ZLarryb Posted December 9, 2023 Share Posted December 9, 2023 Taking delivery 1/3 and we are messing around with the bedding. I could not find the height of the cushions in the knowledge section. Does anyone know how thick they are? Thanks. Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted December 9, 2023 Moderators Share Posted December 9, 2023 47 minutes ago, ZLarryb said: Does anyone know how thick they are? Your best bet - just to make absolutely sure - would be to ask your sales agent at Oliver. However, historically the standard cushions have been 4 inches thick. Bill 4 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
ZLarryb Posted December 9, 2023 Author Share Posted December 9, 2023 Thanks a lot, will do Link to comment Share on other sites More sharing options...
rich.dev Posted December 9, 2023 Share Posted December 9, 2023 20 minutes ago, topgun2 said: However, historically the standard cushions have been 4 inches thick. Yea on our 2023 they were indeed 4” 3 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Solar, 3000W Xantrex Inverter) Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison Link to comment Share on other sites More sharing options...
Galway Girl Posted December 9, 2023 Share Posted December 9, 2023 1 4 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Link to comment Share on other sites More sharing options...
ZLarryb Posted December 10, 2023 Author Share Posted December 10, 2023 Thanks all, we are really getting excited. 3 1 Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted December 10, 2023 Moderators Share Posted December 10, 2023 23 minutes ago, ZLarryb said: Thanks all, we are really getting excited. I'm sure you are! Less than 4 weeks now. It'll be a just "a bit late Christmas" for you. Cushions in our 2008 are the historically used 4". We do use a memory foam topper, 1.5 inch. A queen topper, cut down, and cut in two, if you ordered twins, would work fine if you find you want one. We like the added memory foam comfort. Which configuration did you order? 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
Geronimo John Posted December 16, 2023 Share Posted December 16, 2023 (edited) FOR THE TWIN BEDS; We went with 6" memory foam. 4" would be a better choice should we ever need to replace them. GJ Edited December 16, 2023 by Geronimo John ADDED CLARIFICATION FOR WHERE USED. 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR). Link to comment Share on other sites More sharing options...
Geronimo John Posted December 16, 2023 Share Posted December 16, 2023 JUST THE BEDS. But I recommend using just a 4" topper over the stock mattreses. It would bed less expensive and less troublesome for forragng under the beds and quite comfortable as well. GJ 1 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR). Link to comment Share on other sites More sharing options...
ZLarryb Posted December 17, 2023 Author Share Posted December 17, 2023 We went with the twin configuration and I have built a simple insert for the space between the beds for those "special" occasions..... Yes, we went with toppers, thanks again for all the help 1 Link to comment Share on other sites More sharing options...
Geronimo John Posted December 20, 2023 Share Posted December 20, 2023 On 12/17/2023 at 2:18 AM, ZLarryb said: I have built a simple insert for the space between the beds for those "special" occasions... Can we see some pictures? Of the insert that is! 🙂 GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR). Link to comment Share on other sites More sharing options...
ZLarryb Posted December 27, 2023 Author Share Posted December 27, 2023 Sorry, did not see your post. So here are a couple of pictures. I am a bit concerned about stability but I think with the cushion it will be okay. Also, no claims to be a master carpenter just want some options, pickup next Wednesday so we will see. Second picture looks lopsided but I set it up unlevel in the drive. 2 Link to comment Share on other sites More sharing options...
