This was discussed in a previous thread on essential tools to carry but I thought I’d start a new one to make the information easier to find.
I just finished greasing my E-Z Flex. We had it added to our trailer in December, the original suspension was shot. I’ve got about 3,800 miles on the trailer since the December install. I couldn’t remember how many fittings were on each side, so I started searching the forum because I knew it was recently discussed. EIGHT!!
I found all eight, used almost a tube of grease. The guys at the factory had done a good job when they did the initial lube. A couple fittings didn’t take much grease  Mike
So, based on this (and previous posts elsewhere) if he had used the 3 oz. tube, he would have used up to 5 tubes. I know that I would rather only change the tube once or not at all, while crawling on my back, under the trailer frame. My guess is the mechanical advantage of the longer handle, on the larger gun, makes the process of pumping grease into a fitting that might or might not take grease easier. Hopefully I will not have to change the tube while under the unit next time. Two reasons for this; I will not wait as long between grease jobs and I am sure the new grease gun took some of the grease to fill the pump and grease tube. And indeed there are 8 zerk fittings per side. I did find the flex hose was easier to get in and grease the 2 fittings "hiding" in the center piece. One pointing in each direction...
I was hoping to use the small tubes while traveling but guess not. That seems like a lot of grease for bushings. Mine only took 2 squirts each but I don't have many miles on the trailer yet.
Tom & Cheryl
LE II #305
2018 GMC 2500HD SLT Duramax
Wow that's almost one ounce per zerk.  Seems high for just a top-off at 3800 miles.  Is grease working itself out around the seals?
Wow that’s almost one ounce per zerk. Seems high for just a top-off at 3800 miles. Is grease working itself out around the seals?
The tube was not empty, not sure how much is left. The zerks in the middle are hard to see so I pumped until I could feel grease coming out, probably overdid it but too much is better than too little   Mike
I'm like Tom, give two full shots of grease per fitting with a 14OZ grease gun.  Ollie has one fitting that is a little hard to pump grease into. Take a little weight off of that side with Ollie's jack and fitting takes grease easier.
Ollie has one fitting that is a little hard to pump grease into. Take a little weight off of that side with Ollie’s jack and fitting takes grease easier.
I found the same thing.
Tom & Cheryl
LE II #305
  • 4 weeks later...
Me too
Me too
