Bobfirst Posted January 20, 2021 Share Posted January 20, 2021 (edited) To remove the interior a/c cover do you remove the red or green screws or both ? And what type tool is needed to remove these screws? Thank you , Bobby Edited January 20, 2021 by Bobfirst Link to comment Share on other sites More sharing options...
Moderators mossemi Posted January 20, 2021 Moderators Share Posted January 20, 2021 (edited) I know the bolt in the red circle holds down the roof unit. I think, because I don’t remember, the screw in the green circle holds the control portion of the inside cover in place. To remove 90% of the inside cover, open the curb and street side vents completely and 2 screws will be visible in each opening. Now that you know where to look, open the front and rear vents completely and look on the hinge side of the opening and you should see 2 screws in each opening, but they are much harder to see. Use a long #2 Phillips screwdriver with a round barrel because you will be rubbing on plastic and a square barrel will hinder your efforts. Mossey Edited January 22, 2021 by mossemi 2 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house” Link to comment Share on other sites More sharing options...
Bobfirst Posted January 21, 2021 Author Share Posted January 21, 2021 16 hours ago, mossemi said: I know the bolt in the red circle holds down the roof unit. I think, because I don’t remember, the screw in the green circle holds the control portion of the inside cover in place. To remove 90% of the inside cover off, open the curb and street side vents completely and 2 screws will be visible in each opening. Now that you know where to look, open the front and rear vents completely and look on the hinge side of the opening and you should see 2 screws in each opening, but they are much harder to see. Use a long #2 Phillips screwdriver with a round barrel because you will be rubbing on plastic and a square barrel will hinder your efforts. Mossey Mossey you stopped me from making a huge mistake! Will tackle the front /rear vents screws . Thank you 1 Link to comment Share on other sites More sharing options...
Townesw Posted January 21, 2021 Share Posted January 21, 2021 (edited) I have the 3314850.000 Air Distribution Box on Hull 313. See if this document for installation of the Dometic Air Distribution Box 3314850.000 answers your questions. https://www.intechtrailers.com/images/info/PDF/Dometic/schematics-ac-diagrams.pdf Edited January 21, 2021 by Townesw 1 1 Bill and Martha 2018 LEII Hull 313 2019 Chevrolet 2500HD Duramax Link to comment Share on other sites More sharing options...
Bobfirst Posted January 22, 2021 Author Share Posted January 22, 2021 On 1/20/2021 at 6:40 PM, mossemi said: I know the bolt in the red circle holds down the roof unit. I think, because I don’t remember, the screw in the green circle holds the control portion of the inside cover in place. To remove 90% of the inside cover, open the curb and street side vents completely and 2 screws will be visible in each opening. Now that you know where to look, open the front and rear vents completely and look on the hinge side of the opening and you should see 2 screws in each opening, but they are much harder to see. Use a long #2 Phillips screwdriver with a round barrel because you will be rubbing on plastic and a square barrel will hinder your efforts. Mossey Moses I removed 2 Philip screws from the front , rear & side vents but I still can’t pull down the inside white cover . What am I doing wrong ? Link to comment Share on other sites More sharing options...
Moderators mossemi Posted January 22, 2021 Moderators Share Posted January 22, 2021 (edited) If you have the 8 screws out from the vents, then I think the 2 screws inside the filter area do need to be removed. You circled 1 of them in green. Mossey This picture is from the link Townesw provided. Edited January 22, 2021 by mossemi Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house” Link to comment Share on other sites More sharing options...
Bobfirst Posted January 24, 2021 Author Share Posted January 24, 2021 Finally got the cover off . Now know the model & serial # that is needed to move forward with the heat strip blowing the furnace fuse Link to comment Share on other sites More sharing options...
Overland Posted January 24, 2021 Share Posted January 24, 2021 (edited) 55 minutes ago, Bobfirst said: Finally got the cover off . Now know the model & serial # that is needed to move forward with the heat strip blowing the furnace fuse I don’t know if that was your only reason for wanting the cover off, but you should be able to see that label by taking off just the return air grill and filter. Edited January 24, 2021 by Overland 1 Link to comment Share on other sites More sharing options...
