GarryandKristi Posted Thursday at 05:50 PM Posted Thursday at 05:50 PM While camping recently I heard a whistling sound from outside the trailer while our domestic heater was running. Later while winterizing, I saw a gap in the adapter flange that the flex ducting is attached to. The “breaker” extended completely around the entire circumference. Easy fix with HVAC duct tape. Don’t know how long this has been an issue. Garry and Kristi Apex, NC 2018 Oliver Elite II Hull 372 TV 2015 Ram 1500 3.0 L EcoDiesel
Moderators topgun2 Posted Thursday at 08:14 PM Moderators Posted Thursday at 08:14 PM Sure - but - Look at all that "extra" heat that you'll not be adding to the area between the shells!😇 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted Friday at 12:46 AM Posted Friday at 12:46 AM @GarryandKristi Always good to get into the belly of the beast and put eyes on and check EVERYTHING. Especially those white pex plumbing compression fittings. Bonding time with your Oliver! 😊 Good on you! 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
jd1923 Posted Friday at 06:58 PM Posted Friday at 06:58 PM On 11/19/2026 at 10:50 AM, GarryandKristi said: a gap in the adapter flange that the flex ducting is attached to. Garry, your picture shows exactly as ours was and I had to tighted the flange mount too. How was the ducting in your hull? Ours looked OK from above but when lifted there were holes in the ducting all along the bottom for several feet. I also got rid of the two blower openings. It didn't make sense to me to blow half of the air towards the rear of the basement and then attempt to turn it 180 forward using this soft ducting that allows heat to go right through the light membrane. Who knows why OTT uses this awful stuff!?! When manufacturing while the hulls are wide open, it would be so easy and not much more costly to install rigid ducting! I removed the ductwork going to the rear and added a cover plate there inside the heater box. Then from Lowes I got semi-rigid ducting for the first 6 ft, for as far as I could reach. Airflow is night and day, although I'm not done. The day we need a new fridge, I will also make inspection plates under the drawers. The goal would be to follow and remove ALL the OEM ducting, all the way to the bathroom or as far as possible, with this superior style of semi-rigid ducting. BTW, adding a return duct filter improves performance (its flow resistance will pull more air from the streetside basement) with vents added in the bath and closet. This and deleting the under bed duct makes things much quieter in the bed area. We've read noisy furnace complaints a few times in these pages. There is a lot we can do to improve furnace performance, but yes the flange being properly seated is first and foremost! Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators topgun2 Posted Friday at 07:34 PM Moderators Posted Friday at 07:34 PM 35 minutes ago, jd1923 said: Who knows why OTT uses this awful stuff!?! When manufacturing while the hulls are wide open, it would be so easy and not much more costly to install rigid ducting! To provide heat to the area between the shells for cool/cold weather camping without the need for registers? 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
