tbudy Posted July 31 Posted July 31 Has olliver ever added a platform to the hitch side that can support a 500lb motorcycle?
taylor.coyote Posted July 31 Posted July 31 (edited) Don't know of anything to do this job. This said, very few trucks can handle 500lbs of trailer tongue weight + 500lbs motorcycle over the tongue. You might consider a front receiver if you are driving a 3/4 ton or bigger truck and have enough payload after all gear is on board. The EcoHitch Hidden Front Mount Trailer Hitch Receiver - sold at ETrailer has a 1000lbs vertical load on Ford super duty trucks. I drive an F250 and carry a lot of gear on the truck plus the 500lbs of tongue weight, this maxes out my payload. I would need to Jettison 500lbs from the truck's bed to carry 500lbs on a front receiver. If I wanted to carry our normal load on the truck with a trailer in tow and 500lbs on the front receiver, I would need a 1 ton to have enough payload. Edited July 31 by taylor.coyote 1 2016 Legacy Elite II, Twin Beds, Hull #124 Tow Vehicle: 2019 Ford F250 4x4 / Short Bed / Crew Cab / 6.7 Diesel Fieldbrook, Ca
Moderators Mike and Carol Posted July 31 Moderators Posted July 31 13 hours ago, tbudy said: Has olliver ever added a platform to the hitch side that can support a 500lb motorcycle? No. 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
jd1923 Posted July 31 Posted July 31 18 hours ago, tbudy said: Has olliver ever added a platform to the hitch side that can support a 500lb motorcycle? Of course, OTT hasn't but I've also thought about this. I would love to take my Honda dirt bike (250 LBS) when we boondock BLM and FS lands, but hasn't been a priority. Taylor has the right idea; mount it front of the tow vehicle. You can keep an eye on it and adding front weight to a TV helps with overall balance. Front of Oliver, you'd have to remove the doghouse and LP tanks to put the weight further back allow for turning radius. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderator+ ScubaRx Posted August 2 Moderator+ Posted August 2 (edited) Absolutely not. And they never will because of the safety issues. IF you are towing with a real truck (not a 1/2 ton or, most likely, even a 3/4 ton) then the front of your truck is the place for your motorcycle. Edited August 2 by ScubaRx 2 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
