Moderators Wayfinder Posted Wednesday at 07:49 PM Moderators Posted Wednesday at 07:49 PM I'm posting for an anonymous 2017 Ollie owner. This is why we should NEVER leave our trailer with city water on to the trailer. I need to remember this too, or just use fresh water tank with pump off when leaving. He heard water flowing under the bunk when hooked up to city water and found that the 1/2 inch plastic swivel adapter going to the water heater, under the passenger side bunk, had broken off. Easy fix, but only if you had the Pex tools and parts with you. The trailer would have flooded with that much water pressure going into hull. Here are some pics. He also found out why, in his 2017 ollie, he had low hot water pressure (a kink). Time to put a straight and right-angle brass swivel adaptors in my plumbing bag. Spend a few more bucks to save the rig from being an indoor pool. 1 5 1 Chris o-o 2016 Legacy Elite II (demo) - Hull #110 -"Rock'in 110" o-o 2024 Ford F-250 Lariat, 7.3L Godzilla gasser o-o Augusta, Georgia
jd1923 Posted Wednesday at 11:40 PM Posted Wednesday at 11:40 PM (edited) 3 hours ago, Wayfinder said: This is why we should NEVER leave our trailer with city water on to the trailer. I need to remember this too, or just use fresh water tank with pump off when leaving. When leaving the trailer, e.g. a day trip, there are several things we check. One is to be sure the water pump is OFF. Likewise if on City Water I will shut-off our hose connection at the hook-up. LP off at the tanks is also a good idea for safety. If you leave pets in the trailer these things are more important and of course they need cool fresh air! Almost as bad as water leaking into the hull would be leaving an electrical appliance on that could cause a fire. You could trip the breaker at the post. If un-plugged the batteries could run down. As we’re locking up to leave, I’m checking the shunt reading on the app to see that amps in or out is what’s expected. 😎 Edited Wednesday at 11:51 PM by jd1923 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Rivernerd Posted yesterday at 01:49 PM Posted yesterday at 01:49 PM (edited) Helpful post, with great photos. Thanks for the "heads up." It was my understanding that Olivers have scupper holes in the bottom hull that would allow water leaking into the bottom of the trailer to drain, preventing it from becoming a swimming pool. Am I mistaken? Also, did the unfortunate Oliver owner use a pressure regulator on the city water input connector? I now plan to carry a 1/2" brass fitting and 1/2" Pex B rings, with crimper, on our next long trip. Edited yesterday at 01:54 PM by Rivernerd Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
Moderators topgun2 Posted yesterday at 02:44 PM Moderators Posted yesterday at 02:44 PM 52 minutes ago, Rivernerd said: Am I mistaken? Nope - Those silver looking things on the bottom of the trailer are the scupper holes. They actually even draw water vapor out from between the hulls while you are traveling down the road. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators Wayfinder Posted yesterday at 03:37 PM Author Moderators Posted yesterday at 03:37 PM I know what I’m doing soon. 😏 Chris o-o 2016 Legacy Elite II (demo) - Hull #110 -"Rock'in 110" o-o 2024 Ford F-250 Lariat, 7.3L Godzilla gasser o-o Augusta, Georgia
Geronimo John Posted 19 hours ago Posted 19 hours ago 19 hours ago, jd1923 said: This is why we should NEVER leave our trailer with city water on to the trailer. I need to remember this too, or just use fresh water tank with pump off when leaving. Good thoughts for sure. I take them a step further. For the newer owners, when you hook up to the City water on-boarding port, your closed plumbing system comes up to the same standing pressure as the city system. This includes your pump, hot water heater, and all your piping to the bathroom, kitchen and outside . That pressure generally is much higher than the OTT pumped system, and can cause leaks. When not using this port, most leaks are slow drippers. But if your system is connected to this port, you can get a really serious leak. Especially if you some air in your plumbing, the high pressure City water and air in your system can cause severe water hammer. And that's when fittings get blown out. With a nod to JD's post above, when you have such a system breach, it will flow a lot of water into your hull. If you are not there, your trailer suspension and MEP systems are at extreme risk. Hence you really should be there when using this port. Unless my pump fails, my "Step Further" is that I don't use this port (except for winterizing at the end of season). Just not worth the risk. GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators topgun2 Posted 3 hours ago Moderators Posted 3 hours ago 22 hours ago, Rivernerd said: I now plan to carry a 1/2" brass fitting and 1/2" Pex B rings, with crimper, on our next long trip. You might also want to consider throwing in a 2 to 3 foot section of pex - just in case. Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
