ADKCamper last won the day on December 6 2021
ADKCamper had the most liked content!
Location
Upstate NY
409
2018
Legacy Elite
ADKCamper's Achievements
We have a 2018 LE, with a single Epoch Essentials 300Ah battery. Two of the Epoch 300Ah will not fit into our battery tray. They will likely fit into the battery compartment if the tray is removed. Measure first; your mileage may vary. Our tray inside dimensions are 14-1/4" x 14-1/4". Two Epoch Essential 300Ah batteries side-by-side require 13-3/8" long x 14-3/4" wide (because the battery tops are wider than the bottoms and you can't snuggle them close enough together to fit into the tray). I would like Epoch to develop something like a 200Ah or 250Ah Essentials battery with Bluetooth and heat that is just a bit smaller so that I can fit two of them into the existing tray (or make the 300Ah battery just a bit narrower... but no wider or taller). I prefer using the tray as it slides out, making the connections easier *and* it provides slots for the battery hold-down straps to attach. p.s. I'm also a big Adirondack fan 🙂
Propane/CO alarm quick-disconnect?
ADKCamper replied to GlacierGirl's topic in Mechanical & Technical Tips
Yes... I have used SAE "2-flat" rubberized connectors for 12v dc devices that I might want to disable/remove easily for service, access, replacement, etc. Pay particular attention to the polarity as shown above... so that the "live" end connected to the trailer wiring harness has its positive "+" terminal covered in rubber (and the bare "-" terminal is exposed). I also use the small 2-pin SAE rubber covers to protect the trailer side of such connections when the 12v device has been unplugged. The rubber cover hangs on the wire right behind the trailer-side connector, ready to cover up the live female side of the connector. Also pay attention to the current rating of these connectors. This particular one is a Hopkins 47965, has 16 gauge wire nominally rated at 10A. Many such 2-flat SAE connectors are also rated at 10A max. Looking online a bit harder you can find 2-flat SAE connectors with 12 gauge wire if needed, Just as when you pull the fuse to silence a safety device such as this, be careful to flag the device as disconnected (e.g. hang some surveyer's "tell-tale" tape so it is visible sticking out from under the dinette seat cover) and take positive steps to restore the device to service as soon as possible. -
Towing with a Chevy Colorado Tow package 7500 pound
ADKCamper replied to jgilliam1955's topic in Towing an Oliver
Completely agree with all of the above experience & recommendations. We have an Elite I (5,000 lb Gross) that's lighter than the Elite II that most folks tow. Our tow vehicle has been a 1/2 ton Silverado 1500 5.3L for 8 years. This combination does fine in the flatlands and rolling hills of the East, Southeast and the mid-West. The Rockies and similar mountain ranges of the West are another thing entirely. We're the vehicle going uphill at less than 45 mph in the right lane with the flashers on. Downhill the transmission really winds up (and heats up) trying to help the brakes keep our speed under control. With an Elite II, in the mountains, it would not feel safe/controlled. After our recent trip to Glacier NP and parts of Oregon, we finally upgraded to a 3/4 ton Silverado 2500HD with the 6.6L gas engine and 10-speed Allison transmission. Higher GVWR for camping gear, bigger engine, bigger brakes, more engine oil and transmission fluid cooling capability. Yes the diesel version would be the ultimate, particularly with its engine braking capability, but the purchase and maintenance costs are higher *and* in some locales out in the boondocks away from the interstate highways you can't always find diesel fuel when you need it... hence the gasser. We haven't been back to the Rockies with the larger truck yet, but in the northern NY Adirondack "mountains" (only hills compared to the Rockies) the 2500 is SOLID; you don't even notice our little Elite I behind us. As some have mentioned, its not the best choice for a daily driver in town with narrower roadways, tighter parking and more traffic. -
Wandering Sagebrush started following ADKCamper
ADKCamper replied to John and Jodi's topic in General Discussion
I looked once for solid SS lug nuts, but could not find any in an appropriate configuration. Maybe I’ll give up on that and find some solid chromed steel ones… -
My deep socket gets stuck as well… with both the closest sae and metric sizes. I suspect poor quality control on the chrome-covered lug nuts’ outer dimensions. I carry a fairly long (and inexpensive) Harbor Freight 1/2” breaker bar for removing stuck or over-torqued lug nuts, and a shorter folding tire cross for putting lug nuts back on. I’m still trying to find a good spot to carry a 1/2” torque wrench. I also carry a 3.5 ton Humvee scissor jack with a combo rectangular & curved adapter on top of its pin. It is fairly short when collapsed and comes with a ratcheting box wrench with a long-ish handle which lifts one side of the Elite easily. It can sit on leveling blocks or 4x4s if required. -
Inverter freedoms 2000 is not turning on
ADKCamper replied to Skipster's topic in Welcome to the Oliver Forums
12v power on inverter input lugs? GFCI tripped on inverter output? Tried on/off switch right on inverter face panel? Big input fuse feeding inverter blown? -
VERY nice! Expect to be at St.Mary / East Glacier on the 10th for 5 nights. Fingers crossed we don't get an early blizzard this year!
I don't think anybody *likes* tolls... but if its a "modest" amount and the road is well-maintained, I don't think I can complain. Excessive tolls, or tolls on highways that are in bad shape rub the wrong way. We have encountered lots of interstate sections when traveling cross-country that are less than perfect but probably ok for a passenger car with squishy tires & suspension. Pickups and trailers with stiffer sidewalls & higher pressure tires are another thing altogether. Its not unusual to find highway sections where we have to slow down significantly below the speed limit to reduce the abuse on trailer and tow vehicle... which of course is not the safest thing to do on an interstate highway with all the "squishy" cars passing us with a significant speed differential :(
Northwest parks late summer, early fall
ADKCamper replied to Dennis and Melissa's topic in General Discussion
We were just at TRNP in April! Lots of Bison about, sometimes walking right down the middle of the road. Saw a few pronghorn, lots of prairie dogs, and a lone coyote looking for a late lunch in an active prairie dog village. In addition to the South Unit and the North Unit, we also visited Teddy Roosevelt's Elkhorn Ranch site. To get there you need to follow about 30 miles of gravel road (we didn't take the trailer!) and an easy flat 3/4 mile hike to get to the ranch site. The rangers seem to be pretty cautious about sending folks out over all that gravel road, but it seemed pretty solid to us. There were only a couple of spots that might be challenging if there was a lot of rain. There's not much remaining there other than a few foundation stones, and a couple of historic plaques, but you do get to see the view that TR saw during his time there along the Little Missouri River, and you can say "I stood where Teddy Roosevelt stood" 🙂 They're working on building TR's presidential library in Medora, but I don't think its supposed to be finished until next year. There's lots of TR history in David McCullough's "Mornings on Horseback" if that's your thing. The visitor center also had "Theodore Roosevelt and the Dakota Badlands" (Chester L Brooks & Ray H Mattison) which is a short, easy read about TR's time in the Dickinson & Medora area. Its likely available elsewhere as well. If you are into museums and have the time, there are a few in the area with lots of info/displays on dinosaurs (which were apparently abundant in the area), cowboys and native americans of that time and place: Bismark ND: https://statemuseum.nd.gov/ Dickinson ND: https://www.dickinsongov.com/museum-center Medora ND: https://medora.com/cowboyhalloffame/ (lots of rodeo stuff, but also other cowboy and native american info) We do have Glacier on our list, but haven't been there yet... -
Great views, though... especially near sunset. Weather can indeed whip up fast as @topgun2 has mentioned. We were there for several days in the fall of 2023 while exploring Cody (Buffalo Bill Museum of the West, Irma Hotel), Yellowstone, Grand Teton and vicinity 🙂
Yes, Fish Creek / Rollins Pond is a great campground. Been there many times with the tent & canoe, but have not yet been there with the Ollie. Its on the list! Enjoy your stay!
Great looking installation! We've got a 2018 Dometic 3-way that's likely the same as yours was. It struggles in the heat and will probably suffer the same fate at some point... we're messing with fridge fans now, but the compressor fridge certainly seems like the way to go. Did the old Dometic have to come out in pieces? Did the new Nova Kool fit through the door opening without removing the screen or the door?
Dexter Self Adjusting Brake - Fail
ADKCamper replied to Galway Girl's topic in Mechanical & Technical Tips
I would really like a disc brake upgrade as well... installed Kodiak discs on my boat trailer and it really worked out well. The problem is I can't find a "nice" place to mount the electric-over-hydraulic controller. Several folks with Elite-2's have mounted them in the propane enclosure, but there's not enough room in my Elite-1 propane enclosure. I mocked it up with a modified cardboard cereal box and it just won't fit in there without removing one of the two 20-lb tanks. I think I could mount it on top of the fiberglass in front of the front tongue jack, but its pretty exposed there, looks kinda funny, and screams "come mess with me" to passing by ne'er do wells LOL. I could put it in some sort of tongue box, but that would interfere with lowering the TV tail gate all the way. -
No it did not. I replaced the original Progressive Dynamics converter with the newer lithium-capable model... At some point in the future I will likely replace the PD converter with a Victron charger which can be programmed to match my Victron solar charge controller; I just need the time to find/manufacture a place to mount it. There's not a lot of room remaining under the seats in an Elite-1.
