Olive2Roam Posted Thursday at 10:32 PM Posted Thursday at 10:32 PM (edited) So we have had a DC to DC charging system on our LE I for a year now. It worked very well, but has become inconsistent and unreliable. The system was installed by a local inverter service center with a solid reputation. They actually are the supplier for some parts, such as solar panels, to Oliver. The tow vehicle is a 2024 Pathfinder with a "smart" alternator. The charger is a Victron Orion 50 amp. Using the Victron app I can see that the voltage on the input side of the charger is sitting between 12.2 and 12.4 volts. Aside from a brief spike on start up to 14.4 or so, it remains there. When driving the voltage remains that low and occasionally jumps to 14.4 or so and occasionally that casues the bulk charging to start. But this lasts only for a short time (seconds) and the voltage drops, and the charging stops. Bottom line is that the batteries are not being charged. The inverter service center has worked with me to make sure all of the parameters are correct, but there is still something wonky that we can't figure out. Out of curiosity I had the tow vehicle battery tested by a couple of battery shops and all looks good there. 12.2-12.4 seems very low for the output from the TV battery. In fact, the Victron parameters require 13.3 volts (default) and we have dialed that down to 12. 9. Any thoughts as to why the voltage from the tow vehicle would be that low? Also, does anyone know a DC to DC charging resource/expert that I could connect with to trouble shoot this? Thanks, Bob Edited Thursday at 10:33 PM by Olive2Roam https://www.instagram.com/campbells_olive2roam 2024 Legacy Elite Platinum, Hull #1465 2024 Nissan Pathfinder, Rock Creek Edition Lithium Batteries (260AH), 240 Watt Solar with Charge Controller, and a 2000 Watt Pro Inverter. Victron Orion XS 50A DC-DC Battery Charger
jd1923 Posted Thursday at 11:11 PM Posted Thursday at 11:11 PM 18 minutes ago, Olive2Roam said: 12.2-12.4 seems very low for the output from the TV battery. Yes Bob, this voltage is very low! An automotive LA battery after sitting overnight or sitting for a few days should read 12.5V minimum and more like 12.6V with a newer battery. When towing or at highway speeds, voltage across the battery with the alternator running should produce 13.6V min and more often 13.8V to a max 14.2V. The term Smart battery bothers me unless it's smart enough to know you have the DC-DC charger attached. Check a Nissan truck forum, search for "alternator" or "towing." If you have been DC-DC charging adequately for some time and now nothing, you could have blown something in the Nissan alternator. Perhaps it did not have +50A available. Your DC-DC charger installation is likely fine. Instead of "inverter service" test your alternator or take it to an electrical shop that rebuilds alternators and starters, Before I installed our Orion 50A charger, I installed a HD alternator rated at 50A greater capacity. Let us know. Best wishes, JD 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Olive2Roam Posted Thursday at 11:18 PM Author Posted Thursday at 11:18 PM 2 minutes ago, jd1923 said: Yes Bob, this voltage is very low! An automotive LA battery after sitting overnight or sitting for a few days should read 12.5V minimum and more like 12.6V with a newer battery. When towing or at highway speeds, voltage across the battery with the alternator running should produce 13.6V min and more often 13.8V to a max 14.2V. The term Smart battery bothers me unless it's smart enough to know you have the DC-DC charger attached. Check a Nissan truck forum, search for "alternator" or "towing." If you have been DC-DC charging adequately for some time and now nothing, you could have blown something in the Nissan alternator. Perhaps it did not have +50A available. Your DC-DC charger installation is likely fine. Instead of "inverter service" test your alternator or take it to an electrical shop that rebuilds alternators and starters, Before I installed our Orion 50A charger, I installed a HD alternator rated at 50A greater capacity. Let us know. Best wishes, JD Thanks, JD. This is the best description of the smart alternator that I have found. https://www.thefastreligion.com/mr-smart-alternator-function What I have seen on a couple of other forums (https://www.pathfindertalk.com/threads/disabling-vvcs-voltage-variable-control-system.45074/) is that some choose to disable the variable voltage control system and make the alternator act like they always have and just pump 13.4 V to the battery 100% of the time. I will definitely have the alternator looked at. There might be something going on there. Thanks for your thoughts. https://www.instagram.com/campbells_olive2roam 2024 Legacy Elite Platinum, Hull #1465 2024 Nissan Pathfinder, Rock Creek Edition Lithium Batteries (260AH), 240 Watt Solar with Charge Controller, and a 2000 Watt Pro Inverter. Victron Orion XS 50A DC-DC Battery Charger
Snackchaser Posted yesterday at 06:01 PM Posted yesterday at 06:01 PM Bob, as you already figured out, conventional alternator voltages can’t be applied to a smart alternator. They use a current sensor on the battery’s negative cable that signals the engine computer, which throttles the alternator down once the TV battery is charged. That saves fuel, and 12.4 V while driving can be perfectly normal. Based on what you’ve described, there are several possible causes for your problem. First, I’d verify that the DC-DC charger’s negative cable isn’t connected directly to the TV battery post. If it is, the Orion’s current bypasses the current sensor, the computer never sees the extra load, and it never raises the alternator voltage… unless for other reasons such as a low TV battery. Some manufactures specifically say to ground accessories to the body for this reason. Many vehicles have a ground stud on the far side of the sensor for accessories, otherwise use the chassis ground point where the battery’s negative cable attaches. Even if it worked before, it could be because the current sensor was seeing other TV loads that caused the alternator to increase voltage, and it wasn’t noticed when it stopped charging. If the truck can see the charger’s load independently from the truck loads, then the alternator should keep the voltage raised well above all of the thresholds. So it could have been charging when the truck called higher alternator voltage, but not otherwise. Second, the Orion’s engine shutdown detection works on voltage. My abridged explanation is that with the default “smart alternator” settings, it starts charging at 14.0 V. A smart alternator idling at 12.4 V never gets there, so the Orion thinks the engine is off. There’s also a separate input voltage lockout setting (default 12.5 V) below which charging stops. At 12.2 to 12.4 V, you’re under that too. These thresholds are adjustable in VictronConnect, but there’s a limit. Set them too low and the Orion can stay on and drain the truck battery when parked. Every vehicle is different, so some trial and error may be needed. It sounds like the Nissan system might have some unique quirks, but disabling the voltage control might be extreme. If fine-tuning doesn’t work, an “engine-running” signal on the Orions Remote L Terminal will force the Orion on. It’s there for this very reason. You must leave engine shutdown detection enabled when you do this, so it still turns the charger off when the engine stops. Victron describes several signal sources and recommends a true engine-running signal over a plain ignition wire. For your situation, a wire that goes dead with the key off is the best approach. In a trailer setup, this gets more complicated because it needs a third wire between the truck and trailer. Fortunately, the +12 V wire in the tow harness should work in most cases. Check it with a meter. It must be dead with the key off, and must not be live from the trailer battery with the truck off. Oliver doesn’t connect this wire on lithium systems so you should be okay. Ideally, it would also be off with the key on and the engine not running. Otherwise it could drain the TV battery if key is left on. This wire is usually capped off near the inverter and it’s typically a #10 or #12 wire. Also be aware that undersized cables, poor terminations, and corroded Anderson connectors can cause “additive” voltage drops that only show up when the charger is pulling heavy current. Corrosion builds over time, which could explain why it worked for a year and then stopped. This is where the “Input Voltage Lockout” setting comes into play. It’s set it so that Vlock-out ≤ Vshutdown − Vcable. The Vcable is the voltage drop in the wiring at full current. Victron’s manual provides an example voltage drop at 50 amps over a specific length of heavy cable. It’s a surprisingly high voltage drop, so if you add any additional resistance from undersized wire, corrosion or poor connections, you can add tenths of volts more, and that can push you under the set point where charging stops. You or your installer can measure your actual Vcable with the Orion running at full current (Turn on Oliver’s air conditioner and use a temporary +12V signal on the remote L trigger). Confirm its running full amps on the App. Vcable is the truck battery voltage minus the Orion’s input voltage. Many people wing this and get lucky, but it can become a latent problem especially with marginal wire sizing. Another way to get around this it is to de-tune the Orions maximum output amperage. For example: I have wiring sized for an old 30 amp charger based on the length of the run. When I upgraded to a new 50 amp charger, I reduced it’s power output to 30 amps to match wire size, otherwise Vcable could be too high. Mine actually worked at higher amps, but the wire was getting warm which meant the efficiency was suffering and I was burning more fuel. Finally, it’s worth load-testing the alternator. Turn on all the big loads (headlights, rear defrost, blower on high) and check that voltage climbs to around 14 V and holds. An alternator shop can do a more definitive carbon pile test. Also do a ripple test, which detects a burned diode that would reduce output. You can check it yourself with a meter on AC volts, with the loads on. There are YouTube videos showing how. If the voltage won’t rise even under heavy load, a Nissan dealer can scan for codes to tell whether the problem is the alternator or the current sensor. Again, it might be true that the Orion has never worked to full capacity and it was just not noticed. It probably worked periodically over long drives enough to charge a partially drained battery. The Victron has a history function where you can verify its performance over time. It's a good tool for problems like this. Anyway, it’s been fun trying to write this out in layman terms. I hope it helps, Geoff 1 3 1
Geronimo John Posted 14 hours ago Posted 14 hours ago 14 hours ago, Snackchaser said: I’d verify that the DC-DC charger’s negative cable isn’t connected directly to the TV battery post. If it is, the Orion’s current bypasses the current sensor, the computer never sees the extra load, and it never raises the alternator voltage… Geoff: Could this be the reason that I don't see a charge rate at via the Ollie's Victron shunt more than 22 amps despite having a 30 amp Orion in play? GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Snackchaser Posted 6 hours ago Posted 6 hours ago Gj, the short answer is probably not, at least not directly. The smart alternator issues I described above tend to make the Orion cut in and out. A steady maximum of 22 A from a 30 A charger likely has a different cause. However, if your charger’s negative cable goes straight to the battery post and bypasses the current sensor, then it’s worth correcting. Without a record of the current over time, it’s hard to know what your charger is doing at any given moment. I’m assuming that the wiring is properly sized for minimum voltage drop, and that the battery was low enough to accept full charge. A nearly full battery won’t draw as much current and excessive voltage drop can cause other problems with the settings that I touched upon above. So even without knowing your exact conditions, it sounds like a heat issue. The Orion reduces its output when it gets hot. I had this with mine. Even with two cooling fans, my old 30 A ran scary hot at full load (running the trailer air conditioner while driving). That’s why I upgraded to the 50 A Orion XS, which is far more efficient and makes much less heat. Here’s the math. Your 30 A Orion is a 360-watt charger at a nominal 12.2 V output But a lithium battery charges at about 14.2 V. So 360 W ÷ 14.2 V is only about 25 amps (at 104°F). Above that temperature, Victron derates it 3% per degree C. So with the air around the charger at 113°F, you’re down to about 22 A. See what I mean? Of course, this is all conjecture. First, I’d recommend swapping the 30 A for a 50 A and turning its output down to match your cable size and length. I sold mine on Craigslist to a guy with an Explorer van, where it was better suited. Second, if you want to see what’s really going on, run a load with engine running above idle, such as a small heater on low through the inverter. That keeps the Orion working at full output even if the battery is nearly full. Then put an inexpensive clamp-on DC ammeter on the Orion’s output cable to see the real output. The shunt only shows the net current in and out of the battery. It can’t separate the charger’s output from trailer loads or solar. Hope that helps! Geoff 1 1
Dean and Mary Posted 6 hours ago Posted 6 hours ago (edited) 2 hours ago, Snackchaser said: That’s why I upgraded to the 50 A Orion XS, which is far more efficient and makes much less heat. Thanks, Geoff. I appreciate all the information you've shared. I'm in the process of installing my DC-to-DC charger now, but I haven't begun working on the tow vehicle portion of the project. Your comments about the cabling requirements and the tow vehicle current sensor gave me some useful information to consider before I get started on that part of the install. I agree that the 50A Orion XS is significantly more efficient than the 30A version. Even with the improved efficiency and reduced heat output, I plan to mount my Victron Orion XS 12/12-50A DC-DC charger on top of Mobile Solar Consulting’s Orion Fan Module, which features temperature-controlled cooling. If you’re not familiar with this option, there are several YouTube videos that demonstrate the noticeable reduction in operating temperatures when using the fan module. For me, the added cooling is inexpensive insurance for a component that will often be operating under heavy load. Dean Edited 4 hours ago by Dean and Mary Clarification TV: 2019 F-150 Super Crew Lariat, 3.5L EcoBoost, 10 Speed Transmission, Max Tow and Offroad package. Oliver: 2022 – Hull 953, Twin Bed, with Lithium Platinum Package (640ah Lithionics lithium batteries), Outdoor Pro Package, 16” wheels, D52 axles, 5-leaf Alcan Spring package, Bulldog HD Shock Absorbers, 2 5/16 Bulldog coupler and LT tires. After market: Victron MultiPlus-II 12/4000, Two Victron 100/50 MPPT Solar Charge Controllers, Victron IP65 500A/50mV SmartShunt, Victron Lynx Distributor, Orion DC-DC charger 12/12V 50A 700W, Cerbo GX MK2 with GX Touch 70 Display. Misc: Custom Wood Accessories by Foybles. Seabiscuit Metal Designs front storage box and moose rack.
Dean and Mary Posted 6 hours ago Posted 6 hours ago (edited) 2 hours ago, Snackchaser said: That’s why I upgraded to the 50 A Orion XS, which is far more efficient and makes much less heat. Accidental duplication. Edited 4 hours ago by Dean and Mary Duplication TV: 2019 F-150 Super Crew Lariat, 3.5L EcoBoost, 10 Speed Transmission, Max Tow and Offroad package. Oliver: 2022 – Hull 953, Twin Bed, with Lithium Platinum Package (640ah Lithionics lithium batteries), Outdoor Pro Package, 16” wheels, D52 axles, 5-leaf Alcan Spring package, Bulldog HD Shock Absorbers, 2 5/16 Bulldog coupler and LT tires. After market: Victron MultiPlus-II 12/4000, Two Victron 100/50 MPPT Solar Charge Controllers, Victron IP65 500A/50mV SmartShunt, Victron Lynx Distributor, Orion DC-DC charger 12/12V 50A 700W, Cerbo GX MK2 with GX Touch 70 Display. Misc: Custom Wood Accessories by Foybles. Seabiscuit Metal Designs front storage box and moose rack.
Dean and Mary Posted 6 hours ago Posted 6 hours ago While gathering information for this project, I also discovered that Victron has introduced a new Orion XS 12/12-70A model. It has the same footprint and mounting pattern as the 50A version but adds integrated cooling fans. Victron also slightly increased the terminal size, which should make it much easier to terminate 4 AWG wire. Getting 4 AWG wire into the terminals of the 50A version can be a challenge, so that is a welcome improvement for higher-current installations. It is pricey and I just recently purchased my 50 amp version, so not for me at this time. TV: 2019 F-150 Super Crew Lariat, 3.5L EcoBoost, 10 Speed Transmission, Max Tow and Offroad package. Oliver: 2022 – Hull 953, Twin Bed, with Lithium Platinum Package (640ah Lithionics lithium batteries), Outdoor Pro Package, 16” wheels, D52 axles, 5-leaf Alcan Spring package, Bulldog HD Shock Absorbers, 2 5/16 Bulldog coupler and LT tires. After market: Victron MultiPlus-II 12/4000, Two Victron 100/50 MPPT Solar Charge Controllers, Victron IP65 500A/50mV SmartShunt, Victron Lynx Distributor, Orion DC-DC charger 12/12V 50A 700W, Cerbo GX MK2 with GX Touch 70 Display. Misc: Custom Wood Accessories by Foybles. Seabiscuit Metal Designs front storage box and moose rack.
