taylor.coyote Posted November 17 Posted November 17 (edited) We are planning to spend time at elevations in New Mexico that could range from lows of 20 +/- degrees at night and 40's to mid 50's in the day time. We will be boon-docking and running the heat 45-50 ish at night. We have camped with temperatures in the mid teens for a night or two but never consecutive days running . My question: should we be concerned about winterizing the water system when the temperatures are freezing at night and well above freezing during the day? Edited November 17 by taylor.coyote typo 2016 Legacy Elite II, Twin Beds, Hull #124 Tow Vehicle: 2019 Ford F250 4x4 / Short Bed / Crew Cab / 6.7 Diesel Fieldbrook, Ca
Moderators topgun2 Posted November 18 Moderators Posted November 18 I believe that there are simply way too many factors that should be considered for just about anyone to give you any kind of reasonable answer to your question. Wind, certainty of weather forecast, your own risk tolerance, how much time will you spend in the camper, is it sunny out and will you be camped in the sun, how much access will you really need to those water related items that are located towards the outer hull (i.e. outside shower, black tank flush, city and fresh water tank inputs), etc., etc.. Even though there are a number of posts right here on the Forum from owners that have experienced conditions similar to what you are anticipating, there are virtually never two that are exactly alike. For what its worth, I tend to be a bit more cautious in regards to situations like this. But, I'm from a backpacking background and many time travel alone. It is a bit easier only having to take care of one human versus two (or more). A couple of milk jugs filled with water and another one or two for drinking/cooking/bathing and I'm set. That sure beats virtually any time wasted on worrying about exactly what the temps are going to do and/or repairing damage caused by a frozen pipe. Having said this, I'd guess that you will be OK - particularly if you have the ability to make sure that some "heated" air gets to the rear drivers side and under the forward dinette seat of the Ollie. Obviously this is easy to do with the dinette seat but if someone is sleeping on the driver's side bed, it might take a bit of good positioning of a fan or small heater in order to assuage your worries. Bill 1 5 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Rivernerd Posted November 18 Posted November 18 18 hours ago, taylor.coyote said: should we be concerned about winterizing the water system when the temperatures are freezing at night and well above freezing during the day? For what it's worth, we spent a couple of nights in New Mexico and Colorado in November 2022 when temps dropped as low as 9 degrees F. We did not winterize the water system, so we could continue to use it. We pulled the outside faucet inside. We placed digital thermometers in the "underbelly" of our Elite II near the outside faucet in the rear and under the front dinette seat. We kept our Truma Varioheat furnace running at 70 degrees F all night, but not during the day when we were on the road and daytime temps were above freezing. We also kept the antifreeze attachment in our Truma water heater activated. The digital thermometers confirmed that the temp did not drop below 32 degrees F in the "underbelly" even when outside temps were as low as 9 degrees F. 1 4 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
Patriot Posted November 18 Posted November 18 (edited) It sounds like a fun trip! 😊 We have had limited experience camping in below freezing temperatures, and not in the mid teens as you mentioned. Our temps were in the mid to upper 20 degree range and only for a short couple of hours before sunrise. Our Oliver was not winterized and we had no issues with frozen water lines. We always make it a point to not to connect to city water with a freeze warning and use our on board water. We don’t drink from our fresh water tank, and always carry plenty of gallon jugs for drinking water. Our typical sleeping temp is 61d and we run a dehumidifier which keeps our interior just about perfect at 55% humidity. We always leave the bathroom door open to keep warm air circulating. As @topgun2 mentions there are lots of variables to consider. I think you will be fine just stay weather aware for sure. Safe travels and let us know how your trip goes! Edited November 18 by Patriot 1 2 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
taylor.coyote Posted November 18 Author Posted November 18 Thanks for sharing. I would agree many variables will be in play. Rivernerd, how do you pull the outside faucet inside? Your trailer is much newer (about 1,000 trailers after mine), maybe you have different plumbing. I have seen where people layer in additional insulation between the hatch door and the outdoor faucet. In general, our experiences is as you have described. Our Oliver can handle a few hours of below-freezing temperatures each night, provided you heat the interior and monitor the driver's side hull. I was a hardcore winter camper in my youth but we will head for the barn if the temp is a hard freeze day and night 3 2016 Legacy Elite II, Twin Beds, Hull #124 Tow Vehicle: 2019 Ford F250 4x4 / Short Bed / Crew Cab / 6.7 Diesel Fieldbrook, Ca
BigTexas Posted November 19 Posted November 19 As others have noted, these trailers do very well in cold weather. So I think you'll be fine as long as you have heat. We traveled to Moab for a January wedding. There were several days on the road where the temp never got above freezing and the trailer was covered in ice when we arrived at our overnight stop. We relied mainly on the internal water tank as the supply hose would freeze. One lesson we learned was to be gentle with the trailer when you arrive. Without heat, some of the plumbing may have frozen while traveling. Give it some time with the heat on to thaw out. I broke the toilet petal once by being impatient, not knowing the flush valve in the back had frozen. I carry extra flush valves but the pedal is not available as a separate replacement part. Not my finest hour. 3 Big Texas – 2018 Elite II, Twin Bed, Hull #306 2024 RAM 2500 6.7L Cummins, Weigh Safe hitch
Rivernerd Posted November 19 Posted November 19 17 hours ago, taylor.coyote said: Rivernerd, how do you pull the outside faucet inside? On our Hull #1291 the sprayer on the outside faucet is threaded onto the supply hose. I screw the sprayer head off the hose, then push the hose through the access hole to the inside of the hull. I then take the sprayer inside, open the driver's side rear hatch, locate the hose and thread the sprayer back onto the hose for cold weather storage. 1 4 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
ChristianD Posted November 19 Posted November 19 We're planning a trip to Yosemite soon and I picked up a heated water hose. The forecast is calling for lows just below freezing and it will be a just in case we need to fill our tank. I don't think I'm going to leave it attached, at night, but from what I've read, the heated portion is for that scenario. We'll keep our furnace on at night since it runs quiet, and run our rooftop AC unit heat during the day, so I don't use up all the propane and can save that just for sleeping hours. I also bought a dual voltage plug in Vornado heater, which has a low setting that I plan to run at night since we'll be hooked up to shore power most of our trip. This will be our first trip during colder weather, so I may be over doing it, but wanted to be prepared, just in case it's needed. 1 3 Christian, Katie and Benny (our Maltese) | Cave Creek, AZ | 2019 LE II #448 | '25 GMC Yukon
BigTexas Posted November 20 Posted November 20 22 hours ago, Rivernerd said: On our Hull #1291 the sprayer on the outside faucet is threaded onto the supply hose. I screw the sprayer head off the hose, then push the hose through the access hole to the inside of the hull. I then take the sprayer inside, open the driver's side rear hatch, locate the hose and thread the sprayer back onto the hose for cold weather storage. Ok, this is brilliant. Don't know why I didn't think of this. I've already had to replace the sprayer head once due to freezing. (Where's the head slapping icon?) 1 1 Big Texas – 2018 Elite II, Twin Bed, Hull #306 2024 RAM 2500 6.7L Cummins, Weigh Safe hitch
Moderators topgun2 Posted November 20 Moderators Posted November 20 9 minutes ago, BigTexas said: (Where's the head slapping icon?) 1 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
taylor.coyote Posted November 21 Author Posted November 21 (edited) big tex, you have likely saved me from head slapping and turning the sprayer into an ice cube Edited November 22 by taylor.coyote 2 2016 Legacy Elite II, Twin Beds, Hull #124 Tow Vehicle: 2019 Ford F250 4x4 / Short Bed / Crew Cab / 6.7 Diesel Fieldbrook, Ca
