The Loonies Posted January 15 Share Posted January 15 Have successfully connected to BT with my iPhone in the past, but now I cannot connect. Furrion display states "LINK OKAY", but I still can't connect. I have deleted the old connection on my iPhone and tried to reconnect but it just keeps searching for the connection. Any tips and tricks will be appreciated. Ellie Kelly 2021 Elite 2, Twin Bed, Lithium & Solar, 3000W Inverter #880 2019 Ford F150, 3.5L V6 EcoBoost, 4x4 Supercab, Trailer Tow Package Link to comment Share on other sites More sharing options...
jd1923 Posted January 15 Share Posted January 15 Make sure your spouse's phone, a laptop or another device is not connected. The message "LINK OKAY" likely means there is a connection, but perhaps not your source. When we've had this connectivity issue, this is generally the cause. 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins! Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted January 15 Moderators Share Posted January 15 Another quick suggestion is to turn everything off - Furrion, phone, etc- and then try connecting again. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Link to comment Share on other sites More sharing options...
MAX Burner Posted January 15 Share Posted January 15 (edited) We have the same issue using our Furrion with multiple BT devices. We usually do a manual check in "Settings - Blue Tooth" to discover which device is connected when the Furrion displays the "LINK OK" message. We've defaulted to agree we always use D's devices for the music source and my BT is simply selected to "OFF". Edited January 17 by MAX Burner fixed a typo 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
The Loonies Posted January 15 Author Share Posted January 15 Thank you all for suggestions. I called Furrion after nothing worked and they walked me through a hard reset of the system. That solved the problem. 3 2021 Elite 2, Twin Bed, Lithium & Solar, 3000W Inverter #880 2019 Ford F150, 3.5L V6 EcoBoost, 4x4 Supercab, Trailer Tow Package Link to comment Share on other sites More sharing options...
rich.dev Posted January 16 Share Posted January 16 59 minutes ago, The Loonies said: I called Furrion after nothing worked and they walked me through a hard reset of the system. That solved the problem. Nice, how did you do the hard reset? 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Solar, 3000W Xantrex Inverter) Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison Link to comment Share on other sites More sharing options...
jd1923 Posted January 16 Share Posted January 16 That would lose a prior Bluetooth connection. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins! Link to comment Share on other sites More sharing options...
The Loonies Posted January 17 Author Share Posted January 17 There is a small hole next to the USB port for RESET. Insert a pin and hod for a few seconds, the Furrion wi reset. Yes, prior Bluetooth connections wi be gone, but it is easy to reconnect. 5 2021 Elite 2, Twin Bed, Lithium & Solar, 3000W Inverter #880 2019 Ford F150, 3.5L V6 EcoBoost, 4x4 Supercab, Trailer Tow Package Link to comment Share on other sites More sharing options...
