Legacy Elite vs Top Brand’s Travel Trailers
Explore Airstream competitors: Compare Oliver Legacy Elite and Elite II fiberglass travel trailers to alternatives like Airstream, Escape, and inTech for features, quality, and value.
Hull |
Legacy Elite |
inTech Sol |
Airstream Caravel 20FB |
Airstream Basecamp 20X |
Body |
Four-piece molded fiberglass with insulation between shells | Fiberglass | Riveted Aluminum | Riveted Aluminum |
Insulation |
Double Hull, Thermal Break with Insulated Double-Sided Radiant Barrier Polyethylene Bubble + Radiant Barrier + Vapor Barrier + Air Gap Barrier | Bubble Foil R7 (Walls & Ceiling) | EcoBatt® Insulation | EcoBatt® Insulation |
Floor Plans |
Standard (74" x 52" Bed) | Standard (80" x 60" Queen Mattress) | 1 Floor Plan (Front Bedroom, L-Shaped Kitchen, Convertible Dinette) | 1 Floor Plan |
Exterior Length |
18' 5" | 19' | 21' | 20' 2" |
Exterior Height - Top of A/C |
9' 2" | 9' 5" – 9' 9" | 9' 5" – 9' 7" | 9' 5" |
Exterior Width |
6' 6" | 8' 6" | 8' | 7' 9.5" |
Interior Height |
6' 1" | 6' 6" | 6' 7" | 6' 7" |
Dry Weight (Base) |
3,700 lbs. | 3,113 – 3,795 lbs. | 4,100 lbs. | 3,500 lbs. |
GVWR |
5,000 lbs. | ~4,000 – 4,500 lbs. | 5,000 lbs. | 4,300 lbs. |
Net Carrying Capacity |
1,300 lbs. | ~610 – 800 lbs. | 900 lbs. | 800 lbs. |
Fresh Water Tank Capacity |
32 Gal. (Design Capacity) | 28 Gal. | 23 Gal. | 23 Gal. |
Grey Tank Capacity |
32 Gal. (Design Capacity) | 32 Gal. | 30 Gal. | 28 Gal. |
Black Tank Capacity |
15 Gal. (Design Capacity) | 32 Gal. | 18 Gal. | 21 Gal. |
Water Heater |
Suburban 2-Way Self Igniting 6 Gal. Water Heater, DSI – Option Truma AquaGo® Comfort Tankless Heater | 6 Gal. – Electric or Gas | Tankless On Demand LP Water Heater | Electric/LP Water Heater |
Pricing |
Legacy Elite |
inTech Sol |
Starting Price |
$69,995 (base; MSRP $80,995; 2026 fully booked) | $48,341+ (2026 models; varies by floorplan) | $82,400 (2026 base MSRP; often $89k+ for 20FB with options) | $54,900 (2026 MSRP; some dealers $64k+ with options) |
