Good idea! My son has one of those. I don’t have too much experience but an oscillating tool should work well to square new corners and where a jigsaw would not fit. They're the Vise Grip of the power tool world. Can't believe you don't own one! 1 2 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
DunnYet Posted August 6, 2025 Author Posted August 6, 2025 (edited) Not going to be one of those people who never closes out the thread… My adult supervision found out that the Dometic was not going to be available any time soon. (She really wants a working fridge.) She also had concerns about a situation where I was going to be in proximity to Hull 1364 wielding a jigsaw or an oscillating tool. (And I don’t even have an oscillating tool, so now I’ve lost my (current) excuse to get one.) So - after all my pledging to never own another Isotherm, I am now the proud owner of a new isotherm with a damaged in shipping door. At least they are going to replace that. Hopefully the information in this thread will be helpful to others. Watch for a new thread asking the smarter than me people on this forum questions about how to make my new Isotherm (which because of supply chain issues is 12v only) operate on shore power. 🙂 Edited August 6, 2025 by DunnYet Still can’t get the new hull number in my head. 1 1 Current: 2023 Oliver Elite II - Hull #1364 "Reset 2.0" (Second Owner) Tow Vehicle: 2023 Ford F-150 XLT 3.5L EcoBoost /w 3.55 axle and Max Tow Package "SIlver" Original: 2022 Oliver Elite I - Hull #1030 "Reset" (Sold) Original Tow Vehicle: 2022 Subaru Ascent "Blue Moose" Home Base: Duncanville, TX
Moderators SeaDawg Posted August 8, 2025 Moderators Posted August 8, 2025 On 8/5/2025 at 9:42 PM, DunnYet said: Hopefully the information in this thread will be helpful to others. Watch for a new thread asking the smarter than me people on this forum questions about how to make my new Isotherm (which because of supply chain issues is 12v only) operate on shore power. 🙂 Your old 110/12v probably actually operated on 12v, just stepped down converted power. You'll likely never notice the difference. 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
