In Pursuit
Everything posted by In Pursuit
Is it safe to cover the compressor with a blanket?
Great job Joe, I will tackle this project in the up coming week.
I have to same issue with my door. Of all the campers I had I've ever owned I never seen this before. I did purchase a new replacement from Lippert, but are pretty pricy along with getting the graphic's on the outside.
Annually I buff my camper with Meguiar's Cleaner Wax then use thier Flagship Premium Marine wax; I wash it frequently with Woody Ultra-Pine wash-n-wax boat soap (the best) Good Luck
2023 New England Oliver Owner's Meet and Greet Mini-Rally Pictures
In Pursuit replied to dewdev's topic in Events & Rallies
Great pictures; looks like you guy's had a good time. -
Winter Camping for the season in New Hampshire
In Pursuit replied to In Pursuit's topic in Submit Your Story
I was dry camping all season. They have bathroom facilities at the camp ground. -
I camped all winter DRY, some guy's do hook up black water with PVC piping and flush with anti freeze. -
I was set up at a winter campground, so I didn't have any issue with my batteries due to the fact I was plugged into a shore line. -
Great looking carport!!
Great pictures and illustration!! Is that like 4' of extra duct work?
Thank You
Sorry took so long to finalize this tread; my computer got the virus. I ended up putting in a new gas valve and after removing the old one, you could see the valve handle was broken off.
I have a 2017 Legacy Elite II, The previous owner did take it back to Oliver service and all they did was re-caulk the windows. As I mentioned I went to my local RV center and had the Sealtech 430 test done which is a leak detection test. In the spring I will check the water system. Thanks,
Has anyone every have a problem with water collecting between the two rear bunk beds? Only after I purchased the trailer I found a service receipt that the previse owner brought it back to the factory to solve the problem, the service department noted that they resealed the windows. So I did bring it to a local RV center where they preformed a pressured Seal Test which shows no exterior leaks. I know it is pooling because of the angle of the camper, but because the floor is all most like a tub I can't figure where it is coming from! I will have to wait for spring and maybe try pressurizing the water system. Thanks,
Hot Water Heater (Truma) Bypass Valve Issue
In Pursuit replied to Frank C's topic in Mechanical & Technical Tips
Looks good!! -
Done
I will check tomorrow. Thanks, Done
I will try to post some pictures tomorrow when it is light. Thanks
Taking a close look at my connection with a flashlight it looks like the valve screw is broken. I will post a picture tomorrow.
My Roastove adapter doesn't have a shut off valve on it. I my change it out to the one you provide to me.
I do not see any valve shut off. It's dark out so I cannot take a picture. Thanks,
It is too dark out for me to take a picture, but my Quick Connect on my trailer is a female and doesn't have any valve shut off on it. Pl
