Landrover
Landrover last won the day on April 27 2022
Landrover had the most liked content!
    484
    2019
Landrover's Achievements
Community Regular
Community Regular (8/14)
  • Posting Machine Rare
615
  1. If your still interested in a trailer valet after reading some of the posts most negative mine being one of them. give me a PM I can sell you the one I have Brand New great price.
  2. When all gets real bad at least us diesel owners. Can delete all the emissions junk and go back to making refined diesel fuel. Ahhh the smell of French fries while driving down the road. 😎
  3. I’m surprised this is happening? Doesn’t Oliver still have the booth that simulates heavy rain for thirty minutes to check for internal leaks? Maybe not, production may be moving to Quickly.
  4. Thanks John Perfect timing on your post. It makes a good point for anyone interested in buying my 2019 hull 484. Lol😛 much appreciated.
  5. I’m sure that would work fine the hard part will be getting them in the doorway and around the corner maybe a struggle. It would most likely be a two person operation. If its your only alternative why not, try it.
  6. I was 7-8 not sure. Dad had a new 1965 Chevy C30 4x4 step side, with a slide in camper. Mom Dad and my two brothers spent many times at Charleston Beach RI. On the breach way. Driving a couple of miles on the sand to get to the ocean front. My brothers and I got our fill of digging in the sand, when the truck got stuck in deep sand. We always made it. Camped for three four days on the ocean front no one around for miles. With just a ice block refrig small porti potty toilet and 20 gals of water. Good memories.
  7. Forgot to add Def fluid is available just about everywhere fuel stations Walmart hardware stores. Until they have a shortage which is becoming the norm among items. 😡
  8. Not sure about all the tech conversations. Never had a problem with the DEF fluid. My new GMC has a level gauge full to empty instead of a percentage of use, which makes it much easier to know when to add fluid. Adding fluid is usually 3-5000 miles of use, or every oil change. My mileage has increased to 16-18mpg towing the Oliver. only have 3,000 miles on the truck. I expect this average to go higher once the engine breaks in. There also has been a big increase in tow capacity 18,000 vs 13,500 on my 2017 HD diesel I thought my 2017 highcountry Duramax was over kill. 🤯 The comfort and safety level of the GMC with the diesel is worth putting in DEF fluid not happy about the fuel prices, who is? Still couldn’t be more happier with the choice of a diesel tow vehicle. 😎 you could also import this to Trainman’s post on tow vehicles.
  9. The up side is the service Oliver provides. You wouldn’t get half that attention from another company. Glad the elec was an easy fix.
  10. How about contacting the previous owner to find out what happened. They may or may not know the answer. It would be disappointing if an owner knowingly sold you a trailer with that big of a problem. Good luck. Also ask Oliver service if any repair tickets were ever noted.
  11. I thought the concept of the natures head toilet was to do away with the standard toilet and not utilize the black tank. More user friendly. I have to agree with JD and SeaDawg you’ll still get the urine smell which would most likely will come from your outside vent unless you constantly pour in vinegar or black tank chemicals. Then your in the same situation as a regular toilet. Find a dump station, hose hookup dump and black tank rinse. As suggested get a second or even a third pee tank. In my opinion that mod may get old quickly and not worth the hassle.
  12. They are saying not much to happen in the ocala Marion county area. Sea Dawg if it changes for the worst you can head my way plenty of room to wait it out.
  13. When I have someone who’s interested in seeing my Oliver, I will turn the Ac on about 45 mins before showing. I open all the cabinets to let the Ac circulate throughout the entire hull. The temp will be at 74dgs the automatic fan goes to low. It is quite cool and the noise level is minimal. This is in Florida temps in the 90s. In short 45mins🥶
  14. My GMC tow vehicle has a 400 watt plug in the rear corner of the bed. I cant see much use for it except for plugging in a portable fridge cooler. I’m wondering, if a solar panel can put out 1-2- 3 400watts with a charge controller can this 400watt plug be used in connection with a solar port connection and a charge controller as how a portable solar panel works? Of course the truck would have to be on and idling for the plug to work. Just thought this would be another possibility for battery charging.
  15. I guess i can officially say my post was right. They are junk and should not be considered. At least you can return it hope the return costs aren’t too bad.💸
