Kgoodusav Posted October 10, 2023 Posted October 10, 2023 Well, forgot to check the hose clamps for the black water pipe hose clamps to make sure they were tight after the last winter & came back from a hike to find water or something coming out of the rear of the Oliver.Ā it was an easy fix after I determined what the liquid was 𫨠tightened everything up & no more leakšš» but now how do I clean out all the urine from the channels??? I tried pouring a little water & pine sol & raised the front of the trailer & then put a fan in the dinette basement but it still a little stinky!! help 1 4 Dallas, Texas Legacy Elite IIĀ Hull #77 Toyota Tundra Crew Max 1794
Moderators topgun2 Posted October 11, 2023 Moderators Posted October 11, 2023 13 hours ago, Kgoodusav said: but now how do I clean out all the urine from the channels??? I tried pouring a little water & pine sol & raised the front of the trailer & then put a fan in the dinette basement but it still a little stinky!! When the clamp that holds the black tank sewer line to the rubber connector piece under my dinette seat broke a couple of years ago I spent a fair amount of time even finding where "THAT" odor was coming from.Ā Once found and the clamp replaced I had the same basic problem that you now face.Ā After trying the usual Pine Sol scrubbing thing I resorted to waiting for a hot dry day, parked the Ollie in the sun and then I hosed out the area in question.Ā Note here that I didn't go crazy with the hose or the pressure.Ā Just a nice steady stream to make sure that everything in that area got thoroughly rinsed.Ā Then more Pine Sol and repeat the spraying.Ā Finally, about three days in the hot sun with all things opened up and fans blowing I was done. Good luck! Bill 4 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
dewdev Posted October 11, 2023 Posted October 11, 2023 After reading this post, I am even more glad I have a composting toilet and not deal with liquid in the black tank.Ā 2 1 2018 Oliver Elite II, Twin Bed, Hull #354, new Lithonics batteries andĀ Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition MaineĀ Ā
Ronbrink Posted October 11, 2023 Posted October 11, 2023 14 hours ago, Kgoodusav said: I tried pouring a little water & pine sol Try OdoBan, I use it to eliminate lingering fish odors in my skiff.Ā 1 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2ā receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
SNY SD UP Posted October 11, 2023 Posted October 11, 2023 Was the leak from the connection within the trailer or where the flex hoses connect to the rigid pipe that comes out of sewer compartment at the rear, but outside the trailer body? Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500Ā 6.4L HEMI GasserĀ 4drĀ 6.5' bed Ā Ā
Moderators topgun2 Posted October 11, 2023 Moderators Posted October 11, 2023 17 hours ago, SNY SD UP said: Was the leak from the connection within the trailer or where the flex hoses connect to the rigid pipe that comes out of sewer compartment at the rear, but outside the trailer body? Good question - My leak (as I mentioned) was under the dinette seat nearest the bath.Ā There is a small section of "rubber" that connects to two sections of black sewer pipe under that seat.Ā This rubber section is held in place with a standard stainless steel hose clamps similar toĀ THIS. Apparently the screw tightening device on the clamp gave up the ghost thus causing the clamp to loosen/fail.Ā Since I was on the road at the time (near West Yellowstone, MT) the first thing I did after determining the location of the leak was to simply try to tighten the clamp.Ā Unfortunately, that did work in that turning the screw on the clamp did nothing at all.Ā The good news is that the ACE Hardware store in West Yellowstone had a clamp that was very simple to install. Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
