John Dorrer
John Dorrer last won the day on March 9
John Dorrer had the most liked content!
2 Followers
    1045
    2022
3,937 profile views
John Dorrer's Achievements
Veteran
Veteran (13/14)
  • Posting Machine Rare
1.9k
  1. Happy Turkey Day 🦃
  2. With a $1.00 off at Kroger, I paid $2.02/gallon. Regular price was $3.03.
  3. The Signature Model was on display at the Rally. Several people posted pictures and videos on Facebook. It is a prototype. Oliver said the single axle would debut a low cost, entry level (Signature Model), then the Apex, and then a revised LE1. I might be wrong on the order of #2 and #3.
  4. The Signature model was unvalled 3+/- weeks ago. Oliver shared pictures and videos. This is a prototype that showed a larger restroom and I believe no closet. I believe Oliver was looking for feedback and they got a lot.
  5. I have foam insulation around the outside shower knobs. I have Reflectix that fits outside the outside shower and covering the the floor and entrance to the basement. Two layers on the basement floor at the entrance. Pipe insulation caps for the 4 exterior connections. Soft foam in the ends and tape. 3/4" pipe insulation, cut and a piece added to allow a snug fit on the connector.
  6. Checked ours today and found only one strap and it was located in the center of the back of the Truma, top to bottom. It was still in tact.
  7. We have Tochta and are very happy with ours
  8. We had them vacuumed out, tires balanced, and metal valve stems put on to comply with TST tire monitors requirement of metal stems. We used the $25 gift card against the bill at the Truck Tire Shop. Work was done in 2023.
  9. As I stated, I don't believe this has anything to do with the actual Xantrex Freedom 3000. The inverter breaker has been a PIA and that is why Oliver switched to a large fuse. I have chosen to live with the breaker for now. I carry 2 spares. After running our Lithonics batteries down to 50% and shutting everything down for the winter, I put a wrench to the nuts and found everything tight. If I was to make an upgrade, I would make some of the changes David Austin made. He did a complete system upgrade from AGM/wet batteries to Epoch Lithium Batteries. He has a very detailed post on this.
  10. Here is what you should look for under the street side bed, near the front and next to the actual inverter. 1. Make sure it hasn't tripped 2. Make sure the wires are bolted tight.
  11. This sounds like the inverter breaker has gone bad, or tripped. This happened to us twice on our 2022. The last time we tried to heat a bowl of oatmeal while boondocking, inverter on, and after 30 seconds things shut down. Oliver changed systems in around 2024 and went to a large fuse. They didn't have any at our service visit. I bought one, and when I went to install I found the cable at the breaker, loose, the cable ends were pitted. This was totally on me as I didn't check the bolts like I should have. Here is the safe sequence, turn off solar, turn off the inverter breaker located under the street side bed at the front next to the inverter. Turn off each battery. Restore in reverse. Make sure you aren't plugged into shore power. It is also possible the breaker tripped. That happened on day 2 of owner ship and Oliver walked me through resetting it. When it happened 3 months later Oliver sent me one under warranty. I just turned everything off and checked the bolts. Be careful. That is a high voltage area.
  12. We buy our RV antifreeze at ACE Hardware. This is the safest product. They don't list the type. The white cap is the correct one, and safe for lines, connections and gaskets. Sorry, I cut of the cap, but it is the white cap.
  13. Yes, had our alarm go off, and discovered the detector was close to its 5 year life. I replaced it. I now cover my detector with seranwrap while trailer is winterized and stored. No more problems. RV antifreeze is human safe and it is designed to keep "O" rings and other components lubricated. When we de-winterize, we run fresh water through the lines, we close the fresh tank, and reconfigure the knobs, add a 1/4 cup of bleach into the hose, connect the hose to the fresh tank fill and fill the fresh tank. We run water through the lines, let things sit for an hour, and drain the tank. We refill the tank and are ready to travel. No where have I found anything posted that RV Antifreeze will damage your seals or components. We have hard water in Indiana and use a On The Go Water Softener and top of the line single filter whenever we fill up. Filter by The FitRV
  14. Spotted our fourth Oliver at Split Rock Lighthouse State Park, Shipwreck Campground, Two Harbors, MN Hull #1045, Jolli Olli says happy camping to Hull #475. Sure would love to know more about your small window awning/shades. Got to meet Minnesota Ollie on the way out. Had a nice chat.
