This thread True Induction Stove Top will not turn on has generated a lot of discussion about the advantages of an induction cooktop over a propane stove, while at the same time highlighting the electrical and battery requirements needed to make that transition practical.
Since I am currently in the middle of a major 12-volt system upgrade, it seems like a good time to at least consider replacing my propane stove with an induction cooktop.
My question for those who have already gone down this road: Is True Induction the only brand Oliver has used in its trailers, or have owners successfully upgraded to other brands? If you've made the switch from propane to induction, I'd be interested in hearing what cooktop you chose and how well it has worked.
Thanks,
Dean
TV: 2019 F-150 Super Crew Lariat, 3.5L EcoBoost, 10 Speed Transmission, Max Tow and Offroad package.
Oliver: 2022 – Hull 953, Twin Bed, with Lithium Platinum Package (640ah Lithionics lithium batteries), Outdoor Pro Package, 16” wheels, D52 axles, 5-leaf Alcan Spring package, Bulldog HD Shock Absorbers, 2 5/16 Bulldog coupler and LT tires.
After market: Victron MultiPlus-II 12/4000, Two Victron 100/50 MPPT Solar Charge Controllers, Victron IP65 500A/50mV SmartShunt, Victron Lynx Distributor, Orion DC-DC charger 12/12V 50A 700W, Cerbo GX MK2 with GX Touch 70 Display.
Misc: Custom Wood Accessories by Foybles. Seabiscuit Metal Designs front storage box and moose rack.
Yeah, that was a long thread for a cooktop that wasn't wired through the inverter! 🤣
Chris wants an induction cooktop, but I had already purchased a countertop model when @Ollie-Haus brought it to our attention over a year ago. She likes it so much she was using it daily at home, so I purchased another (clean) unit for Oliver only use. I also purchased a case which sits behind me in the TV. We use it inside and outdoors.
Later the idea of a built-in model came up but in a way we have the best of both worlds. I'm really tired of working on the Oliver, 3 years counting! Built-in not worth it for me at this time.🤣 (my new project; I'm cutting 14-step risers for a new deck staircase, LOL!)
We like the outdoor use and like having LP just in case. We bought Amazon used Like New for $80 each, no labor! Both had damaged packaging but were untouched inside: https://www.amazon.com/dp/B07KSNTSVR/
I can't answer your Oliver model question, but any drop-in model should work. The best you can buy may not be what OTT installs.
We cook on induction at home - love it. However, in an RV, with limited power at times, I preferred the propane. But we often cooked outside on a propane, so I guess it's a push.  Soon I will be breaking out all the "stuff" we stored away from the first Ollie experience - to tell the truth, I'm a little wary - no telling what I'm going to find.
Cindy,  Russell and  "Harley dog" . Winchester TN
2027 EII on the production board. "Ramble On"
2026 Chevrolet 2500 ZR2, 6.6L L8T gas V8
You're asking a great question considering the timing of making other upgrades to your electrical system. Regarding True Induction induction stoves, once you dig into the options, you will quickly discover that they all work on the same principles and have similar limitations. The unit that Oliver supplies is actually designed for either built-in or counter top use. They currently only offer the built in option. I personally do not like the idea of built in and I will get into my reasoning in comments below.
  As @jd1923mentioned above we have moved from propane cooking while Ollie traveling, to strictly induction cooking. Obviously when boondocking we have to be diligent to manage electrical usage, but our Olivers are very capable of supplying our needs with proper planning and by augmenting the solar and other recharging capabilities already built in. Our method is to utilize auxiliary solar panels plugged into the external solar port, a 3800wh EcoFlow lithium power pack that is kept charged up through a dedicated EcoFlow DC2DC charger in the truck, and we also have a DC2DC charger we've added to the Oliver to quick charge the Lithionics house batteries while connected to the truck. With these overlapping systems, we have so far found it pretty easy to manage our power supply, and without the use of a portable generator. For what it's worth, we still have the outside propane connections to use should we ever need or choose to use a propane grill. Here's the brand we use and we are extremely pleased with it's performance and ease of use: https://www.amazon.com/dp/B01FLR0ET8?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_3&th=1
Backstory: I and my wife went through a trial process using a single element countertop unit to experiment with the whole process, primarily for making the decision of getting an induction stove for our future kitchen remodel. That experiment was so convincing that we did opt for a five burner recessed induction stove for the kitchen.
The plan all along after our experiment, was to move the counter top unit to the Oliver for camp cooking. At that time we were using a two burner propane grill plugged into the external propane connection. And to be honest we have never used the propane stove inside the Oliver. Having the induction hot plate along quickly became the go-to cooking method just because it was so quick and easy to set up, use and clean up, and it was just like cooking at home. By the end of that season we stopped hauling the propane grill around with us and we added a second identical single element induction unit.
How we presently operate: The reasoning for two separate single elements was a natural progression, enabling us to cook while camping like we normally do in our home. When on occasion we need two elements, I just set the second one next to the other and we have two stove positions, each having full independent control of 1800 watts per element. I can use two separate pans on the hot plates, or I can use a single griddle that spans both elements and have separate controls for each side of the griddle. This essentially duplicates the capabilities of a dual element induction, but allows full wattage at both elements simultaneously, something that is not possible with a dual element stove. ( My electrical source is explained in the next paragraph ).  All two element stoves on the market that run on 120V 15A plugs limit the total draw to 1800 watts. The elements are independently controlled, but the total 1800 watts are split proportionally between the two elements, with one element taking priority over the second element.
Now in order for me to use both induction units with full control without tripping the breaker, I must plug the second unit into a separate power source, such as directly to the pedestal or to my lithium battery pack in the back of the truck. The lithium power pack is the method for boondocking and the pedestal is easiest when connected to shore power. This seems a little busy, but remember that probably 85% of the time we are only using a single skillet to prep our meal thus using only one induction unit. Currently we limit inside cooking to a single induction unit.
Now I'll describe what will be our next phase of induction cooking. As I mentioned earlier, we have not used the built in propane stove to date, but we use the induction unit inside regularly. I would like to have Oliver replace my counter top with one that has no stove at all. We like the idea of a clean, clear counter top for meal prep and other galley activities without having to work around a built in stove. On those occasions we cook inside, we will have a wide open counter to use as we please unobstructed. I would also like to add a second 120v plug in the cabinet area to be able to run the second unit off a separate independent circuit. It would have to be a non-inverter powered circuit fed directly from shore power to operate with full capability as we do when two element cooking outside. I would also like to add a second external plug next to the existing curbside plug, fed from the same independent circuit. This would allow using both induction units outside, plugged into the camper with no extension cords needed while connected to shore power. This is a system upgrade that is still in the planning stages.
Hopefully this long winded reply gives you plenty of food for thought as to your path forward. We love induction and we love the electric capabilities already built into our Oliver that makes our method of choice so easy to use, both outside cooking and inside. One last thought, with counter top appliances, if we have an appliance failure, it's a simple Amazon order to replace the bad one from any location in the country, and the second one will still fully supply our needs while the new one in in route, no need to seek service or interrupt our travels for a repair.
Chris
Edited by Ollie-Haus
Since OTT rewired my stovetop to the inverter, I have been quite pleased with using the True Induction Stove.  I can now make coffee in the morning.  We don't do a lot of cooking indoors when we are boondocking.  When cooking breakfast (eggs, sausage, coffee) my cast iron heats up quickly and I only use about half or less power draw (level 3-5 out of 10).  The battery/electrical system is more than adequate and doesn't register much of a drop if any.  Usually, we cook outside on propane when making larger meals.  While I am fond of the induction system, if I would have had a propane system already installed, I wouldn't even consider switching.  The benefits didn't outweigh the cost and possible troubles.  Just my 2 cents.
Lamar
2026 LE1 Hull #1687
Wow, that is the best idea yet. It would also be very easy for Oliver to implement on a new build. Rather than adding anything, they would simply eliminate one hole or opening in the countertop and the cooktop. The owner gains additional usable counter space, the installation is cleaner, and manufacturing is actually simplified. In addition, having two portable induction cooktops makes a lot of sense. "One is none and two is one." Use it outside or inside or keep in a cabinet until needed leaving space for an electric kettle ...
Thanks for all the information, it helped greatly!
Thanks, good information.
But consider storage of countertop units.
We have experimented a lot in our first three years of Oliver camping and I think we are heading in the right direction. I'm glad you picked up on the logic I was trying to convey.
BTW two induction units store very neatly in the cabinet above the TV at the back of your Oliver. We also store a large and a small induction ready skillet with glass lids in the same space.
FYI in a short conversation while at the rally a few weeks ago, it appears Oliver is thinking very much along these lines for possible future cooking appliance options. Who knows where it will go but as always they are continuously trying to improve the customer experience with Oliver campers.
See my related answer in my next comment.
John, There is usually a down side to almost all options and that is worth considering.
This is our storage method. I normally have a hand towel between each item for cushioning while traveling. I removed them to make the method clearly visible in the picture. There's tons of space remaining for other storage needs in this same cabinet space.
Here's my outside setup for the griddle on two elements using a Jackery 1000 for the second unit. I was preparing Beef tenderloin and jumbo scallops for that meal.  It works flawlessly even on the highest setting and you could easily operate the second unit for several meals without recharging.
For anyone interested in the equipment we use for induction camping, here's a list of the items we keep in the Oliver while traveling:
Duxtop induction cooktop
Greenpan ceramic coated induction ready skillet with glass lid - Large
https://www.amazon.com/dp/B074CWBJ5D?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_3
Greenpan ceramic coated induction ready 10" pan with glass lid
https://www.amazon.com/dp/B074CVZ7MM?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_9&th=1
Greenpan induction ready 18" ceramic griddle
https://www.amazon.com/dp/B0D2J2LL5B?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_2
Protective no-slip silicone pad for induction cooktops. Prevents slipping and scratching. Prevents overheating of cooktop while cooking.
https://www.amazon.com/dp/B0B1QLB8QX?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1&th=1
First off, your clean countertop idea is perfect, would add positively to the clean look of the Oliver interior. I’d have OTT ship me one but you live closer! 😎
Cool to have one burner for Boondocking and can power two when on shore.
We could run two on inverter, but for us one is enough. I’d have to add an outlet since OTT daisy-chained all outlets off one 15A GCFI.
@Dean and Mary will soon be able but dual outlets apply.
Y’all r goin’ to need some more Ah! 🤣
17 hours ago, Ollie-Haus said:
Quite a few forum members have spoken highly of this unit. Many use it as their main stove, while others keep it as a versatile backup for cooking indoors or outdoors. We just ordered one to try for ourselves. Regardless of the outcome, I'm sure it will get used either in our home or in the camper. Testing it firsthand seems like the easiest way to determine whether it meets our needs.
Still looking for feedback from anyone that has swapped out their factory propane stove for an induction stove.  Thanks, Dean
There might not be any. I know the 2026-27 Olivers have the option, but nobody has yet shown an upgrade post on our Forum.
John,
That is good information to know, and it explains why my searches came up empty. If I decide to pursue this upgrade, I may end up being the first person to document it on this forum.
The True Induction TI-2BN 14-inch built-in vertical dual-burner cooktop is rated at 1,750 watts and measures approximately 23" D × 15" W × 2.1" H. By comparison, our factory propane cooktop is roughly 15" W × 18" D, so the installation would require enlarging the countertop cutout to accommodate the additional depth.
From an electrical standpoint, the upgrade would be fairly straightforward for me. It would require running a stranded marine-grade 10/3 cable to a dedicated 20-amp circuit breaker and making the appropriate connections. The project would also involve removing the propane cooktop, properly capping or terminating the propane supply line, and finishing the countertop modifications.
At least on paper, it appears to be a very doable conversion.
Well, I learned something: The 2026-2027 Oliver trailers are not using the True Induction vertical dual-burner cooktop. Instead, they are installing the horizontal version. Unfortunately, the horizontal model would not fit my existing cooktop opening without replacing my countertop or turning the horizontal unit vertical. 😕
The vertical dual-burner model was appealing because its dimensions appear to be much closer to the footprint of the existing propane stove cut out. In my case, it looks like the conversion could be accomplished by simply enlarging the current cutout to provide the additional depth required.
The vertical model may have been discontinued, since I keep getting no longer in stock from several suppliers. If it has in fact been discontinued by True Induction, that may make this project more difficult. I'll need to do some additional research on availability before giving the conversion any serious consideration.
Making the cut-out opening a little larger is something easy enough. I installed a return duct filter assembly where OTT only had a grate. Cutting the fiberglass worked well to make the opening larger, using blue tape and a power jigsaw.
@mossemi used a router to cutout an opening under the kitchen drawers. Mikes' pics looked great and that's sure a cool way to do it which could work for your application to cut a clean line.
I tried removing the rear propane connection. The quick connect which for some reason OTT thought should be mounted behind the bumper, right there with the sewer hose. 🤣 If it was mounted more like the front connection we could use it on occasion.
Those flange pipe fittings are on TIGHT! Although your hull is newer, so maybe better. I don't often give up but it became not worth the effort. The right way to do it is to remove the 'T' and replace it with a straight line coupler. You must get 2 wrenches on it, which alone isn't easy, or the fitting will turn and the pipe will bend.
I've seen most fridge upgrades where they just cap it off which should be OK, but the less propane connections inside the cabin, the better! 😎
