Blum-Anderson Posted February 5, 2020 Posted February 5, 2020 Water started dripping from the curbside rear speaker. I removed the speaker, panel in the attic and some of the insulation inside the cupboard. Source seems to be the center break light or maybe the back-up camera. I cannot tell just yet because the leak is slow. It’s been going on a while, it’s wet under the cupboard mat. Anyone else had this problem? #198
Moderators SeaDawg Posted February 5, 2020 Moderators Posted February 5, 2020 We've had to reseal the upper brake light a couple times over the last 12 years. Sherry 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Galway Girl Posted February 5, 2020 Posted February 5, 2020 Found this ....as a past post on that issue. 2 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine Aug 2024 on way to Nova Scotia.
Patriot Posted February 7, 2020 Posted February 7, 2020 (edited) On 2/5/2020 at 12:35 PM, ctshort09 said: Found this ....as a past post on that issue. Hopefully this “leak” at the Oliver logo light will not be an issue with the 2020 Oliver Elite ll we have on order. Thank you ctshort09 for reposting this info. Edited February 7, 2020 by Patriot 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderators SeaDawg Posted February 7, 2020 Moderators Posted February 7, 2020 I doubt it will happen at pickup, or in the first severalyears. Our first leak at the light was 6 or 7 years in, as i recall Stuff happens. Hulls flex, over the miles. Leaks around lites/ ports happen on our 40 plus year old sailboat, usually at the smallest, tightest radiuses, earlier. The added issue with the third tail light on the Oliver is no real eyebrow, on our older elite. Maybe next year, when we update some of the eyebrow/ rv gutter material, we'll add a little strip above. So far, so good. Every six years for a reseal is not a really big deal. Sherry 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Trainman Posted February 7, 2020 Posted February 7, 2020 Ran into a fellow Oliver owner at the Casita Rally in Grapeland, Texas last year and he had the same problem, turned out to be the seal around the A/C unit. He said, the seal was installed improperly, required removing the A/C unit and reinstall with a new seal. Hope this isn't your problem, but there are very few things that can leak on the roof of the Oliver. trainman 2019 RAM 1500, 5.7 Hemi, 4X4, Crew Cab, 5'7" bed, Towing Package, 3.92 Gears. Oliver was sold.
