2008RN Posted July 20 Posted July 20 Question for the more technical people. Now that I have the Fridge exhaust fans in place, I know to use it when on propane in hotter weather. Would it be beneficial to use it on 120V and/or 12V in hotter weather? Maybe make the fridge more efficient and take a little load of off the compressor from running as much? Would this maybe extend the life of the fridge? Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
jd1923 Posted July 20 Posted July 20 3 hours ago, 2008RN said: I know to use it when on propane in hotter weather. I run our fridge exhaust fan when it's hot regardless of how it's powered; AC, DC or LP. LP runs a little hotter but the real heat is generated from the cooling. We choose between DC/LP based solely on battery SOC. Of course, when we're plugged in we switch to AC. I can notice the heat coming out of the top vent when entering the cabin which reminds me to turn the fan on. Living in the SW, if the sun is on the entrance wall, turn on the fan. We also have Ruuvi temp sensors in fridge and freezer compartments to monitor cooling. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Ronbrink Posted July 20 Posted July 20 8 hours ago, 2008RN said: Would it be beneficial to use it on 120V and/or 12V in hotter weather? I operate mine on the temperature auto mode regardless of the source of power/fuel being used. It’s generally set at 85°/50% fan speed, but in extreme heat I will bump the fan speed up. The evaporator fin fan in the fridge is turned on to run continuously whenever the unit is in use. These external and internal fans will indeed improve the cooling efficiency and likely extend the life of the unit. However, when stationary it is imperative to have the 3-way perfectly level to ensure proper cooling. Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
