aaronorange Posted 11 hours ago Posted 11 hours ago Is it normal to have this large furnace opening blowing under the curbside bed? We seem to be getting excessive hot air blowing out our kitchen drawers and under the bed. The rest of the flex duct looks fine. (The photo shows the large furnace opening directly behind the under bed access port.) Thanks! Hull #1238 - Legacy Elite II, TB. TV 2017 Tundra TRD.
Galway Girl Posted 11 hours ago Posted 11 hours ago That looks like the knockout panel on the furnace is missing . You can seal it with silver furnace tape or find a sheet metal piece to put in place. Please post the pix to oliver as a service ticket! 2 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
aaronorange Posted 2 hours ago Author Posted 2 hours ago Thanks, that’s what I was thinking but didn’t see the knockout in plane site. I’m going to take a mirror to see if it slid under the floor. 😀 We are slowly making our way to Alaska from Arizona. Currently in Idaho and we are definitely using the heater. 🥶⛄️. 1 Hull #1238 - Legacy Elite II, TB. TV 2017 Tundra TRD.
routlaw Posted 2 hours ago Posted 2 hours ago Difficult to tell from the existing picture but it's also possible the duct work has dropped out of the knockout panel. If you haven't already I would move your bed aside, open the hatch from above to make sure the duct has not vibrated loose and onto the floor. 2 Legacy Elite II #70
aaronorange Posted 2 hours ago Author Posted 2 hours ago Thanks, that’s what I was thinking but didn’t see the knockout in plane site. I’m going to take a mirror to see if it slid under the floor. 😀 We are slowly making our way to Alaska from Arizona. Currently in Idaho and we are definitely using the heater. 🥶⛄️. Hull #1238 - Legacy Elite II, TB. TV 2017 Tundra TRD.
aaronorange Posted 1 hour ago Author Posted 1 hour ago routlaw, thanks for checking with us 😀We did look under the bed that’s how we found the opening and the rest of the duct looks secure. I’ll let everyone know what I find once we get parked for the night. Hull #1238 - Legacy Elite II, TB. TV 2017 Tundra TRD.
jd1923 Posted 1 hour ago Posted 1 hour ago (edited) 9 hours ago, aaronorange said: excessive hot air blowing out our kitchen drawers This must mean your ducting is detached from the furnace somewhere, or you have a large hole in the ducting. It's a pain when traveling, but you'll need to get under the curbside bed again to fully diagnose and correct. Most of these furnaces have forced air coming out fore and aft of the furnace. Check there first and then follow the ducting forward. If you can't see it quickly, run the furnace while you have the basement open and you should feel a lot of hot air blowing somewhere! We'll be thinking of you, as you head north and it gets hotter and hotter in Arizona. Have a great trip! 😎 Edited 1 hour ago by jd1923 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
