Legacy Elite II vs Airstream Flying Cloud, Escape Camper & nuCamp Avia
Choosing the right travel trailer can feel overwhelming with so many options out there, but don’t worry—we’re here to make it easier for you. We’ve done the heavy lifting by comparing Oliver to top brands like Airstream, Escape, and NuCamp. Curious how Oliver measures up? Take a look at our detailed comparison table below to see how it stands side-by-side with these leading RVs.
Hull |
Legacy Elite II |
Airstream Flying Cloud 23' FB |
Escape 21' |
NuCamp Avia |
Body |
Four-piece Molded Fiberglass With Insulation Between Shells | Riveted Aluminum | Two-piece Molded Fiberglass | Lamilux® 4000 Fiberglass Skin, Aluminum Structure w/ Azdel® Sidewalls |
Insulation |
Double Hull, Thermal Break with Insulated Double-Sided Radiant Barrier Polyethylene Bubble + Radiant barrier + Vapor Barrier + Air Gap Barrier. | EcoBatt® Fiberglass Insulation | Rolled Foam - Option - Extra insulation / Heat pads with Spray Foam | Foiled Double Bubble Insulation |
Floor Plans |
Standard (75" x 79" Bed) or Twin Bed Floor Plans | Three Floor plans - 23FB, 23CB and 23CB Bunk | One Floor Plan | One Floor Plan |
Exterior Length |
23' 6" | 23' 9" | 21' 4" | 28' |
Exterior Height |
9' 7" | 9' 9" | 8' 7" | 9' 10" |
Exterior Width |
7' | 8' | 7' 4" | 7' 4" |
Interior Height |
6' 6" | 6' 7.5" | 6' 4" | 6' 4" |
Interior Width |
6' 7" | 7' 7" | 6' 8" | 7' 1" |
Dry Weight (Base) |
4,900 lbs. | 4,806 lbs. | 3,365 lbs. | 5,185 lbs. |
GVWR |
7,000 lbs. | 6,000 lbs. | 5,000 lbs. | 7,000 lbs. |
Net Carrying Capacity |
2,100 lbs. | 1,194 lbs. | 980 lbs. | Not Specified |
Fresh Water Tank Capacity |
Design Capacity 32 Gal. | 39 Gal. | 28 Gal. | 43 Gal. |
Grey Tank Capacity |
Design Capacity 32 Gal. | 30 Gal. | 28 Gal. | 39 Gal. |
Black Tank Capacity |
Design Capacity 15 Gal. | 18 Gal. | 22 Gal. | 43 Gal. |
Water Heater |
Suburban 2-Way Self Igniting 6 Gal. Water Heater, DSI - Option Truma AquaGo® Comfort Tankless Heater | 2-Way, 6 Gal DSI | 6 Gal DSI (LP Only) - 2 Way Option | ALDE® System |
Chassis |
Legacy Elite II |
Escape 21' |
NuCamp Avia |
Axles |
Quad Shocks On Tandem 3,500 Lb. Dexter Leaf Spring Axles with Nev-R Lube Hubs | Torsion Axle Suspension | High Lift Axle | Dexter Axle |
Brakes |
"Nev-R-Adjust®" 12" Electric Brakes | "Nev-R-Adjust®" Brakes | Electric Brakes | Dexter |
Front Tongue Jack |
Electric Powered Hitch Jack | Electric Powered Hitch Jack | Manual Hitch Jack | Electric Powered Hitch Jack |
Stabilizer Jacks |
Electric Powered | Manual | Manual | Electric Powered x4 |
Wheels |
Premium 10-ply Tires on Aluminum Rims with Black "Rock Guard" Wheel Well Lining | 15" Goodyear® ST225/75R15 on Aluminum Rims | 15" Radial Tires on Steel Rims with Mud Flaps - Option Aluminum Rims | 15" Aluminum Wheels |
Spare Tire |
Full Size Spare Tire with Aluminum Rim | Spare Tire with Steel Rim - Full Size | Spare Tire with Steel Rim - Full Size | Equipped with Spare Tire |
Hitch Connection |
7,000 Lb. Cast Iron Bulldog Hitch | Standard Trailer Hitch | Standard Trailer Hitch | Standard Trailer Hitch |
Frame |
2" x 5" Box Tube Aluminum Frame | Steel With Aluminum Skin Underbelly | 3" Box Steel | Aluminum |
Rear Bumper |
Hide-Away Brushed Aluminum Storage Bumper with Black/grey Water Drain Hose | Polished Bumper with Storage | Box Steel | Molded Trim |
Exterior |
Legacy Elite II |
Escape 21' |
NuCamp Avia |
Furnace |
Truma VarioHeat Furnace | 18K BTU Furnace | 12K BTU Furnace | ALDE® Radiant Heat 11,000-18,700 BTU |
Air Conditioner |
Dometic High Efficiency A/C (Aprox. 11,000 BTU) Unit and Wall Mount Thermostat (Can Operate with a 3000W Generator) - Optional Truma Aventa available. | Quietstream™ A/C w/ Heat Pump and Electronic Thermostat 13,500 BTU | Option | 15,000 BTU |
Exterior LP Gas Port |
Exterior LP Service Ports Available for Front and Rear (Option) | Exterior LP Quick Connect Service Port | Option | N/A |
Outside Wash Station |
Standard | Standard | Option | Standard |
Battery Storage |
Custom Enclosed Slide-Out Battery Storage (Fits up to 4x batteries) | Battery Box on Tongue (Fits 2x Batteries) | Storage Compartment Under Interior Seat Fits 1x Battery. (Optional Upgrade To Fit 2x Batteries) | Front Access Hood |
Deep Cycle Batteries |
Includes 4x Group 27 Deep Cycle 12v Batteries. Optional 6V AGM or Lithium Batteries Upgrades Available. | 2x Deep Cycle Battery Group 24 w/ Converter | Deep Cycle Batteries 1x Group 27 Deep Cycle Battery | 2x 6V AGM Batteries |
Propane Gas Tanks |
20 Lb. x2 Lp Tanks (Option Upgrade To 30 Lb. Tanks) | 30 Lbs. x2 LP Tanks | 20 Lb. x2 LP Tanks | 20 Lb. x2 LP Tanks |
Exterior Lighting |
High Mount LED Porch Lights, LED Ground Lights, LED Rear Brake and Backup Lights. Custom Rear High Mount LED Oliver Sign. | LED | LED Exterior Porch Lights 2x. Rear Upper LED Brake, Signal Lights and LED Marker Lights | LED Utility Lighting & Marker Lights, Lighted Entry Handle w/ Motion Sensor |
Awning |
Standard 16ft. Powered Pro Awning that includes wind sensor, upgraded canvas, and remote. Additional Awning on Street Side is also available | Manual ZipDee® Patio Awning with Sunbrella® Fabric | 13' Dometic Power Awning | 16' Cassette Awning w/ Bluetooth® Control |
Windows |
4x Bonded Dual Pane Windows with Screen & Day/Night Shades and Larger Rear Emergency Egress Window | Tempered Tinted Windows | Non-Thermal Pane Screened Windows | Stargazer Windows |
Steps |
Fold Up Aluminum Double Entry Steps with Grip Tape | Aluminum Entry Step | Single Steel Step | Project 2000 Aluminum Entry Step |
Interior |
Legacy Elite II |
Escape 21' |
NuCamp Avia |
Interior Lighting |
LED Lights | LED Lights | LED Lights | LED Lights |
Window Shades |
Day/Night Window Treatments (Excludes Bathroom) | Aluminum Roller Blinds | Draw Down Window Shades w/ Valances | Curtains |
Digital Monitoring Systems |
See Level II Monitoring System for Tanks and Battery Voltage | Probeless Tank Monitoring System | Monitor Panel w/ Holding Tank Level Indicator and Battery | Fill Level Monitor Screen for Tanks and Battery |
Vent Fan |
MaxxFan Deluxe RV Ventilator System with Remote Control | Fantastic© Fan x2 w/ Thermostat | MaxxFan | Fan-Tastic© Fan x4 |
Floor Construction |
Gel-Coat Over Fiberglass Molded Inner Shell | 5/8″ WBP Tongue-and-Groove Wood Floor | Plywood Flooring | Not Specified |
Interior Wall Construction |
Gel-Coat Over Fiberglass Molded Inner Shell | Complete Aluminum Interior Walls and Ceiling | Vinyl Headliner/wall Covering Over Wood Frame | Aluminum Structure w/ Azdel® Sidewalls |
Countertops |
Gel-Coat Over Fiberglass | Laminate Galley Top | Formica Counter and Tabletops | Laminate Galley Top |
Flooring |
Seamless Vinyl Floorings | Seamless Vinyl Flooring | Linoleum Flooring | Vinyl Flooring |
Upholstery |
Premium PU Leather Upholstery | Ultraleather™ (Synthetic) | Cloth | Pleather (Appears to be - Not specified) |
Electric |
Legacy Elite II |
Escape 21' |
NuCamp Avia |
12V USB Charging Outlets |
12V USB Charge Station | 12V USB Charge Station | 12V USB Interior Outlet | 12V USB Interior Outlet |
Interior 110V/120V Outlets |
110V Outlets on GFCI Protected Circuit | 110V Outlets | 110V Outlets | 110V Outlets |
Exterior 110/120V Outlets |
Battery Converter/Charger |
45 AMP Converter with Battery Charger | 55 AMP Converter with Battery Charger | 55 AMP Converter with Battery Charger | Not Specified |
Solar Package |
Optional 400W Solar Panel with Charge Controller in some Power packages | Prewired (Option 90W or 180W Solar Package with AGM Battery) | (Option 190W Solar Panel with Charge Controller) | Top-Line Solar Package |
Inverter |
Optional 2000W Inverter or 3000W Inverter with Lithium Pro Package | Standard 1000 Watt Inverter | Inverter with/without Transfer Switch - Option | 1200-Watt Inverter |
Power Cord |
30 Amp 25' Power Cord | 30 Amp 25' Power Cord | 30 Amp 25' Power Cord (Option) | Not Specified |
Kitchen |
Legacy Elite II |
Escape 21' |
NuCamp Avia |
Cooktop |
2-Burner LP Cooktop | 3-Burner Cooktop | 2-Burner Cooktop | 3-Burner Cooktop |
Refrigerator |
2 Way Refrigerator (12V, 11OV) | 2-Way, 5 Cubic ft. Refrigerator | 3-way 6 Cubic ft. Dometic Refrigerator | 3-Way 5.0 cu. ft. Refrigerator / Freezer |
Microwave |
Stainless Steel Microwave (Option Convection Microwave Oven) | Microwave (Option Convection) | Microwave (Option) | Convection / Microwave Oven w/ Air Fryer |
Cabinetry |
Acrylic Faces with Custom Designed Storage Drawers with Dovetail Joints | Lite-Ply® Laminated Interior Cabinetry | Custom Wood Interior | European-Styled Cabinetry |
Bathroom |
Legacy Elite II |
Escape 21' |
NuCamp Avia |
Bath Type and Features |
Wet bath (Option Shower Track for Curtain) | Dry bath | Wet bath | Dry Bath |
Toilet |
Porcelain Toilet (Option For Nature's Head Composting Is Available) | Porcelain Toilet | Thetford Toilet | Porcelain Toilet |
Entertainment |
Legacy Elite II |
Escape 21' |
NuCamp Avia |
TV |
24" Smart LCD TV | 22" LED HD TV x2 | Not Included | 24" Flat-Screen TV - Kitchen 28" Flat-Screen TV - Bedroom |
DVD, AM/FM/CD Head Unit with Speakers |
Furrion AM/FM Radio, Bluetooth®, HDMI, DVD, MP3, and CD-R/ RW Playback with Custom Mounted Speakers x4 | Clarion Stereo: FM/AM/CD Radio with Bluetooth® (in/out) & Blu-Ray™ DVD Player | Stereo/DVD Speakers (Option) | Premium Sound System w/ Subwoofer, Premium Exterior Speakers |
Cable/Satellite TV Hookup |
Cable/Satellite Ready with Extra Dual Exterior Coax for TV | Cable / Satelite / TV Antenna Hookups are standard | TV/Cable Ready with 120V Outlet (Option) | Cable / Satelite Connection |
Safety |
Legacy Elite II |
Escape 21' |
NuCamp Avia |
Detector Alarms |
Fire Extinguisher, Carbon Monoxide, Smoke & LP Detectors | Fire Extinguisher, Carbon Monoxide, Smoke & LP Detectors | Fire Extinguisher, Carbon Monoxide, Smoke & LP Detectors | Fire Extinguisher, Emergency Exit Window, Smoke Alarm, Carbon Monoxide, CO & LP Gas Alarm |
Pricing |
Legacy Elite II |
Escape 21' |
NuCamp Avia |
Starting Price |
$79,995 | $94,400 | $51,900 CDN (Approx. $42,195 USD) | $60,000 (No longer building newer models) |
