Oliver Travel Trailers
Design Benefits & Features
Benefits of Oliver's Innovative Design
The Oliver Travel Trailers' design was inspired by years of using other travel trailers and making every aspect better.
The Oliver is built with higher quality, more efficiency, easier to use and maintain.
Learn about how the design of our travel trailers benefit you.
4-Season Living
4 seasons camper trailer
The Oliver Travel Trailer's extreme weather protection features are unmatched. We have not seen a more effective design that shields from the elements, providing a level of protection that will give you confidence in any weather condition.
With a four-season travel trailer built with a unique double hull fiberglass shell, you have similar attributes of double pane windows & we combine them with the standard LP Ducted Furnace. The inside of the Oliver will be warm even in cold temperatures. Additional composite materials built into the shells combined with reflective and insulating materials and an air gap between the two shells help keep the interior at comfortable levels but also help prevent condensation from forming on the inside.
Easy & Stable Towing
The Oliver trailer's frame and layout design were designed with great attention to detail, ensuring a safe, balanced, and stable towing experience.
We've strategically addressed the crucial factor of tongue weight by mounting the holding tanks low in the trailer, between the shells, and placing the batteries directly over the axles. We designed the outer lower shell to wrap around the 2-inch x 5-inch tubular aluminum frame sections, adding strength and rigidity to prevent excessive sway and twisting of the frame when hit with side winds or turbulence from passing trucks. This design choice ensures optimal towing performance.
Double Fiberglass Core
double fiberglass core
Oliver's construction takes RVs to a new level. Both the exterior and interior shells are gel-coated fiberglass, a material that offers superior benefits over metal, laminated composites, and other materials commonly used to build travel trailers.
With Oliver, you can avoid the hassle of searching for older-model fiberglass trailers to refurbish. The interior seats, cabinets, walls, floor, and counters are all made of gel-coated fiberglass, ensuring you enjoy the superior benefits of this material throughout your RV.
Aerodynamic Design
aerodynamic design RV
The Oliver trailer's design allows for better aerodynamics while towing. The rounded corners, smooth sides, and recessed areas for external components all work together to reduce wind resistance, making it easier to pull the trailer and improving fuel efficiency.
The enclosed underbelly of the trailer helps minimize wind drag by keeping all tanks and water lines hidden and protected. This means that the trailer can move through the air more smoothly without the resistance caused by exposed components.
Premium Class Materials
travel trailers aluminum chassis frame
The superior construction of the fiberglass shells, high-quality materials, and craftsmanship used in building the Oliver ensures durability and longevity. This attention to detail extends to other components, such as latches, shore power connections, and hinges, all made of premium materials to withstand harsh weather conditions.
Even our frame and entry steps are made of aluminum for a "No Steel, No Rust, No Maintenance" factor. The decision to use 6061 aluminum equipped with zinc anodes for the trailer's frame and entry steps is significant because aluminum is known for its strength and corrosion resistance. By choosing aluminum over steel, the trailer is less likely to rust and require maintenance.
Better Storage Capacity
closet storage
Upon entering the Oliver, you will immediately notice a large floor-to-ceiling illuminated closet with shelving. In the kitchen, under the counter, you have spacious dovetailed wooden slide-out drawers for your cutlery, dish towels, and pans. Directly across from the drawers, you have a pantry for food storage.
For added peace of mind, the Oliver is equipped with overhead illuminated storage cabinets on both sides and the back, ensuring your belongings are always within reach. With the convenience of accessing the basement from the inside and a lockable outside door, you can rest assured that your belongings are safe and secure, ready for your next journey.
Self-Contained
self contained camper 4 season camping
If your travels take you in directions where water and electricity are unavailable, you’re in good shape in an Oliver.
Large fresh water and waste water holding tanks can get you through it. A battery bank of up to four can provide days of use because all our lighting is exceptionally energy-efficient LEDs. With two 20-pound propane tanks, you’ll have plenty of hot water and cooking abilities. If you need more, the Legacy Elite II can be upgraded with 30-lb. propane tanks for even more flexibility.
The optional solar packages and our standard remote freshwater refill abilities can stretch your stay from days to weeks.
Composite Exterior Shell
layers of chopped fiberglass
In addition to multiple layers of various composite materials, such as fiberglass mats and carbon core, the Oliver shells also include insulation sandwiched between the fiberglass shells. The carbon core adds durability and strengthens common stress areas in the shell, preventing any loss of integrity. The insulation layers make the travel trailer more energy-efficient, help regulate the unit's interior temperature, and ensure it is four-season camping-ready.
High-quality materials used to construct the Oliver shells set them apart from other fiberglass campers. The extra steps to reinforce stress areas and improve insulation make the Oliver shells durable, long-lasting, more efficient, and comfortable for the owner.
Privacy Overview
