Moderators topgun2 Posted January 3, 2023 Moderators Posted January 3, 2023 B and B - The only problem that I think there is with the Lippert shade is that it can not be opened and closed with the screen door in place. That means that you will need to open the door, unlatch the screen door from the main door, adjust the blind and then close both doors. This, obviously, prohibits being able to see who might be at the door without opening the door first - assuming that the blind is closed. With the Zarcor, you can adjust the blind from the inside without having to open the door. As far as I know, this is the only "shade system" that has this most important feature. Bill 1 5 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Hokieman Posted January 3, 2023 Posted January 3, 2023 1 hour ago, topgun2 said: As far as I know, this is the only "shade system" that has this most important feature. There is another option from Zarcor that works from the inside without opening the door. See @Andrew K post & pics of Ocean Air roller shade at this link. This is the upgrade my wife prefers, it’s on my task list. Ocean Air Roller Shade 2 “Ramble” - 2021 Legacy Elite II #797; 2020 Ford F-250. Former owner of 2019 Oliver Legacy Elite #431. Blairsville, GA
Moderators topgun2 Posted January 3, 2023 Moderators Posted January 3, 2023 I had forgotten about seeing that one. Certainly it presents another choice (and that is a good thing) but it will not block as much light as the sliding blind number. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted January 3, 2023 Posted January 3, 2023 4 hours ago, topgun2 said: I had forgotten about seeing that one. Certainly it presents another choice (and that is a good thing) but it will not block as much light as the sliding blind number. Bill All good points Bill. And when all else fails my eyelids pull the good night curtain when it’s time to hit the hay.. 😂😴 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
BBL Posted January 3, 2023 Posted January 3, 2023 4 hours ago, Hokieman said: There is another option from Zarcor that works from the inside without opening the door. Very good points and I am familiar with the Ocean Air shades having just sold our Airstream. Maybe the combination of the Ocean Air shade and the tinted window would provide the 99% solution. It’s great to have this dialog and have some options to consider. Thank you all! Brian 1
Gliddenwoods Posted 1 hour ago Posted 1 hour ago Where do I find the video of the Zarcor Company staff's demonstration of the replacement of the door window in an Oliver that is referred to at the beginning of this thread? 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
Gliddenwoods Posted 1 hour ago Posted 1 hour ago On 8/16/2022 at 10:12 AM, hobo said: I was talking to John (owner of ZARCOR) today with a technical question and he advised me they are looking for someone in the Dallas, TX area with a late model (2021 or newer) Oliver Elite so they can install and film one of their very nice door replacement windows. They will provide the parts and labor free-of-charge for use of the trailer to do the installation video. Here's an opportunity for a free upgraded window and your trailer will be a star. Call John at ZARCOR and tell him I sent you over. Paul Where do I find this finished video? 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
