Oliver Travel Trailers
Oliver’s Frame & Chassis – A Work of Art
oliver travel trailers aluminum chassis frame
By: Oliver
Updated: February 19, 2025
We focus on every detail at Oliver Travel Trailers to create the ideal travel trailer. Our frames and chassis are expertly crafted with high-quality materials and precision engineering, ensuring exceptional durability, performance, and a distinct style that stands out in the industry.
Our all-welded aluminum frame is not just heavy-duty; it’s made from aircraft-grade 6061 box aluminum with a hot-dipped galvanized steel chassis bolted to the frame. Zinc anodes are attached to the frame to prevent galvanic corrosion. This means that your Oliver Travel Trailer is not just a purchase; it’s an investment that will stand the test of time, providing you with years of reliable use and enjoyment.
Our trailers are not just about durability. They’re about your comfort and safety on the road. They provide peace of mind with premium aluminum rims with 10-ply tires, black Rock Guard wheel well lining and a full spare tire. The Dexter leaf spring Nev-R-Lube axle with Nev-R-Adjust electric brakes ensures exceptional control and braking for a smooth and safe ride every time. And with gas shocks included, you’ll experience a level of comfort and stability unmatched in the industry.
Oliver Travel Trailers Aluminum Chassis
  • 1: 6061 Aluminum Frame – Built with 1/4″ thick aluminum with welded gussets to add strength throughout the frame.
  • 2: 5/8″ Aluminum Frame Tongue – Our rigid tongue is built using a solid piece of 5/8″ thick 6061 aluminum to increase safety and towing performance.
  • 3: Fold-Up Aluminum Steps with Grip Tape – Our steps are welded to the frame for added strength.
  • 4: Single 5,000 lb. Axle (Legacy Elite) or Dual 3,500 lb. Axles (Legacy Elite II) – For minimal maintenance and safety.
  • 5: Dexter “Nev-R-Lube” Axle Hubs with “Nev-R-Adjust” Brakes – Equipped with “Nev-R-Lube” Hubs are pre-lubricated and sealed for life and “Nev-R-Adjust” 10″ or 12″ electric brakes offer exceptional control.
  • 6: Cast Iron Bulldog Coupler – Its design allows for 360-degree articulation of your tow vehicle’s ball, resulting in unparalleled stability regardless of the terrain.
  • 7: Dexter “EZ FLEX” Rubberized Suspension (Legacy Elite II) – Helps absorb road impacts better than traditional leaf spring equalizers alone.
  • 8: Heavy Duty Gas Shocks – Assist the springs and equalizer for enhanced towing.
  • 9: Three Point Electric Stabilizing Jacks – Makes setting up and leveling easy.
  • 10: Hide-Away Aluminum Storage Bumper – Storage for your waste hose and water drain attachment located inside.
  • 11: Premium Aluminum Wheels with E-Rated 10-Ply Tires – Quality rims and tires (includes a full-size spare).
Join Josh as he walks you through every aspect of Oliver’s frame and chassis, providing valuable insights into the construction that contributes to its superior quality.
Experience the beauty and craftsmanship of an Oliver Travel Trailer for yourself. Contact us today to learn more about our chassis and the features that make our trailers a cut above the rest.
Privacy Overview
