chiwald Posted June 15, 2023 Posted June 15, 2023 Good morning, Question for y'all. We have the compost toilet and I was wondering if anyone has repurposed the water valve behind the toilet for something like a portable washing machine? I just got one from the laundry alternative and planned to connect it to the bathroom faucet but the Manuel says you can't hook to a pull out faucet. So then I remembered the water valve behind the toilet and wonder if I could use that instead? Thoughts? 4 Explore, Dream, Discover Christi, Matt & Lucy 2022 Legacy Elite II, TB Hull # 1261 2019 F150 Limited
John E Davies Posted June 15, 2023 Posted June 15, 2023 How big is the washer? It could be a very cool mod, the water line simply tees into the cold line under the sink. It could drain into the shower pan. If you want to place it on top of the toilet you should definitely install a 1 way check valve so that there is no possibility of contaminating your water supply. Please don’t let it discharge into the campground grass like this guy! Have you seen this? … https://olivertraveltrailers.com/forums/topic/2758-how-to-wire-cable-clothes-line-full-cabin-length/ I put a Caframo fan in the back, with a rear window open and the MaxxFan running on exhaust, I can point the small one at the clothesline and it greatly speeds up the drying time. Especially with synthetic fabrics. Please post pics of your project! John Davies Spokane WA 1 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
chiwald Posted June 15, 2023 Author Posted June 15, 2023 The washer is 16" by 16" by 28" so not big. I would need to figure out what type fitting would work. And yes, drain to gray tank. 2 Explore, Dream, Discover Christi, Matt & Lucy 2022 Legacy Elite II, TB Hull # 1261 2019 F150 Limited
VBistro Posted June 15, 2023 Posted June 15, 2023 I'm very curious to see how this works for you. We currently do small loads in a laundry bag/scrubber, but are limited to a couple of pairs of bike shorts/jerseys at a time. 1 MaryBeth Boulder, CO 2022 Elite II #953 TV: 2021 Ford Expedition Max Platinum, Max Tow Package
chiwald Posted June 15, 2023 Author Posted June 15, 2023 It's working great! Went to home Depot and got a knowledgeable plumbing person. Took her 3 minutes to locate 2 adapters and a short hose 😁 This has to be my best mod yet! Got to figure out a storage place though. 2 3 Explore, Dream, Discover Christi, Matt & Lucy 2022 Legacy Elite II, TB Hull # 1261 2019 F150 Limited
Moderators SeaDawg Posted June 15, 2023 Moderators Posted June 15, 2023 4 minutes ago, chiwald said: It's working great! Went to home Depot and got a knowledgeable plumbing person. Took her 3 minutes to locate 2 adapters and a short hose 😁 This has to be my best mod yet! Got to figure out a storage place though. That's awesome. First, that you found a helpful and knowledgeable person at the big box store, and second, that they actually had everything you needed. How much does the cute little washer weigh? Will you have to keep it in the truckbed? 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
VBistro Posted June 15, 2023 Posted June 15, 2023 12 minutes ago, chiwald said: It's working great! Went to home Depot and got a knowledgeable plumbing person. Took her 3 minutes to locate 2 adapters and a short hose 😁 This has to be my best mod yet! Got to figure out a storage place though. Fantastic! Do you have a link you could share? MaryBeth Boulder, CO 2022 Elite II #953 TV: 2021 Ford Expedition Max Platinum, Max Tow Package
chiwald Posted June 15, 2023 Author Posted June 15, 2023 It does weigh 50 lbs. It's from The Laundry Alternative.com and the model is the purifi. They do have other models. They have a smaller one but I thought it was too small. Here are the adapters plus I bought a short plumbing hose. 1 3 Explore, Dream, Discover Christi, Matt & Lucy 2022 Legacy Elite II, TB Hull # 1261 2019 F150 Limited
VBistro Posted June 16, 2023 Posted June 16, 2023 Thanks for the details. This is on our list, but at 50 pounds it might have to wait until we have a TV with more payload. 🙂 MaryBeth Boulder, CO 2022 Elite II #953 TV: 2021 Ford Expedition Max Platinum, Max Tow Package
chiwald Posted June 16, 2023 Author Posted June 16, 2023 I think we are going to store it (only on long trips) in the front basket of the oliver wrapped in thick insulation. TLA does have a cute smaller one that only weighs 13 lbs. We can't haul it in our TV because it's taller than the bed cover. 1 1 Explore, Dream, Discover Christi, Matt & Lucy 2022 Legacy Elite II, TB Hull # 1261 2019 F150 Limited
chiwald Posted June 19, 2023 Author Posted June 19, 2023 Update to the weight of the purifi washer. It's 42 lbs not 50 lbs. Sorry about that! 1 1 Explore, Dream, Discover Christi, Matt & Lucy 2022 Legacy Elite II, TB Hull # 1261 2019 F150 Limited
Moderator+ ScubaRx Posted June 19, 2023 Moderator+ Posted June 19, 2023 Instead of moving a 42 pound machine in and out of the trailer, why not just use it sitting in the outside front generator basket. It would be very simple to run a water line out through the front of the trailer to the washer or if you're in a campground simply run a hose to it from the campground tap. 4 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
chiwald Posted June 19, 2023 Author Posted June 19, 2023 That is a GREAT idea. I just looked for a 5 ft hose on Amazon and its only "11 bucks! Thanks so much! And then it is not in the way in the bathroom! 1 2 Explore, Dream, Discover Christi, Matt & Lucy 2022 Legacy Elite II, TB Hull # 1261 2019 F150 Limited
Moderator+ ScubaRx Posted December 13, 2023 Moderator+ Posted December 13, 2023 On 6/19/2023 at 10:16 AM, chiwald said: That is a GREAT idea. Thanks so much! And then it is not in the way in the bathroom! You are very welcome. Glad it worked out for you. Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
rich.dev Posted December 13, 2023 Posted December 13, 2023 @chiwald this looks like a great little washing machine. Have you used it much and are you happy with it? **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
