  1. Today
  2. Yeah Rich, so it must have kept the drip lines off the fiberglass on both sides! I believe with 25" I should have about 6 ft leftover to place a drip edge on the rear just below the OLIVER sign. You had cautioned us as to how this product would not straighten out, creating wrinkles, which can be seen in your picture. This thread started with a $16 product, with the title "DO NOT use this product!" The one you tried is $40 and the Trim-Lok with 3M tape is $63. It's expensive, but now that I have it in hand, you can stretch this product at a radius opposite to how it's coiled up for packaging and it stretches nicely without wrinkling. Your warning and finally @ScottyGS's suggestion got me to the right product, thank you!
  3. Dup post deleted.
  4. Oliver2Roam, I’ll let you know when the Pelland product arrives. After posting my first response, I called Pelland Enterprise and was told the window seal is still on backorder, but they expect it to ship in about 2–3 weeks. Dean
  5. I did same John, but I used the 3/4” and on both the driver and passenger side. https://a.co/d/08DrU7cW
  6. Bob, I believe Mike was the first to switch to BLACK and he convinced me a couple years ago when I replaced ours. See what my white ones looked like! And on your hull, only 2 years old, they need replacing? The windows look black, the thin rubber on the stationery window is black and over time the black will still look new. Mold stains the white and you cannot see it on black. They may not supply white anymore due to this issue. Actually, the window frames look more balanced left to right with the black moldings (pic1). BTW, to be sure for your hull, remove one edge to see if the profile of the rubber looks identical (pic2).
  7. I purchased this item and it appears to be the real deal: https://www.amazon.com/dp/B01CJRH19Y/ I'm not doing the windows but will run a full length strip up at the streetside roof line. Check the picture of the curbside awning of our Oliver. Prior owner likely installed this drip rail after removing the awning flashing. It appears to be the very same product (thanks Gregg)! For the 3 years we've owned our Oliver, we have water marks, drip lines top to bottom from dew/frost condensate or occasional rains. And it's only on the streetside, never curbside so this Trim-Lok drip rail has proven to work. It's like night and day. I will pressure-wash the Oliver and the curbside is clean and the streetside still has the water drip lines top to bottom unless you hand scrub with soap (something I'm not doing anymore). My plan is to copy this roofline drip rail at the same height on the streetside. I'll use blue painter's tape to mask the height for installation. Question for the group: I will get with my detailer, ceramic coating specialist, but now that we have a good shine on the Oliver, what do I need to do to carefully remove a line of the ceramic coating so that the 3M VHB tape will stick to the ceramic? 3M states to use rubbing alcohol for VHB tape prep, but an AI search returned that this will soften the ceramic coating and not remove it nor prep properly for VHB tape. I hate to be up there with acetone but that may be necessary. Thanks for any advice. JD
  8. Looks like it would work in the 2024. Did they have white available? I didn't see a color sector.
  9. Not certain re 2024, but this is what I purchased for the rubber surround on the window half that opens, as pictured. https://www.pellandent.com/Half-Inch-Glass-Vinyl-Seal
  10. Modern variable speed and inverter A/C units don't need the Easy Start and if your fan slipped alignment and jammed, unfortunately the Penguin has little to no used value. Perhaps you could sell the Easy Start. Yeah, I get it! We have campground reservations but everyday I wonder how 1700 miles one-way will "tucker us out! " Are we crazy? I may have to start a thread titled, "Calling all Rally Pickleball Players!" We would likely play pickleball or more often hike around the lake vs. attending vendor presentations. Chris and I are 4.0 rated seniors! But we play weekly with friends with less experience, so we "work on our soft game!" Hope to meet you and play someday. If not in Alabama, keep it in mind for the next time you travel SW! 😂
  11. Congrats and Welcome from Hull #1045
  12. we might not make the Rally @Lake Guntersville after 110 days in our Oliver. for some reason we are both tuckered out 😂 Hope somewhere along the way we can play pickleball with you guys in the future I can’t shove the Penguin off the roof until we salvage the east start out of it !!! I should have said we missed the worst of the fires……they were still ongoing Gunnison has very active open play at 9am Mon-Sat. Mostly seniors that are lots of fun ……a few advanced players on one court.
  13. Robert, I see you're local to Alabama. Going to the Rally with pickleball gear? Ours are always in the TV. Last summer on our Minnesota trip we played in 6 states! I see there are two public court locations right at the lake! 😎 (Pickleheads app) We're sorry, but please don't bother. Remove the interior panel, loosen 4 bolts, cut wires and then all you need to do is get up rooftop and heave! 🤣
  14. Welcome! It will be worth the wait. What a nice part of TN you live in! Mike
  15. We got lucky and only had a few Smokey days in Gunnison a little smoke in the wet mountain valley we just missed the flash floods and landslides in Ouray, Telluride and near Ridgway,and the Black Canyon……..missed the Aspen fire and the Gold Mountain fire it was a fantastic trip our only bad luck was on the way home in Oklahoma's panhandle it hit 109 degrees and the demonic squirrel cage developed a significant rattle………and was out of service Night temps dropped down and a box fan allowed us to sleep didnt have a chance yet to take the lid off the Penguin
  16. That’s great information. Thanks for sharing. I will check out the Steele product. I would be curious about the Pelland as well. Let us know how that works out. Thanks again!
  17. I've been negligent in posting to my YouTube channel... More to come from last year's Big Bend trip...
  18. Congratulations and welcome! Your pickup date is so close. What an exciting time!
  19. Steele Rubber Products sells window molding weather strip (part # 70-4500-257), and it worked perfectly on my 2022 Oliver Elite II. I learned about it from another forum member who recommended it in a different thread. Another option is: Pelland Enterprises - (part # H109-376). I ordered both products to compare, but have yet to receive the Pelland product.
  20. Does anybody have a supplier for the weatherstripping that goes around the windows in a 2024? That stuff is nearly impossible to get clean and I would just like to replace it all. It comes from Lippert, but Oliver hasn’t been able to get them to provide any replacement rolls of the stuff. Appreciate your thoughts. Bob
  21. clear skies and no smoke, amazing. AQI here this morning is 136 and getting worse.
  22. We are Steve and Elaine. Soon to be the proud owners of Happy Hour - our hull # is 1730. We pick up our Ollie on 20 August (can't wait). We saw our first and only Ollie in the wild (so to speak) when our family members Mitch and Debbie brought their Oliver "Dickens" home several years ago. (We are just finally able to get our own and start traveling) We live in Maryville, TN and look forward to meeting everyone out on the road. Cheers!
  23. after 3.5 months on the road and the Colorado mountain hiking trails we are heading home…. pulling out of Alvarado campground USFS near Westcliffe, Colorado San Isabel National Forest Sangre De Cristo Wilderness we hiked mountain trails all over Colorado and hit the pickleball court in Gunnison our longest hike was 10.5 miles, 2600 ft elevation gain
  24. Google Maps has basic travel planning that is free. Please find an example link below https://www.google.com/maps/dir/McKinleyville,+CA+95519/Medford,+Oregon/Lake+Shasta+Caverns+National+Natural+Landmark,+20359+Shasta+Caverns+Rd,+Lakehead,+CA+96051/@41.427653,-124.1908508,7.61z/data=!4m20!4m19!1m5!1m1!1s0x54d15c594e280e27:0x585da6f91a139f5f!2m2!1d-124.0312661!2d40.9373196!1m5!1m1!1s0x54cf7c5b37361f6d:0x7db736c5541136e!2m2!1d-122.8767396!2d42.3230112!1m5!1m1!1s0x54d27d843f61b711:0x35bb1e6f54db32a1!2m2!1d-122.3039955!2d40.8042955!3e0?entry=ttu&g_ep=EgoyMDI2MDgwNC4wIKXMDSoASAFQAw%3D%3D
  25. I don't know, but i sure would be annoyed with a Rivian tailgating me the whole trip.😂
  26. Yesterday
  27. In the past, I have used RVparky for my trip planning. I have 5 trips saved on the site and it will not allow me to add another trip unless I pay to upgrade to the PRO version. Are there any other trip planning sites to use that are FREE to use (not with a 7 day trial)? Thanks
