If you have Lithionics batteries, you should check their Firmware.  Mine was three versions outdated!  The latest version of Firmware includes upgrades and corrections to the Battery Management System (BMS) and State Of Charge (SOC) accuracy.
The Firmware can be checked and updated with the Lithionics Application.  Go to settings and pick “Firmware Update.”  Then press the “Flash Firmware” button if you don't have the latest version.  Be sure to up-date each battery.
IMG_0104.thumb.PNG.f82ac5f590b6b59221790a87c0736c9a.PNGIMG_0106.thumb.PNG.715f1f8eeded7d95dc09f925559ad8c0.PNG
These Lithionics batteries are really top drawer, and priced to boot 😅I happened to come across a video yesterday showing why
Generic Brand X: Typical cylindrical cell. Lots of plastic, zip tied and a BMS bolted on.
Problem: Many weld points, many cells which need to be leveled, plastic construction can have heat issues and doesn't conduct heat. Glued tinker toy construction possibly more prone to issues in a trailer.
Lithionics
Large pouch cells for higher energy density, fewer welds and leveling. Aluminum for head conduction, integrated BMS which per OP has an app and firmware updates. Also they test and there's a lower internal battery impedance. Not to mention extra features like built in heating pad and on/off/status switch
Edited by DanielBoondock
Sierra EV AT4 2026 (max range 500 mile pack)
