Thanks. I'm missing a few, too!
Dometic,  if they have them, is far more expensive.
Before this, I've been using stickyback silicone bumpers for cabinet doors. They only last a few months.
Thanks for the info, I ordered a bunch. A couple of mine have disappeared down under the grill top, does it lift up to gain access?
In our 2008 , anything lost, is , well, lost. Unless you disassemble a lot of stuff.
I don't know about yours.
You are a long ways ahead of mine, #12
I don't know if ours has the same grommet; we have the new Dometic stove with the cast iron grate.  On the new stove there are 4 grommets, one at each corner, with holes where a pin on the corner of the grate fits in.  We were a couple of days out from Hohenwald when I discovered two of these were missing.  I called Oliver and they had some and sent them in the mail.
There are also smaller rubber bumpers that the glass cover rests on when closed.
10 hours ago, BBandJ said:
One of the small rubber feet supporting our Dometic D21 Drop-in Cooktop Grill needed replacing. I found an option online that works. It's not the exact size/design as the original, but it does the trick. Actually feels like a more durable rubber compared to the original.
https://www.rubberfeetwarehouse.com/products/5-32-inside-diameter-rubber-grommet-fits-1-4-holes
Is this the new stove Oliver is installing now . . . . the one with the one piece cast iron grate that covers the entire cooktop?  Ours was missing two; Oliver sent new ones.
I think our Ace Hardware has the ones you mentioned.
Edited by Ray and Susan Huff
Ray and Susan Huff
1UP-USA Heavy-duty bike rack
Yes, we have the one-piece cast iron grate. Our Oliver manual calls it the D21. The new grommet works with the hole and grate, same way as the original.
