To remove the interior a/c cover do you remove the red or green screws or both ? And what type tool is needed to remove these screws? Thank you , Bobby
Edited by Bobfirst
I know the bolt in the red circle holds down the roof unit.  I think, because I don’t remember, the screw in the green circle holds the control portion of the inside cover in place.  To remove 90% of the inside cover, open the curb and street side vents completely and 2 screws will be visible in each opening.  Now that you know where to look, open the front and rear vents completely and look on the hinge side of the opening and you should see 2 screws in each opening, but they are much harder to see.  Use a long #2 Phillips screwdriver with a round barrel because you will be rubbing on plastic and a square barrel will hinder your efforts.
Edited by mossemi
16 hours ago, mossemi said:
I know the bolt in the red circle holds down the roof unit.  I think, because I don’t remember, the screw in the green circle holds the control portion of the inside cover in place.  To remove 90% of the inside cover off, open the curb and street side vents completely and 2 screws will be visible in each opening.  Now that you know where to look, open the front and rear vents completely and look on the hinge side of the opening and you should see 2 screws in each opening, but they are much harder to see.  Use a long #2 Phillips screwdriver with a round barrel because you will be rubbing on plastic and a square barrel will hinder your efforts.
Mossey you stopped me from making a huge mistake! Will tackle the front /rear vents screws . Thank you
Moses I removed 2 Philip screws from the front , rear & side vents but I still can’t pull down the inside white cover . What am I doing wrong ?
If you have the 8 screws out from the vents, then I think the 2 screws inside the filter area do need to be removed.  You circled 1 of them in green.
This picture is from the link Townesw provided.
Edited by mossemi
55 minutes ago, Bobfirst said:
Finally got the cover off . Now know the model & serial # that is needed to move forward with the heat strip blowing the furnace fuse
I don’t know if that was your only reason for wanting the cover off, but you should be able to see that label by taking off just the return air grill and filter.
Edited by Overland
