jd1923 Posted July 24 Author Posted July 24 On 1/13/2026 at 11:58 PM, jd1923 said: Looking at the specs I see a 3.25" difference (14.5" - 11.25" Chill Cube vs. Dometic Penguin 2). My son Adam climbed up the scaffolding and place an 8' 1x3" on top of the A/C unit hanging off to the curbside. I measured the height and did not believe the number, so I measured it in the same way off the streetside, same number! I measured exactly 9' 8.5" on BOTH sides! Let's call it 9' 9" to top of the Chill Cube A/C on hull #113. OTT advertises the Oliver to be 9' 8" top of A/C! How is that? I put an A/C at least 3" taller than OEM! Crazy if this could fit in a garage with a 10 ft door. Chris said, "Who cares how tall it is? It's quiet! 😂 @Boudicca908, the above is quoted from an earlier post of mine, page 1 of this thread. This was measured with Alcan Springs and the older 16" wheels which are 1/2" taller than the newer 15" wheels. I would say measure the height of your hull, to the top of your Dometic P2 A/C and add 3", or 4" to be safe. 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
ScottyGS Posted October 2 Posted October 2 Hey Everyone, Hull # 145 2016 LE2 Furrion Chill Cube A/C upgrade 10/1/2026 We finally gave the heave ho to the noisy jet engine Penguin 2 air conditioner and installed the Furrion Chill Cube with heat pump. Installation was done at Miles RV in Hendersonville NC. Performed at under two hours of shop labor and included the installation of a Lux Pro thermostat to control the LP heater. When installing the Furrion the heat and A/C will operate independently so a new thermostat will be required. For reasons unknown to me, the Dometic thermostat that used to run both will not work with just the heat. The Lux Pro works fine and shows the current temp in the display. You have to turn the fan from auto to on and the heat from off to on and then control heat with the up / down setting for temp. After that it cycles on and off normally. The Furrion A/C is controlled independently with either the remote or the buttons on the air distribution box. This concerned me quite a bit, but in talking with the shop supervisor, he said his tech guys would have no problem. And, they didn't. Why I chose the Furrion A/C: Two main reasons... 1.) NOISE and 2.) Energy use. The main difference between the Furrion and other units is how the compressor / fan combination operate. The fan is not a round propeller type, it is a cylinder. That may be one of the reasons the A/C is about 4” taller than other comparable units. Our height went from 9'8” to 9'11”.... still under 10 feet but will avoid underpass's that are less than 10-1/2' in height. The compressor is variable speed... that means instead of the compressor tuning on and off when holding temp, it will, well... vary in speed. We are planning on a 900 ah lithium upgrade in November and expect the run time on this a/c to be measured in days. JD has reported on very good run times and I expect the same type of performance. Testing so far has been plugged into a 20a outlet with moderate temperatures. The 20a outlet is not a problem because the Furrion does not require a “soft start” add on. It's soft start by design. It also has what they call a “gear” function that allows you to set the power consumption at 50%, 75%, and 100%. All tests have been done at 50%. There is quite a bit of difference in noise depending on the setting. When the fan is set to auto, and the ambient and set temp are 8-10 degrees apart, it can be loud. The fan has a turbo mode and when that kicks in it's up about 65+ db. However, when you set the fan to low and the ambient-set difference is 4-5 degrees it is whisper quiet at about 52db. Very easy to hold a conversation. We were in the trailer with low fan and the A/C dropped the temp 5 degrees in about a half hour. All in all, I expect that it will be noisy when first turned on and trying to cool down the trailer from high temps to reasonable ones. Then when holding that reasonable temp it will be very quiet. Oh... and HEAT... I set the heat on 85 degrees with the ambient temp at 70. The unit took a short while to start, but when it did, the noise was very low at 51db and the air coming from the vents was nice and warm. The gear function does not work when heat is selected, so I did not leave it on very long. I have carried a ceramic cube heater and a Buddy Jr. heater when camping in cold temps as back up in case there was a problem with the heat. After the battery upgrade, I don't think I will need to do that any longer. There are some other nice features. There is a timer that can be set to either turn the unit ON or OFF. Nice if you are arriving back at camp after a hot day exploring or to set to turn on an hour or so before you arrive at your campsite. Our "Flying Sea Turtle" turned 10 years of age (notice I did not use the word "old") this summer and once we have the lithium upgrade done we will be set up for the next ten. Thanks again to John for his extensive testing and reporting on this unit. Furrion owes a commission on my unit. All for now... Happy Camping, Scotty 2 4 1 Gregg & Donna Scott and Missy the Westie - The Flying Sea Turtle - 2016 Hull # 145 2024 Nissan Titan XD - Western NC
