Legacy Elite vs Top Brand’s Travel Trailers
Explore Airstream competitors: Compare Oliver Legacy Elite and Elite II fiberglass travel trailers to alternatives like Airstream, Escape, inTech, and NuCamp for features, quality, and value.
Hull |
Legacy Elite |
inTech Sol |
Airstream Caravel 19CB |
Airstream Basecamp 20X |
Body |
Four-piece molded fiberglass with insulation between shells | Fiberglass | Riveted Aluminum | Riveted Aluminum |
Insulation |
Double Hull, Thermal Break with Insulated Double-Sided Radiant Barrier Polyethylene Bubble + Radiant Barrier + Vapor Barrier + Air Gap Barrier. | Bubble Foil R7 (Walls & Ceiling) | EcoBatt® Insulation | EcoBatt® Insulation |
Floor Plans |
Standard (74" x 52" Bed) | Standard (80" x 60" Queen Mattress) | 1 Floor Plan | 1 Floor Plan |
Exterior Length |
18' 5" | 19' | 19'5" | 20'2" |
Exterior Height - Top of the A/C |
9'" | 9' 5" | 9' 7" | 9' 6" |
Exterior Width |
6' 6" | 8' 6" | 8' | 7' 9.5" |
Interior Height |
6' 1" | 6' 6" | 6'7" | 6'7" |
Dry Weight (Base) |
3,700 lbs. | 3,640 lbs. | 4,000 lbs. | 3,500 lbs. |
GVWR |
5,000 lbs. | 4,000 lbs. | 5,000 lbs. | 4,300 lbs. |
Net Carrying Capacity |
1,300 lbs. | 610 lbs. | 1,000 lbs. | 800 lbs. |
Fresh Water Tank Capacity |
Design Capacity 32 Gal. | 28 Gal. | 23 Gal | 23 Gal |
Grey Tank Capacity |
Design Capacity 32 Gal. | 32 Gal. | 29 Gal | 28 Gal |
Black Tank Capacity |
Design Capacity 15 Gal. | 32 Gal. | 18 Gal | 21 Gal |
Water Heater |
Suburban 2-Way Self Igniting 6 Gal. Water Heater, DSI - Option Truma AquaGo® Comfort Tankless Heater | 6 Gal. - Electric or Gas | Tankless On Demand LP Water Heater | Electric/LP Water Heater |
Chassis |
Legacy Elite |
inTech Sol |
Axles |
Dual Shocks on Single 5,200 lb. Dexter Leaf Spring Axle with Nev-R Lube Sealed bearings (Now with Bronze Bushings and Grease Zerks) | Dexter Torsion | Torsion Axle Suspension, Nev-R-Lube® Sealed Bearings | Torsion Axle Suspension |
Brakes |
“Nev-R-Adjust” 12″ electric brakes for exceptional control and braking | Electric Powered | Nev-R-Adjust® Brakes | Nev-R-Adjust® Brakes |
Front Tongue Jack |
Electric Powered | Optional | Electric Powered | Manual |
Stabilizer Jacks |
Electric Powered x2 | Manual Rear | 4 Manual Heavy Duty Stabilizer Jacks, Powered Hitch Jack with Light | 4 Manual Heavy Duty Stabilizer Jacks |
Wheels |
Premium Aluminum Rims with 10-ply Tires with Black “Rock Guard” Wheel Well Lining | ST225/75R15 Tires w/Aluminum Wheels | ST225/75R15 Tires Stylized Aluminum Wheels, | ST235/80R16 Tires Stylized Aluminum Wheels |
Spare Tire |
Full Size Spare with Aluminum Rim | Full Size Spare Tire | Full Size Spare Tire | Full Size Spare Tire |
Hitch Connection |
7,000 Lb. Cast Iron Bulldog Hitch | Standard | Standard | Standard |
Frame |
2" x 5" Box Tube Aluminum Frame | All-Aluminum / All-Tube / Cage Frame | All-Aluminum / All-Tube / Cage Frame | All-Aluminum / All-Tube / Cage Frame |
Rear Bumper |
Hide-Away Brushed Aluminum Storage Bumper with Black/Grey Water Drain Hose | 2” Receiver – 100# Capacity | Polished Bumper with Storage | Polished Bumper with Storage |
Exterior |
Legacy Elite |
inTech Sol |
Furnace |
Truma VarioHeat Furnace | 16K BTU Furnace | Ducted Furnace (18,000 BTU) | Ducted Furnace (14,300 BTU) |
Air Conditioner |
Dometic High Efficiency A/C (Aprox. 11,000 BTU) Unit and Wall Mount Thermostat (Can Operate with a 3000W Generator) - Option for Truma Aventa | Dometic 13.5K BTU Low Profile Air Conditioner | 30 AMP Service Single AC with Heat Pump (13,500 BTU) | 30 AMP Service Single AC with Heat Pump (13,500 BTU) |
Exterior LP Gas Port |
Exterior Quick Connect Ports available for Front and Rear (Option) | LP Quick Connect | Exterior LP Gas Low Pressure Grill Connection | Exterior LP Gas Low Pressure Grill Connection |
Outside Wash Station |
Standard | Standard | Exterior Shower with Hot & Cold Water | Exterior Shower with Hot & Cold Water |
Battery Storage |
Custom Enclosed Slide-Out Battery Storage (Fits Up to 2x Batteries) | Interior Storage Enclosure | Exterior Front Tongue Enclosure | Inside Front Storage Compartment |
Deep Cycle Batteries |
2x 12 V Batteries. Optional AGM and Lithium Battery Upgrades Available. | 1x Deep Cycle 12V Battery | Deep Cycle Battery | Deep Cycle Battery |
Propane Gas Tanks |
20 Lb. x2 LP Tanks | 20 Lbs. Tank x1 | LP (2 – 20 lb. Steel Tanks) with Auto 2-stage Regulator | LP (2 – 20 lb. Steel Tanks) w/ auto 2-stage regulator |
Exterior Lighting |
High Mount LED Porch Lights, LED Ground Lights, LED Rear Brake and Backup Lights. Custom Rear High Mount LED Oliver Sign. | Step Light, Porch Light and Blue Accent Strip Along the Windshield | LED Dimmable Patio Awning Light, Cast Aluminum LED Tail Lights | Cast Aluminum LED Tail Lights |
Awning |
Standard Powered Pro Awning upgrade that includes wind sensor, upgraded canvas, and remote. | Optional 10' Thule awning | Manual Zip Dee® Patio Awning with Sunbrella® Fabric | Optional ARB Awning |
Windows |
3x Bonded Dual Pane Windows with Screen & Day/Night Shades and Larger Rear Emergency Egress Window | (8) Tinted Windows w/Shades | Interior Windows and Skylights, Handcrafted Welded Extruded Aluminum Window Frames, Panoramic Front Windows with Blackout Shades, Solar Front Window Protection, Tempered Tinted Windows with Double Cam Latching System | Interior Windows and Skylights, Handcrafted Welded Extruded Aluminum Window Frames, Panoramic Front Windows with Blackout Shades, Solar Front Window Protection, Tempered Tinted Windows with Double Cam Latching System |
Steps |
Fold Up Aluminum Double Entry Steps with Grip Tape | Entry Step | Aluminum Entry Step | Steel Entry Step |
Interior |
Legacy Elite |
inTech Sol |
Interior Lighting |
LED Lights | 12V Ceiling Dome Light, Blue/White Reading Accent Light | LED Interior Lighting with Dimmer, Reading LED Lights | LED Interior Lighting |
Window Shades |
Day/Night Window Treatments (Excludes Bathroom) | Pull Down Roller Shade | Blackout Shades | Blackout Shades |
Digital Monitoring Systems |
Wall Mounted, See Level II Monitoring System for Tanks and Battery Voltage | Tank Monitoring System | Probeless Tank Monitoring System, QuietStream™ A/C with Heat Pump & Electronic Thermostat | Probeless Tank Monitoring System |
Vent Fan |
Maxxair Fan Deluxe RV Ventilator System with Remote Control | Maxxair Fan | Fantastic© Fan with Thermostat & Automatic Rain Sensor, Roof Vent/Fan | Fantastic© Fan |
Floor Construction |
Gel-coat Over Fiberglass Molded Inner Shell | Infinity Woven Flooring | 5/8″ WBP Tongue-and-Groove Wood Floor | 5/8″ WBP Tongue-and-Groove Wood Floor |
Interior Wall Construction |
Gel-coat Over Fiberglass Molded Inner Shell | Aluminum Walls with Sealing Exterior Door | Complete Aluminum Interior Walls and Ceiling | Complete Aluminum Interior Walls and Ceiling |
Countertops |
Luxury Fiber-Granite | Laminate Galley Top | Laminate Galley Top | Laminate Galley Top |
Flooring |
Premium Vinyl Floorings | Infinity Woven Flooring | Seamless Composite Flooring, Seamless Vinyl Flooring | Seamless Vinyl Flooring |
Upholstery |
Premium Cloth Upholstery Options or PU Leather Upgrades | Not Specified | Ultraleather® | Ultraleather® |
Electric |
Legacy Elite |
inTech Sol |
12V USB Charging Outlets |
12V USB Charge Station | 2 USB Ports | 12V USB Ports | 12V USB Ports |
Interior 110V/120V Outlets |
110V Outlets on GFCI Protected Circuit | 2x 120V AC, 12V DC Outlet | 110V Outlets | Pop Up 110V USB and 110V Outlets |
Exterior 110/120V Outlets |
110V Outlets on GFCI Protected Circuit | 110V Outlets | 110V Outlets | 110V Outlets |
Battery Converter/Charger |
45 AMP Converter with Battery Charger | 35 Amp | Included (Unspecified Amp) | Included (Unspecified Amp) |
Solar Package |
Prewired - Optional Integrated 230W Roof Mounted Solar Panel with Charge Controller | Prepped to have a Solar Panel Kit Installed | Solar Pre-wire (3 Rooftop & 1 Front Access Points) | Solar Pre-wire (3 Rooftop & 1 Front Access Points) |
Inverter |
Option - Xantrex Freedom XC 2000W Inverter | 30 Amp 120V Breaker Box w/ 12V Converter - PD4100 | 1000W Pure Sine Inverter | Not Available |
Power Cord |
30 Amp 25' Power Cord | Not Specified | Not Specified | Not Specified |
Kitchen |
Legacy Elite |
inTech Sol |
Cooktop |
2-Burner LP Cooktop | 2-Burner Stainless Steel | 3 Burner Gas Cooktop (20, 22); 2 Burner Gas Cooktop (16, 19) | 2 Burner Cooktop (LP Gas) |
Refrigerator |
2 Way Refrigerator (12V, 110V) | 3.7 Cu Ft 3-Way | Refrigerator (12v Electric) 4.3 Cu Ft | Refrigerator (LP/Electric) 3.1 Cu Ft |
Microwave |
Stainless Steel Microwave - Option Microwave Convection Oven | 1 Cu Ft Stainless Steel | Stainless Microwave | Optional |
Cabinetry |
Acrylic Faces with Custom Designed Soft Close Storage Drawers with Dovetail Joints | (6) Drawers, (7) Overhead Cabinets, (4) Overhead Cubbies | Handcrafted Italian Lite-Ply Laminated Cabinetry | Handcrafted Italian Lite-Ply Laminated Cabinetry |
Bathroom |
Legacy Elite |
inTech Sol |
Bath Type and Features |
Wet Bath (Optional Shower Curtain) | Wet Bath | Wet Bath | Wet Bath |
Toilet |
Porcelain Toilet - Option For Nature's Head Composting Is Available | Porcelain Toilet | Standard Toilet | Standard Toilet |
Entertainment |
Legacy Elite |
inTech Sol |
TV |
24" Smart LCD TV | 32" TV | LG LED HD TV with Omni Directional Antenna | N/A |
DVD, AM/FM/CD Head Unit with Speakers |
Furrion AM/FM Radio, Bluetooth®, HDMI, DVD, MP3, and CD-R/ RW Playback with Custom Mounted Speakers x4 | Bluetooth Stereo w/(4) Speakers and DVD Player | Blu-Ray™ DVD Player w/(4) Speakers and Subwoofer | N/A |
Cable/Satellite TV Hookup |
Cable/Satellite Ready with Extra Dual Exterior Coax for TV | Cable TV Hookup | Cable TV Hookup | N/A |
Safety |
Legacy Elite |
inTech Sol |
Detector Alarms |
Fire Extinguisher, Carbon Monoxide, Smoke and LP Detectors | Smoke and CO Detector, LP and CO Alarm, Fire Extinguisher | LP, Smoke & Carbon Monoxide Detectors, Fire Extinguisher | LP, Smoke & Carbon Monoxide Detectors, Fire Extinguisher |
Pricing |
Legacy Elite |
inTech Sol |
Starting Price |
$69,995 | $42,539 | $77,300 |
$54,400 |
