Hello, I have searched the forum, but not ben able to find a link to purchase a new water pump filter.
I have a 2021 Elite1 and my filter housing has cracked.  Where can I purchase a new one?
Thank you in advance.
Hull #735 - 2021 Elite 1 (Shorty)  |  2021 Toyota Tundra
 Complete strainers are cheap and easy to find.
SHURFLO (255-313) 1/2" Twist-On Pipe Strainer
I read an article that some RV antifreeze brands can affect and crack the plastic housing, you might think about changing brands or researching that topic
Mine had cracked, and judging by the pink discoloration, the cracking was probably due to the winterizing anti-freeze.  I couldn’t find just the clear bowl/screen part available as a replacement so I just ordered the entire assembly that John linked above, and swapped out the bowl/screen.  When you do replace the bowl, make sure that the O-ring is in place and properly seated when you install the new bowl, otherwise air can get sucked in and prevent the pump from priming.
For sure my screen/bowl has snagged plenty of installation shavings... especially in the first two seasons.
But frankly I would like to change out the unit with a true water filter that would not be a PITA to install and service.
Any suggestions along these lines?
I bought one from Amazon.
