Oliver Travel Trailers
Small Camper with Bathroom and Kitchen
Legacy Elite Small Travel Trailer
18' 5" Length
5000 LBS. GVWR
Seats 6 / Sleeps 3
Single Axle
2026 Legacy Elite is Fully Booked
All available production slots for the 2026 Legacy Elite have been reserved.
For now you can check out the Legacy Elite II model.
Small Camper, Full-Size Features
Legacy Elite tiny camper
Tax Credit Available on Select Solar Packages
View Tax Credit Information
The Oliver Legacy Elite is an 18'5" fiberglass travel trailer built for easy towing and four-season use. The insulated double-hulled fiberglass shell stays dry in storms and insulated in cold. Inside: convertible dinette to sleeping area, kitchen with flush-mount induction stovetop and 12V refrigerator, bathroom with toilet and shower. Full spec list below.
Specifications
GVWR: 5000 LBS
Dry Weight (Approximate Of Base Model): 3700 Lbs
Tongue Weight (Approximate Of Base Model): 370 Lbs
Outside Length: 18' 5"
Outside Height To Top Of A/C: 9' 2"
Outside Width: 6' 6"
Inside Height: 6' 1"
Inside Width: 6' 2"
Fresh Water Tank Capacity: 32 Gal Design Capacity
Grey Water Tank Capacity: 32 Gal Design Capacity
Black Water Tank Capacity: 15 Gal Design Capacity
Seats: 6
Sleeps: 3
Oliver Legacy Elite in the snow, with four-season insulation and heated tanks.
Perfect for Couples
Pet-Friendly/Easy to Clean
Lithium Batteries Available
Solar Power Available
Four Season Camping Ready
Aircraft Grade Aluminum Frame
Easy to Maintain
Tankless Water Heater Available
Fiber-Granite Countertops
Powered Awning
Easy to Tow
Built to Last Generations
Inside the 18'5" Legacy Elite
The 18'5" x 6'6" footprint tows easily behind most mid-size SUVs, and every inch inside is convertible between dinette, lounge, and sleeping space.
Rear Seating Area Converts Into A 52" X 74" Bed
Side Dinette Converts into a 71" x 23" Bed
  • Oliver Legacy Elite small travel trailer floorplan with convertible dinette and table.
  • Oliver Legacy Elite small travel trailer floorplan with convertible dinette that turns into a bed.
Small Camper with a Bathroom
The Legacy Elite is a small travel trailer with a full bath (porcelain bowl, real shower wand, ventilation), a working kitchen (two-burner stove, Norcold three-way fridge, real counter space), and an 11,000 BTU Dometic AC sized for the insulated double-hull interior. Most small campers under 20 feet skip one of those three or undersize them to fit the footprint. The Legacy Elite was designed to not cut any of them. At 18 feet 5 inches and a 3,700-pound dry weight, it's still tow-able with a half-ton truck. What we learned building small campers since 2008.
Standard Features
The Legacy Elite uses the same fiberglass, axles, and electrical packages as the Legacy Elite II.
  • Hull Features
  • Full Custom Molded Interior and Exterior Insulated Shells Standard
  • Transportation Grade Gel-Coat with UV Protectants Standard
  • Custom Molded LP Cover Standard
  • Custom Molded Spare Tire Cover Standard
  • Plumbing, Holding Tanks and Drain Pipes enclosed between shells with heat to diminish freezing Standard
  • 32 Gal. Design Capacity Fresh Water Tank Standard
  • 32 Gal. Design Capacity Grey Water Tank Standard
  • 15 Gal. Design Capacity Black Water Tank with pressure flushing system for the Tank Standard
  • Chassis Features
  • Heavy Duty Anode Protected Aircraft Grade Aluminum Frame Standard
  • Dual Gas Shocks on Single 5000 Lbs. Dexter Leaf Spring "Nev-R-Lube" Axle with “Nev-R-Adjust” 12″ Electric Brakes for Exceptional Control and Braking (Now with Bronze Bushings & Grease Zerks) Standard
  • Aluminum Rims with 10-ply Tires Standard
  • Full Size Spare Tire with Aluminum Wheel Rim Standard
  • 7000 Lb. Cast Iron Bulldog Hitch Standard
  • Black “Rock Guard” Wheel Well Lining Standard
  • Hide-Away Aluminum Storage Bumper with Black/Grey Water Drain Attachment Located Inside Standard
  • Exterior Features
  • 20 Lb. LP Tanks x2 Standard
  • Fresh Water Fill Hook-Up Standard
  • City Water Direct Hook Up Standard
  • Fold Up Aluminum Double Entry Steps with Grip Tape Standard
  • Custom Enclosed Slide-Out Battery Storage (Includes 2x 12 V Batteries) Standard
  • Marine Grade Shore Power Connection with 25′ Cord Standard
  • Outside 11Ov GFI Protected Outlet w/ Cover Standard
  • Exterior LED Ground Lighting Standard
  • LED Brake Lights Standard
  • LED Marker Lights Standard
  • High Mount Porch Lights x2 (1 on Each Side) Standard
  • Custom Rear High Mount Oliver Sign Standard
  • Exterior Entry Handgrip Standard
  • Powered Pro Awning with LED Light Strip, Wind Sensor, Remote, & Upgraded Canvas Standard
  • Outside Wash Station Standard
  • Three Point Power Stabilizing System Standard
  • Bonded Dual Pane Windows with Screen & Day/Night Shades x4 Standard
  • Propane Easy Access Port Standard
  • Interior Features
  • Fiber-Granite Countertops, Tables, and Accents Standard
  • Full Surround Over-Head Lighted Storage Compartments Standard
  • Lighted Full Height Wardrobe Closet Standard
  • EZ Winterizing System Standard
  • MaxxFan Deluxe Remote Control RV Ventilator System Standard
  • 2 Way Self Igniting Water Heater, DSI 6 Gal Standard
  • Fresh Water Pump 55 PSI, 3.0 GPM Standard
  • Dometic High Efficiency A/C (Approx. 11,000 BTU) Unit & Wall Mount Thermostat Standard
  • LP Ducted Furnace Standard
  • Monitoring System for Tanks and Batteries Standard
  • White Day/Night Window Treatments (Excludes Bathroom) Standard
  • Overhead LED Lights Standard
  • LED Courtesy Floor Lights Standard
  • Reading Light Package Standard
  • Frosted Upper Cabinet Doors in Cabin and Bathroom Standard
  • Water Accumulator Standard
  • 120-Volt Receptacles Standard
  • 12V/5V Dual Charging Stations Standard
  • Kitchen Features
  • Flush Mount Induction Stove Standard
  • Refrigerator (12V) Standard
  • High Rise Swivel Faucet Standard
  • Custom Designed Storage Drawers with Dovetail Joints Standard
  • Stainless Steel Microwave Standard
  • Dinette, Seating, Sleeping and Storage Features
  • Side Dinette (seats 2) Converts to Single Bed Standard
  • Rear Dinette (seats 5) Converts to 74″ x 52″ size bed on Standard Floor Plan Standard
  • Bathroom Features
  • Molded Vanity with Toiletry Storage Standard
  • Dometic 311 Toilet (Low Profile with Porcelain Bowl) Standard
  • Exhaust Fan Standard
  • Brushed Nickel Faucet with Pull Out Shower Wand Standard
  • Sliding Frosted Privacy Window with Screen Standard
  • Mirror Tinted Door Standard
  • Waterproof Toilet Paper Compartment Standard
  • Towel Bar and Hook Standard
  • Central Heat Vent Standard
  • Safety Features
  • Fire Extinguisher Standard
  • Smoke Detector with Alarm Standard
  • Carbon Monoxide Detector with Alarm Standard
  • LP Leak Detector with Alarm Standard
  • Oversized Emergency Egress Window with Screen Standard
  • Electric Features
  • 120V Outlets on GFI Protected Circuit Standard
  • Progressive Industries EMS Surge Protector Standard
  • Converter with Built in Charge Wizard Standard
  • Multiple Charging Stations, 12V DC marine-grade female socket & dual USB 5V adapters Standard
  • External Plug & Play Port for Portable Solar Panels Standard
  • Entertainment Features
  • 24” Flat Screen LCD TV (120V, requires Inverter) Standard
  • Radio with FM and AM Dual Zone Audio Output, DVD, CD/MP/WMA/MP4, USB, Bluetooth and Remote Control Standard
  • Custom Mounted Speakers x4 Standard
  • Dual Exterior Coax for Portable Satellite/Cable Standard
Oliver Legacy Elite small travel trailer with optional solar panels for off-grid camping convenience.
Extend your Stay Off-Grid
Upgrade packages for the Oliver Legacy Elite include Lithium battery and solar panel options for extended off-grid camping.
View Optional Packages
User Reviews
3D Virtual Tour
Oliver Legacy Elite small travel trailer virtual 3D tour.
Take a walkthrough with a 3D Virtual Tour of the Legacy Elite online.
Take the Factory Tour
The factory tour walks you through how each Legacy Elite is built, from fiberglass layup to final QC.
Schedule a Factory Tour
Find Campers Near You
Oliver Legacy Elite small camper trailers near you – find a dealer map.
Three ways to see a Legacy Elite in person: a real owner's Ollie, our factory in Tennessee, or a local dealer.
See The Legacy Elite
Privacy Overview
