Hi All,  My backup camera stopped working and the head unit cannot connect wirelessly even if it is within inches of the camera.  Of course the power is on to the camera.  My question is has anyone had this problem and how do i check if power is getting to the camera.  Also,  on my 2018 Hull #381 there doesn't seem to be a 12v fuse labled backup camera and the schematic doesn't show which one it would be.  I just thought I would ask here before tearing into everything.  Thanks
Try this -
turn the power off for both the monitor and the camera.
Assuming that you have verified that the camera is receiving power - turn it back on
while looking at the monitor, turn it back on - does it give instructions as to "re-pairing" it with the camera?
If yes, then do what it says.
Good luck!
You did not say which camera is installed on your trailer. IF there is a fuse it will be an inline one in the power cord hidden behind the white reflectix insulation glued inside the attic cabinet. You'll have to pull it all down to find it. Put it back into place using spray contact cement. Use of this will probably set off your propane detector.
Had the same problem.  Seems that tree branch ate my Furrion rear camera antenna.
Worth a glance.
